لطفا کمک کنید من با EEPROM مشکل دارم
من کدو دریافت می کنم وذخیره می کنم ولی وقتی می خوام کد بعدی رو ذخیره کنم نمی تونم ببینید مشکل از کجاست لطفا کمک کنید
خیلی تو نت گشتم ولی چیزی پیدا نکردم
چرا کمک نمی کنید
$regfile = "m8def.dat"
$crystal = 8000000
$baud = 9600
Config Lcdpin = Pin , Rs = Portc.5 , E = Portc.4 , Db4 = Portb.4 , Db5 = Portb.3 , Db6 = Portb.2 , Db7 = Portb.1
Config Lcd = 16 * 2
Dim E As Byte , P As Byte
Dim C(12)as String * 1
Dim Code As String * 10
Dim A As String * 10
Dim K As String * 10
Dim B As String * 10
'Dim C As String * 11
Dim D As String * 10
Dim N As Word
Dim H As Byte
Cls
Cursor Off
Door_open Alias Pind.2 'Portd.2
'Config Portd.2 = Output
Config Pinc.2 = Input
Config Pinc.3 = Input
Declare Sub F
Declare Sub S
Do
Cls : Lcd "<<insert Card>>" : Wait 1
Step1:
Incr E
C(e) = Waitkey()
If E < 12 Then Goto Step1
For E = 3 To 12
Incr P
Mid(code , P , 1) = C(e)
Next
E = 0 : P = 0
'Cls : Lcd Code : Wait 4
'Goto F
Gosub F
Return
Loop
'F:
Sub F
'Code = " "
'Do
For N = 0 To 512 Step 65
Cls
Readeeprom B , N
If Pinc.2 = 1 Then Goto S 'Gosub S
If B = Code Then
Door_open = 1
Locate 1 , 4
Lcd "Welcome"
Locate 2 , 5
Lcd "Opened"
Wait 2
Door_open = 0
Code = "mk"
End If
Next N
Locate 2 , 4
Lcd Code
Waitms 600
'Loop
'End
End Sub
S:
K = "0000000000"
Writeeeprom K , N
Waitms 10
Next N
N = 0
H = 1
Do
Cls
Locate 1 , 4
Lcd "Save user"
Locate 2 , 1
Lcd "(" ; H ; "):" ; Code
Waitms 600
If Pinc.2 = 1 Then
Writeeeprom Code , N
Code = "Successful"
Locate 2 , 1
Waitms 2000
N = N + 65
Incr H
'Code = "next tag"
Lcd "next tag"
If H = 4 Then
Locate 2 , 1
Lcd "(" ; H ; "):" ; "Memory Full"
Waitms 3000
N = 0
H = 1
End If
End If
If Pinc.3 = 1 Then Goto Step1 '
Loop
$crystal = 8000000
$baud = 9600
Config Lcd = 16 * 2
Dim N As Word
Dim H As Byte
Cls
Cursor Off
Declare Sub F
Declare Sub S
Do
Step1:
Incr E
C(e) = Waitkey()
For E = 3 To 12
Incr P
Next
E = 0 : P = 0
'Goto F
Gosub F
Return
Loop
'F:
Sub F
'Code = " "
'Do
Cls
Readeeprom B , N
If B = Code Then
Door_open = 1
Locate 1 , 4
Lcd "Welcome"
Locate 2 , 5
Lcd "Opened"
Wait 2
Door_open = 0
Code = "mk"
End If
Next N
Locate 2 , 4
Lcd Code
Waitms 600
'Loop
'End
End Sub
S:
K = "0000000000"
Writeeeprom K , N
Waitms 10
Next N
N = 0
H = 1
Do
Cls
Locate 1 , 4
Lcd "Save user"
Locate 2 , 1
Waitms 600
If Pinc.2 = 1 Then
Code = "Successful"
Locate 2 , 1
Waitms 2000
N = N + 65
Incr H
'Code = "next tag"
Lcd "next tag"
If H = 4 Then
Locate 2 , 1
Waitms 3000
N = 0
H = 1
End If
End If
Loop
چرا کمک نمی کنید
