کد راه اندازی ماژول تشخیص رنگ TCS3200 با بسکام
  • darban.saeed0
    • 2013/08/30
    • 28
    #1
    کد راه اندازی ماژول تشخیص رنگ tcs3200 با بسکام . با قابلیت تشخیص 10 رنگ.
    'color detector project
    'auther :saeed darban
    'date:25/11/1396
    'version:1.0.0
    'details: we detect 10 colors by using tsc3200 sensor
    'it's give us 3rgb percentege color in frequency variation
    'we shoulld calculate frequency to detect colours
    $regfile = "m16def.dat"
    $crystal = 8000000
    Config Lcd = 16 * 2
    Config Lcdpin = Pin , Db4 = Portc.3 , Db5 = Portc.2 , Db6 = Portc.1 , Db7 = Portc.0 , Rs = Portc.5 , E = Portc.4
    Config Timer1 = Timer , Prescale = 1 'for time measurment
    Stop Timer1
    Config Porta.0 = Output
    Config Portb.1 = Output
    Config Portb.2 = Output
    Config Portb.3 = Output
    Config Portb.4 = Output
    Config Pina.5 = Input
    Config Portb.6 = Output
    Tcs_output Alias Pinb.5
    Buzzer Alias Porta.0
    S0 Alias Portb.3 'scaling selector(s0,s1)
    S1 Alias Portb.4
    S2 Alias Portb.1 'color filter selectors(s2,s1)
    S3 Alias Portb.2
    Tcs_led Alias Portb.6
    Declare Sub Scaling(byval A As Byte , Byval B As Byte)
    Declare Sub Rgb_select(byval A As Byte , Byval B As Byte)
    Declare Sub Red_measure
    Declare Sub Green_measure
    Declare Sub Blue_measure
    Declare Sub Tcs_measure
    Declare Sub Clear_measure
    'Declare Sub Tcs_led_on
    'Declare Sub Tcs_led_off
    Dim A As Byte
    Dim Red As Dword
    Dim Green As Dword
    Dim Blue As Dword
    Dim Color As Dword
    Dim Object As Long
    Dim Temp1 As Dword
    Dim Temp2 As Dword
    Dim Temp3 As Dword
    Dim Smallest As Dword
    Dim _red As Dword
    Dim _green As Dword
    Dim _blue As Dword
    Dim C As Dword
    Dim R As Dword
    Dim B As Dword
    Dim G As Dword
    Dim Frequency As Dword
    Cls
    Cursor Off 'clear lcd
    'Locate 1 , 5
    'Lcd "welcome"
    'Wait 2
    'cls
    'lcd "vahid raouf "
    'wait 2
    'Cls
    'Cursor Off
    Call Scaling(0 , 1) '2% scaling
    Cls
    Lcd "put the thing"
    'Waitms 500
    B = 0
    G = 0
    R = 0
    C = 0
    Red = 0
    Blue = 0
    Green = 0
    _red = 0
    _blue = 0
    _green = 0
    Cls
    Lcd "waiting..."
    'Lowerline
    'Lcd "befor sensor"
    'Tcs_led_on
    Clear_measure 'to find an object we measure clear color and compare those
    Temp1 = C
    Waitms 100
    'Tcs_led_off
    Clear_measure 'absoulut maximum
    Temp2 = C
    Object = Temp1 - Temp2
    Object = Abs(object)
    'Lcd "temp1=" ; Temp1
    'Lowerline : Lcd "temp2=" ; Temp2
    'Lcd "o=" ; Object
    Wait 1
    If Object > 25 Then 'this value was reached from example downloaded code
    Cls
    Lcd "object found"
    Set Buzzer
    Waitms 40
    Reset Buzzer
    Waitms 20
    'Tcs_led_on
    Red_measure
    _red = R
    Blue_measure
    _blue = B
    Green_measure
    _green = G
    'Tcs_led_off
    If _red < _blue Then
    If _red < _green Then
    Smallest = _red
    Else
    Smallest = _green
    End If
    Else
    If _blue < _green Then
    Smallest = _blue
    Else
    Smallest = _green
    End If
    End If
    'scalling
    Smallest = Smallest / 10
    Red = _red / Smallest
    Green = _green / Smallest
    Blue = _blue / Smallest
    ''''''show'''
    Cls
    Lcd "r=" ; Red ; "-g=" ; Green ; "-b=" ; Blue
    '''''result colours'''''''''''''''''
    If Red > 8 And Red < 12 And Green > 12 And Green < 18 And Blue > 9 And Blue < 13 Then
    Lowerline : Lcd "result:green"
    Elseif Red > 36 And Red < 45 And Green > 8 And Green < 12 And Blue > 10 And Blue < 18 Then
    Lowerline : Lcd "result:red"
    Elseif Red > 8 And Red < 12 And Green > 20 And Green < 32 And Blue > 38 And Blue < 60 Then
    Lowerline : Lcd "result:blue"
