با سلام خدمت تمام اساتید گل
کسی راجع به این سنسور اطلاعاتی داره ؟
آخرین قیمت روز ؟
یا حق
آخرین قیمت روز ؟
یا حق
Pin 1 GND
Pin 2 Data (PB0)
Pin 3 Serial Clock (PB1)
Pin 4 VDD (2.4V to 5.5V)
#include <mega32.h>
#include <stdio.h>
#include <delay.h>
#include <math.h>
#include <stdlib.h>
// Alphanumeric LCD Module functions
#asm
.equ __lcd_port=0x1B ;PORTB
#endasm
#include <lcd.h>
typedef union
{ unsigned int i; float f;} value;
enum {TEMP,HUMI};
sfrb PINB = 0x16;
sfrb PORTB = 0x18;
sfrb DDRB = 0x17;
#define SHT_DATA_OUT DDRB.0
#define SHT_DATA_IN PINB.0
#define SHT_SCK PORTB.1
#define noACK 0
#define ACK 1
//adr command r/w
#define STATUS_REG_W 0x06 //000 0011 0
#define STATUS_REG_R 0x07 //000 0011 1
#define MEASURE_TEMP 0x03 //000 0001 1
#define MEASURE_HUMI 0x05 //000 0010 1
#define RESET 0x1e //000 1111 0
const float C1=-4.0; // for 12 Bit
const float C2=+0.0405; // for 12 Bit
const float C3=-0.0000028; // for 12 Bit
const float T1=+0.01; // for 14 Bit @ 5V
const float T2=+0.00008; // for 14 Bit @ 5V
//SHT Functions
char SHT_WriteByte(unsigned char valuep);
char SHT_ReadByte(unsigned char ack);
void s_transstart(void);
void s_connectionreset(void);
char s_softreset(void);
char s_measure(unsigned char *p_value, unsigned char *p_checksum, unsigned char mode);
void calc_sth11(float *p_humidity ,float *p_temperature);
float calc_dewpoint(float h,float t);
unsigned char key=16,uch_TempTime_Number=0;
int intTemp1=0,intTime1=0,intTemp2=0,intTime2=0,intTemp3=0,intTime3=0;
int intTemp4=0,intTime4=0,intTemp5=0,intTime5=0,intTemp6=0,intTime6=0;
void print_temp_humy (void)
char str_hum_temp[10];
value humi_val, temp_val;
unsigned char error, checksum, status;
float dew_point;
error=0;
error+=s_measure((unsigned char*) &humi_val.i,&checksum,HUMI);
error+=s_measure((unsigned char*) &temp_val.i,&checksum,TEMP);
if(error!=0) s_connectionreset();
else{
humi_val.f=(float)humi_val.i; //converts integer to float
temp_val.f=(float)temp_val.i; //converts integer to float
calc_sth11(&humi_val.f,&temp_val.f); //calculate humidity, temperature
dew_point=calc_dewpoint(humi_val.f,temp_val.f); //calculate dew point
temp_val.f+=10;
ftoa(temp_val.f,0,str_hum_temp);
lcd_clear();
lcd_putsf("Tempreature: ");
lcd_puts(str_hum_temp);
ftoa(humi_val.f,0,str_hum_temp);
lcd_gotoxy(0,1);
lcd_putsf("Humydity: ");
void main(void)
PORTA=0x00;
DDRA=0x00;
PORTB=0x00;
DDRB=0x00;
DDRC=0x0F;
PORTC=0xF0;
DDRD=0x0F;
PORTD=0xF0;
TCCR0=0x00;
TCNT0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0x08;
TCCR2=0x05;
TCNT2=0x00;
OCR2=0x00;
//GIMSK=0x00;
MCUCR=0x00;
TIMSK=0x40;
ACSR=0x80;
// Setup Sensibus Pins
PORTB.1 = 0; // ClockLow
DDRB.1 = 1; // SCK is an output
PORTB.0 = 0; // Always Zero
// Toggle DDRB.0 for Data
// LCD module initialization
lcd_init(16);
Start:
s_softreset();
print_temp_humy();
while (1)
delay_ms(500);
print_temp_humy();
goto Start;
// tulis byte ke SHT
unsigned char i,error=0;
for (i=0x80;i>0;i/=2)
if (i & valuep) SHT_DATA_OUT=0;
else SHT_DATA_OUT=1;
SHT_SCK=1;
