من این برنامه راه اندازی LCD کاراکتری ر واز سایت زیر گرفتم و دقیقا هم جواب میده... (برد رزبری پای و زبان پایتون)
اما سوال اینجاست که با فرض اتصال سنسور دما مثل Ds18B20 چطور میشه مقدار متغیر اونو روی این LCD نشون داد... یعنی چه تغییری در دستورات برنامه LCD باید داشته باشیم؟؟؟
import RPi.GPIO as GPIO
import time
# Define GPIO to LCD mapping
LCD_RS = 7
LCD_E = 8
LCD_D4 = 25
LCD_D5 = 24
LCD_D6 = 23
LCD_D7 = 18
# Define some device constants
LCD_WIDTH = 16 # Maximum characters per line
LCD_CHR = True
LCD_CMD = False
LCD_LINE_1 = 0x80 # LCD RAM address for the 1st line
LCD_LINE_2 = 0xC0 # LCD RAM address for the 2nd line
# Timing constants
E_PULSE = 0.0005
E_DELAY = 0.0005
def main():
# Main program block
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BCM) # Use BCM GPIO numbers
GPIO.setup(LCD_E, GPIO.OUT) # E
GPIO.setup(LCD_RS, GPIO.OUT) # RS
GPIO.setup(LCD_D4, GPIO.OUT) # DB4
GPIO.setup(LCD_D5, GPIO.OUT) # DB5
GPIO.setup(LCD_D6, GPIO.OUT) # DB6
GPIO.setup(LCD_D7, GPIO.OUT) # DB7
# Initialise display
lcd_init()
while True:
# Send some test
lcd_string("Rasbperry Pi",LCD_LINE_1)
lcd_string("16x2 LCD Test",LCD_LINE_2)
time.sleep(3) # 3 second delay
# Send some text
lcd_string("1234567890123456",LCD_LINE_1)
lcd_string("abcdefghijklmnop",LCD_LINE_2)
# Send some text
lcd_string("RaspberryPi-spy",LCD_LINE_1)
lcd_string(".co.uk",LCD_LINE_2)
time.sleep(3)
# Send some text
lcd_string("Follow me on",LCD_LINE_1)
lcd_string("Twitter @RPiSpy",LCD_LINE_2)
time.sleep(3)
def lcd_init():
lcd_byte(0x33,LCD_CMD) # 110011 Initialise
lcd_byte(0x32,LCD_CMD) # 110010 Initialise
lcd_byte(0x06,LCD_CMD) # 000110 Cursor move direction
lcd_byte(0x0C,LCD_CMD) # 001100 Display On,Cursor Off, Blink Off
lcd_byte(0x28,LCD_CMD) # 101000 Data length, number of lines, font size
lcd_byte(0x01,LCD_CMD) # 000001 Clear display
time.sleep(E_DELAY)
def lcd_byte(bits, mode):
# Send byte to data pins
# bits = data
# mode = True for character
# False for command
GPIO.output(LCD_RS, mode) # RS
# High bits
GPIO.output(LCD_D4, False)
GPIO.output(LCD_D5, False)
GPIO.output(LCD_D6, False)
GPIO.output(LCD_D7, False)
if bits&0x10==0x10:
GPIO.output(LCD_D4, True)
if bits&0x20==0x20:
GPIO.output(LCD_D5, True)
if bits&0x40==0x40:
GPIO.output(LCD_D6, True)
if bits&0x80==0x80:
GPIO.output(LCD_D7, True)
# Toggle 'Enable' pin
lcd_toggle_enable()
# Low bits
if bits&0x01==0x01:
if bits&0x02==0x02:
if bits&0x04==0x04:
if bits&0x08==0x08:
lcd_toggle_enable()
def lcd_toggle_enable():
# Toggle enable
time.sleep(E_DELAY)
GPIO.output(LCD_E, True)
time.sleep(E_PULSE)
GPIO.output(LCD_E, False)
time.sleep(E_DELAY)
def lcd_string(message,line):
# Send string to display
message = message.ljust(LCD_WIDTH," ")
lcd_byte(line, LCD_CMD)
for i in range(LCD_WIDTH):
lcd_byte(ord(message[i]),LCD_CHR)
if __name__ == '__main__':
try:
main()
except KeyboardInterrupt:
pass
finally:
lcd_byte(0x01, LCD_CMD)
lcd_string("Goodbye!",LCD_LINE_1)
GPIO.cleanup()
import time
LCD_RS = 7
LCD_E = 8
LCD_D4 = 25
LCD_D5 = 24
LCD_D6 = 23
LCD_D7 = 18
LCD_CHR = True
LCD_CMD = False
# Timing constants
E_PULSE = 0.0005
E_DELAY = 0.0005
def main():
lcd_init()
while True:
# Send some test
# Send some text
# Send some text
time.sleep(3)
# Send some text
time.sleep(3)
def lcd_init():
time.sleep(E_DELAY)
# bits = data
# False for command
# High bits
if bits&0x10==0x10:
if bits&0x20==0x20:
if bits&0x40==0x40:
if bits&0x80==0x80:
lcd_toggle_enable()
# Low bits
if bits&0x01==0x01:
if bits&0x02==0x02:
if bits&0x04==0x04:
if bits&0x08==0x08:
lcd_toggle_enable()
# Toggle enable
time.sleep(E_DELAY)
time.sleep(E_PULSE)
time.sleep(E_DELAY)
try:
main()
pass
finally:
GPIO.cleanup()