    Elseif Red > 18 And Red < 25 And Green > 17 And Green < 22 And Blue > 8 And Blue < 14 Then
    Lowerline : Lcd "result:yellow"
    Elseif Red > 8 And Red < 12 And Green > 8 And Green < 14 And Blue > 8 And Blue < 12 Then
    Lowerline : Lcd "result:black"
    Elseif Red > 18 And Red < 30 And Green > 8 And Green < 14 And Blue > 12 And Blue < 20 Then
    Lowerline : Lcd "result:pink"
    Elseif Red > 26 And Red < 34 And Green > 9 And Green < 17 And Blue > 8 And Blue < 14 Then
    Lowerline : Lcd "resultrange"
    Elseif Red > 14 And Red < 22 And Green > 8 And Green < 14 And Blue > 8 And Blue < 14 Then
    Lowerline : Lcd "result:brown"
    Elseif Red > 14 And Red < 20 And Green > 8 And Green < 14 And Blue > 14 And Blue < 22 Then
    Lowerline : Lcd "result:violet"
    Elseif Red > 14 And Red < 20 And Green > 16 And Green < 24 And Blue > 8 And Blue < 14 Then
    Lowerline : Lcd "result:light green"
    Else
    Lowerline
    Lcd "unknown colour"
    End If
    Wait 5
    End If
    End
    Sub Red_measure
    'Cls : Lcd "red measure" : Wait 1
    Call Rgb_select(0 , 0) 'red filter
    Call Tcs_measure
    R = Frequency ' / 1000 '/1000 is just for easing the calculation because it make kilo hz to hz
    Waitms 10
    Call Tcs_measure
    R = R + Frequency ' / 1000
    Waitms 10
    Call Tcs_measure
    R = R + Frequency '/ 1000
    R = R / 3 'averaging
    'Lowerline : Lcd "r=" ; R
    'Wait 3
    'in an example code that had downloded from the internet here was r=r/3.3 (i dont know why?!!!)
    Return
    End Sub
    Sub Green_measure
    'Cls : Lcd "green measure" : Wait 1
    Call Rgb_select(1 , 1) 'green filter
    G = 0
    Call Tcs_measure
    G = Frequency ' / 1000
    Waitms 10
    Call Tcs_measure
    G = G + Frequency '/ 1000
    Waitms 10
    Call Tcs_measure
    G = G / 3
    'Lowerline : Lcd "g=" ; G
    'Wait 3
    Return
    End Sub
    Sub Blue_measure
    'Cls : Lcd "blue measure" : Wait 1
    Call Rgb_select(0 , 1)
    B = 0
    Call Tcs_measure
    B = Frequency
    Waitms 10
    Call Tcs_measure
    B = B + Frequency
    Waitms 10
    Call Tcs_measure
    B = B + Frequency
    B = B / 3 'in an example code that had downloded from the internet here was r=r/4.2 (i dont know why?!!!)
    'Lowerline : Lcd "b=" ; B
    'Wait 3
    Return
    End Sub
    Sub Clear_measure
    'Cls : Lcd "clear measure" : Wait 1
    Call Rgb_select(1 , 0) 'clear select
    C = 0
    Call Tcs_measure
    C = Frequency
    Waitms 5
    Call Tcs_measure
    C = C + Frequency
    Waitms 5
    Call Tcs_measure
    C = C + Frequency
    C = C / 3
    'Lowerline : Lcd "c=" ; C
    'Wait 3
    Return
    End Sub
    Sub Tcs_measure
    Frequency = 0
    Bitwait Tcs_output , Set
    Bitwait Tcs_output , Reset 'for debounce and sure that output is low
    Tcnt1 = 0
    Start Timer1
    Stop Timer1
    Temp3 = Tcnt1 * 2 'for earn priod
    Frequency = 8000000 / Temp3 'for earn real frequency we must multipy oscilator frequency in our measurment
    Return
    End Sub
    Sub Scaling(a As Byte , B As Byte)
    Select Case A
    Case 0 : S0 = 0
    Case 1 : S0 = 1
    End Select
    Select Case B
    Case 0 : S1 = 0
    Case 1 : S1 = 1
    End Select
    Return
    End Sub
    Sub Rgb_select(a As Byte , B As Byte)
    Select Case A
    Case 0 : S2 = 0
    Case 1 : S2 = 1
    End Select
    Select Case B
    Case 0 : S3 = 0
    Case 1 : S3 = 1
    End Select
    Return
    End Sub
  • سون سگمنت
    • 2010/09/06
    • 108
    پاسخ : کد راه اندازی ماژول تشخیص رنگ TCS3200 با بسکام
    با سلام و تشکر از شما دوست عزیز بابت برنامه خوبتون
    من اینو پروگرام کردم و مدارشو بستم ولی نمیدونم مشکلم چیه که درست کار نمیکنه
    همش رنگ قهوه ای نشون میده روی ال سی دی
    همچنین ال ای دی های ماژول فقط در لحظه اول که به مدار تغذیه میدم روشن میشن و بعدش خاموش میشن
    اگه ممکنه راهنماییم کنین ممنون میشم
