با سلام خدمت دوستان عزیز
یک برنامه نوشتم که توی اون از دستور case استفاده کردم اما بسکام سه تا ارور میده که نفهمیدم برای چیه، ممنون میشم راهنماییم کنید.
ارور هایی که میده اینه :
line32: 3parameters expected
line34: 3parameters expected
line0: end select expected
ممنون از لطفتون
$regfile = "m32def.dat" $crystal = 8000000 Config Porta = Output Config Lcdpin = Pin , Db4 = Pina.3 , Db5 = Pina.2 , Db6 = Pina.1 , Db7 = Pina.0 , Rs = Pina.4 , E = Pina.5 Config Lcd = 16 * 2 Dim A As Byte Dim A1 As Byte Dim A2 As Byte Dim T As Word Dim T1 As Byte Dim T2 As Byte Dim T3 As Byte Dim T4 As Byte Dim T5 As Byte Enable Interrupts A = 2 Do Main: Debounce Pind.4 , 1 , Per Debounce Pind.5 , 1 , Nexte Debounce Pind.6 , 1 , Exite Debounce Pind.7 , 1 , Menu If A = 3 Then A = 0 Select Case A Case A = 0 Goto N_tarikh Case A = 1: Goto N_dama Case A = 2: Goto N_trip End Select Loop Return End Per: Decr A If A = 3 Then A = 0 Return Nexte: Incr A If A = 3 Then A = 0 Return Exite: Goto N_tarikh Return Menu: Goto Tanzim Return N_tarikh: Locate 2 , 4 Lcd Date Return N_dama: Locate 2 , 6 Lcd C Return N_trip: Locate 2 , 5 Lcd T Return Do Tanzim: Debounce Pind.4 , 1 , T_per Debounce Pind.5 , 1 , T_nexte Debounce Pind.6 , 1 , T_exite Debounce Pind.7 , 1 , T_menu If A1 = 5 Then A1 = 0 Select Case A1 Case A1 = 0: Goto T_clock Case A1 = 1: Goto T_tarikh Case A1 = 2: Goto T_dama Case A1 = 3: Goto T_trip Case A1 = 4: Goto T_info End Select Loop Return T_per: Decr A1 T_nexte: Incr A1 T_exite: Goto Main T_clock: Locate 2 , 5 Lcd " clock >" T_tarikh: Locate 2 , 5 Lcd "< tarikh >" T_dama: Locate 2 , 6 Lcd "< dama >" T_trip: Locate 2 , 6 Lcd "< trip >" T_info: Locate 2 , 7 Lcd "< info " T_menu: Select A1 Case A1 = 0: Goto Clock Case A1 = 1: Goto Tarikh Case A1 = 2: Goto Dama Case A1 = 3: Goto Trip Case A1 = 4: Goto Info End Select Info: Cls Locate 1 , 2 Lcd "s.reza babaee" Locate 2 , 2 Lcd "09196648460" Trip: Cls Lcd "00000" Cursor On Blink Locate 1 , 4 Do Debounce Pind.4 , 1 , M_per Debounce Pind.5 , 1 , M_nexte Debounce Pind.6 , 1 , M_exite Debounce Pind.7 , 1 , M_menu If A2 = 5 Then A2 = 0 Select Case A2 Case A2 = 0: Mid(t , 1 , 1) = T1 Case A2 = 1: Mid(t , 2 , 1) = T2 Case A2 = 2: Mid(t , 3 , 1) = T3 Case A2 = 3 Mid(t , 4 , 1) = T3 Case A2 = 4 Mid(t , 5 , 1) = T5 M_menu: Select Case A2 Case A2 = 0: Incr T1 If T1 = 10 Then T1 = 0 Case A2 = 1: Incr T2 If T2 = 10 Then T2 = 0 Case A2 = 2: Incr T3 If T3 = 10 Then T3 = 0 Case A2 = 3: Incr T4 If T4 = 10 Then T4 = 0 Case A2 = 4: Incr T5 if T5 = 10 Then T5 = 0 M_per: Decr A2 M_nexte: Incr A2 M_exite: Goto Tanzim If A2 = 5 Then A2 = 0
ممنون از لطفتون
