التماس دعا
This program was produced by the
CodeWizardAVR V2.03.3 Evaluation
Automatic Program Generator
© Copyright 1998-2008 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 2008/06/10
Author : Freeware, for evaluation and non-commercial use only
Company :
Comments:
Chip type : ATmega8
Program type : Application
Clock frequency : 1.000000 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 256
#include <mega8.h>
// Alphanumeric LCD Module functions
#asm
.equ __lcd_port=0x18 ;PORTB
#endasm
#include <lcd.h>
#include<delay.h>
#include<string.h>
//**tarife sabet baraye afzayeshe sa@
#define q PIND.0
//**tarife sabet baraye afzayeshe daghighe
#define w PIND.1
//**yekan va dahgane saniye
int s1,s2;
//**yekan va dahgane daghighe
int m1,m2;
//**yekan va dahgane sa@
int h1,h2;
//**tarife reshte baraye namayesh
char a[]="00:00:00";
//**tabee ke dar soorat estefade sa@ ra afzayesh midahad
void incr_h(void)
if (h1<0x39)
h1+=1;
else
h1=0x30;
if (h2<0x32)
h2+=1;
else
h2=0x30;
if (h2==0x32 && h1==0x34)
s1=0x30;
m1=0x30;
h1=0x30;
s2=0x30;
m2=0x30;
h2=0x30;
//**tabee ke dar soorat estefade daghighe ra afzayesh midahad
void incr_m(void)
if (m1<0x39)
m1+=1;
else
m1=0x30;
if (m2<0x35)
m2+=1;
else
m2=0x30;
void main(void)
// Port B initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTB=0x00;
DDRB=0x00;
// Port C initialization
// Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Clock source: System Clock
// Clock value: Timer 0 Stopped
TCCR0=0x00;
TCNT0=0x00;
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Timer 1 Overflow Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Clock value: Timer 2 Stopped
// Mode: Normal top=FFh
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
MCUCR=0x00;
TIMSK=0x00;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
// LCD module initialization
lcd_init(16);
//**avalin namayeshe lcd
lcd_puts(a);
//**sefr kardane hame motaghayerha ghabl az shoro barname
s1=0x30;
m1=0x30;
h1=0x30;
s2=0x30;
m2=0x30;
h2=0x30;
//**adade 30 hex barabare 0 dar kode aski ast va be hamin tartib 31 hex barabare 1 dar kode aski
while (1)
// Place your code here
//**dar sorati ke kelidi ke be pinc.0 vasl ast ke q mo'arefi shode feshar dahim q barabare sefr mishavad va sa@ yeki ziad mishavad
if (q==0)
incr_h();
//**dar sorati ke kelidi ke be pinc.1 vasl ast ke w mo'arefi shode feshar dahim w barabare sefr mishavad va daghighe yeki ziad mishavad
if (w==0)
incr_m();
if (s1<0x39)
s1+=1;
//**in halghe s1 ra ta 9 bala mibarad
else
s1=0x30;
//** s1 barabare sefr mishavad ta dar halghe badi 2bare shoro be shomaresh konad
if (s2<0x35)
s2+=1;
//**in halghe s2 ra ta 5 bala mibarad
else
s2=0x30;
//** s2 barabare sefr mishavad ta dar halghe badi 2bare shoro be shomaresh konad
if (m1<0x39)
m1+=1;
else
m1=0x30;
if (m2<0x35)
m2+=1;
else
m2=0x30;
if (h1<0x39)
h1+=1;
else
h1=0x30;
if (h2<0x32)
h2+=1;
//**chon dar sa@ 24 sa@ reset mishavad in shart ra gozashtim
s1=0x30;
m1=0x30;
h1=0x30;
s2=0x30;
m2=0x30;
h2=0x30;
//**bekhatere in ke ejraye dasturat khod zaman bar ast delay kamtar az 1s=1000ms entekhab shod
delay_ms(820);
//**adadha ra dar jaye khod migozarad
a[7]=s1;
a[6]=s2;
a[4]=m1;
a[3]=m2;
a[1]=h1;
a[0]=h2;
//**lcd ra pak karde va a jadid ra minevisad
lcd_clear();
lcd_puts(a);
[left][/left]
