یک برنامه با ALARM برای کتابخانه ماژول ساعت DS3232RTC
    بسم الله
    کد برنامه ساعت به همراه 2 Alarm داخلی ماژول DS3231 و DS3231
    ترکیبی از example8 و example3 و کمی تغییرات از داخل کتابخانه DS3232RTC می باشد.
    کد PHP:
    // Arduino DS3232RTC Library
    // https://github.com/JChristensen/DS3232RTC
    // Copyright (C) 2018 by Jack Christensen and licensed under
    // GNU GPL v3.0, https://www.gnu.org/licenses/gpl.html
    // DS3231/DS3232 Alarm Example Sketch #8
    // Set both alarms to occur once per day at different times.
    // Configure the RTC INT/SQW pin to be asserted when alarm match occurs.
    // Detect the alarms by polling the INT/SQW pin.
    // Assumes the RTC time is already set.
    // Hardware:
    // Arduino Uno, DS3231 RTC.
    // Connect RTC SDA to Arduino pin A4.
    // Connect RTC SCL to Arduino pin A5.
    // Connect RTC INT/SQW to Arduino pin 2.
    // Jack Christensen 17Dec2018
    #include <DS3232RTC.h>        // https://github.com/JChristensen/DS3232RTC
    #include <Streaming.h> // http://arduiniana.org/libraries/streaming/
    //*******RTClib.h****
    #include "RTClib.h"
    #include "Wire.h"
    RTC_DS3231 rtc;
    //*******END_RTClib.h****
    //tabdile roz caat va daghighe be saniye
    long t_to_sec(int h, int m , long days)
    long t_to_sec = ((((days * 24) * 60) * 60) + ((h * 60) * 60) + (m * 60));
      return
    t_to_sec;
    int tA1_Hour = 0;
    int tA1_Minute = 1;
    long tA1_Day = 0;
    int tA2_Hour = 0;
    int tA2_Minute = 1;
    long tA2_Day = 0;
    const
    time_t ALARM_1_INTERVAL(t_to_sec(tA1_Hour, tA1_Minute, tA1_Day));  // alarm interval in seconds
    const time_t ALARM_2_INTERVAL(t_to_sec(tA2_Hour, tA2_Minute, tA2_Day));  // alarm interval in seconds
    // pin definitions
    const uint8_t RTC_INT_PIN(2);
    // current time from the RTC in text format
    char timestamp[32];
    void setup()
    Serial.begin(115200);
    if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
        while (
    1);
      if (
    rtc.lostPower()) {
    Serial.println("RTC lost power, lets set the time!");
    // If the RTC have lost power it will sets the RTC to the date & time this sketch was compiled in the following line
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
    // If you need to set the time of the uncomment line 34 or 37
      // following line sets the RTC to the date & time this sketch was compiled
       //rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
      // This line sets the RTC with an explicit date & time, for example to set
      // January 21, 2014 at 3am you would call:
       //rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
    delay(1000);
    Serial << F( "\n" __FILE__ " " __DATE__ " " __TIME__ "\n" );
    pinMode(RTC_INT_PIN, INPUT_PULLUP);
    // initialize the alarms to known values, clear the alarm flags, clear the alarm interrupt flags
    RTC.setAlarm(ALM1_MATCH_DATE, 0, 0, 0, 1);
    RTC.setAlarm(ALM2_MATCH_DATE, 0, 0, 0, 1);
    RTC.alarm(ALARM_1);
    RTC.alarm(ALARM_2);
    RTC.alarmInterrupt(ALARM_1, false);
    RTC.alarmInterrupt(ALARM_2, false);
    RTC.squareWave(SQWAVE_NONE);
    // print the current time
    time_t t = RTC.get();
    formatTime(timestamp, t);
    Serial << millis() << F(" Current RTC time ") << timestamp << endl;
    // set alarm 1 to occur in ?
      // set alarm 2 to occur in ?
