How to factory reset an iPhone without password or access to Apple ID?
    To understand How To Factory Reset Iphone Without Password​ to its settings, without the screen lock code you can use a special mode called Recovery Mode and a computer.First you need to turn off the Apple iPhone and then connect it to a computerNext you have to put the Apple iPhone into Recovery Mode, which's a bit different depending on the Apple iPhone model you have.On a Mac computer you can reset the Apple iPhone using the Finder application.On a Windows computer you have to use the iTunes application.When the computer asks you what to do you need to select the option that says Restore to erase the Apple iPhone and install the iOS operating system again.If the Activation Lock feature is turned on you will still need the original Apple ID and password to activate the Apple iPhone after you reset it to its original settings. If you do not have the Apple ID and password you will not be able to activate the Apple iPhone.