delay_us(5); //pulswith approx. 5 us
SHT_SCK=0;
SHT_DATA_OUT=0; //release DATA-line
SHT_SCK=1; //clk #9 for ack
error=SHT_DATA_IN; //check ack (DATA will be pulled down by SHT11)
SHT_SCK=0;
return error; //error=1 in case of no acknowledge
// baca byte dari SHT, dan berikan ACK
unsigned char i,val=0;
SHT_SCK=1;
if (SHT_DATA_IN) val=(val | i); //read bit
SHT_SCK=0;
SHT_DATA_OUT=ack; //in case of "ack==1" pull down DATA-Line
SHT_SCK=0;
return val;
// kondisi start
// _____ ________
// DATA: |_______|
// ___ ___
// SCK : ___| |___| |______
SHT_DATA_OUT=0;
SHT_SCK=0; //Initial state
delay_us(1);
SHT_SCK=1;
delay_us(1);
SHT_DATA_OUT=1;
delay_us(1);
SHT_SCK=0;
delay_us(5);
SHT_SCK=1;
delay_us(1);
SHT_DATA_OUT=0;
delay_us(1);
SHT_SCK=0;
// reset koneksi, 9 clock diikuti dengan kondisi start
// _____________________________________________________ ________
// DATA: |_______|
// _ _ _ _ _ _ _ _ _ ___ ___
// SCK : __| |__| |__| |__| |__| |__| |__| |__| |__| |______| |___| |______
unsigned char i;
SHT_DATA_OUT=0; SHT_SCK=0; //Initial state
for(i=0;i<9;i++) //9 SCK cycles
SHT_SCK=1;
delay_us(1);
SHT_SCK=0;
s_transstart(); //transmission start
// reset SHT-nya !!
unsigned char error=0;
s_connectionreset(); //reset communication
error+=SHT_WriteByte(RESET); //send RESET-command to sensor
return error; //error=1 in case of no response form the sensor
// pengukuran data
unsigned error=0;
unsigned int i;
switch(mode){ //send command to sensor
case TEMP : error+=SHT_WriteByte(MEASURE_TEMP); break;
case HUMI : error+=SHT_WriteByte(MEASURE_HUMI); break;
default : break;
for (i=0;i<65535;i++) if(SHT_DATA_IN==0) break; //wait until sensor has finished the measurement
if(SHT_DATA_IN) error+=1; // or timeout (~2 sec.) is reached
*(p_value+1) =SHT_ReadByte(ACK); //read the first byte (MSB)
*(p_value) =SHT_ReadByte(ACK); //read the second byte (LSB)
*p_checksum =SHT_ReadByte(noACK); //read checksum
return error;
// hitung temperature [°C] and humidity [%RH]
// input : humi [Ticks] (12 bit)
// temp [Ticks] (14 bit)
// output: humi [%RH]
// temp [°C]
//float rh=*p_humidity; // rh: Humidity [Ticks] 12 Bit
//float t=*p_temperature; // t: Temperature [Ticks] 14 Bit
float rh_lin; // rh_lin: Humidity linear
float rh_true; // rh_true: Temperature compensated humidity
float t_C; // t_C : Temperature [°C]
t_C=*p_temperature*0.01 - 40; //calc. temperature from ticks to [°C]
rh_lin=C3*(*p_humidity)*(*p_humidity) + C2*(*p_humidity) + C1; //calc. humidity from ticks to [%RH]
rh_true=(t_C-25)*(T1+T2*(*p_humidity))+rh_lin; //calc. temperature compensated humidity [%RH]
if(rh_true>100)rh_true=100; //cut if the value is outside of
if(rh_true<0.1)rh_true=0.1; //the physical possible range
*p_temperature=t_C; //return temperature [°C]
*p_humidity=rh_true; //return humidity[%RH]
// calculates dew point
// input: humidity [%RH], temperature [°C]
// output: dew point [°C]
float logEx,dew_point;
logEx=0.66077+7.5*t/(237.3+t)+(log10(h)-2);
dew_point = (logEx - 0.66077)*237.3/(0.66077+7.5-logEx);
return dew_point;