    tmElements_t tm;
    breakTime(t + 60 , tm);
    //tm.Hour = 00;                   // set the RTC to an arbitrary time
      //tm.Minute = 00;
    tm.Second = 00;
    time_t a1 = makeTime(tm) + ALARM_1_INTERVAL ;   // calculate the alarm time
    time_t a2 = makeTime(tm) + ALARM_2_INTERVAL;    // calculate the alarm time
    formatTime(timestamp, a1);
    timestamp[17] = 0;                   // keep just hh:mm weekday DD MM
    Serial << F("A1:") << timestamp << endl;
    formatTime(timestamp, a2);
    Serial << F("A2:") << timestamp << endl;
    RTC.setAlarm(ALM1_MATCH_DATE, minute(a1), hour(a1), day(a1));
    RTC.alarm(ALARM_1);                 // ensure RTC interrupt flag is cleared
    RTC.alarmInterrupt(ALARM_1, true);
    RTC.setAlarm(ALM2_MATCH_DATE, minute(a2), hour(a2), day(a2));
    RTC.alarm(ALARM_2);                 // ensure RTC interrupt flag is cleared
    RTC.alarmInterrupt(ALARM_2, true);
    void loop()
    DateTime now = rtc.now();
    char buffer1[] = "hh:mm:ss";
    Serial.print(now.toString(buffer1));
    char buffer2[] = " DDD ";
    Serial.print(now.toString(buffer2));
    char buffer3[] = "YYYY-MM-DD";
    Serial.print(now.toString(buffer3));
    Serial.print(" Temp:");
    Serial.print(rtc.getTemperature());
    Serial.println("C");
    delay(1000);
      // check to see if the INT/SQW pin is low, i.e. an alarm has occurred
    if (!digitalRead(RTC_INT_PIN))
    formatTime(timestamp, RTC.get());   // get current RTC time
    if (RTC.alarm(ALARM_1))             // resets the alarm flag if set
    Serial <<  F(" Alarm1 Fired at:") << timestamp << endl;
    // get the current time
    // calculate the next alarm time
    time_t a1 = t + ALARM_1_INTERVAL;
    // set the alarm
    RTC.setAlarm(ALM1_MATCH_DATE, second(a1), minute(a1), hour(a1), day(a1));
        if (
    RTC.alarm(ALARM_2))
    Serial << millis() << F(" Alarm2 Fired at:") << timestamp << endl;
    time_t a2 = t + ALARM_2_INTERVAL;
    // set the alarm
    RTC.setAlarm(ALM2_MATCH_DATE, second(a2), minute(a2), hour(a2), day(a2));
    // format a time_t value, return the formatted string in buf (must be at least 25 bytes)
    void formatTime(char *buf, time_t t)
    char m[4];    // temporary storage for month string (DateStrings.cpp uses shared buffer)
    strcpy(m, monthShortStr(month(t)));
    sprintf(buf, "%.2d:%.2d:%.2d %s%.2d%s %d",
    hour(t), minute(t), second(t),  dayShortStr(weekday(t)), day(t), m, year(t));
    جدیدترین ویرایش توسط حمید حمید; 2020/04/08, 09:02.
    پاسخ : یک برنامه با ALARM برای کتابخانه ماژول ساعت DS3232RTC
    LCD کاراکتری 20x4 با رابط I2C به کد برنامه اضافه شد.
    بعلاوه 2 عدد رله که در زمان Alarm ها وصل میشود.
    کد PHP:
    #include <EEPROM.h>
    #include "RTClib.h"
    #include "Wire.h"
    RTC_DS3231 rtc;
    #include <AnalogButtons.h>
    #define ANALOG_PIN A1
    #include <Wire.h>
    #include <LiquidCrystal_I2C.h>
    // Set the LCD address to 0x27 for a 20 chars and 4 line display
    LiquidCrystal_I2C lcd(0x3F, 20, 4);
    // pin definitions
    #define Input1 A1
    #define Input2 A2
    #define Output1 8
    #define Output2 7
    boolean key = 0;
    int _hour, _minute;
    int _year, _month, _day;
    boolean key_SET = 1 , key_DOWN = 1, key_UP = 1;
    // pin definitions
    const uint8_t RTC_INT_PIN(10);  //connected to SQW PIN of DS3231
    char timestamp[32];
    char timestamp2[32];
    // A call back function that you pass into the constructor of AnalogButtons, see example
    // below. Alternativly you could extend the Button class and re-define the methods pressed()
    // or held() which are called
    void b1Click() {
    ////Serial.println("button 1 clicked");
    void b1Hold() {
    //Serial.println("button 1 held");
    key_SET = 0;
    void b2Click() {
    //Serial.println("button 2 clicked");
    void b2Hold() {
    //Serial.println("button 2 held");
    void b3Click() {
    //Serial.println("button 3 clicked");
    key_DOWN = 0;
    lcd.clear();
    void b3Hold() {
    //Serial.println("button 3 held");
    key_DOWN = 0;
    void b4Click() {
    //Serial.println("button 4 clicked");
    key_UP = 0;
    lcd.clear();
    void b4Hold() {
    //Serial.println("button 4 held");
    key_UP = 0;
    AnalogButtons analogButtons(ANALOG_PIN, INPUT);
    Button b1 = Button(595, &b1Click, &b1Hold, 1000, 2500);
    Button b2 = Button(839, &b2Click, &b2Hold);
    Button b3 = Button(777, &b3Click, &b3Hold, 500, 25);
    // Default hold activation frequency of 250ms is overriden for button 4 so to
    // get it activated (hold function invoked) only every 500ms
    Button b4 = Button(888, &b4Click, &b4Hold, 500, 25);
      return
    t_to_sec;
    long A1_day = EEPROM.read(20);
    int A1_hour = EEPROM.read(25);
    int A1_minute = EEPROM.read(30);
    long A1_delay = EEPROM.get(35,  A1_delay);
    long A2_day = EEPROM.read(40);
    int A2_hour = EEPROM.read(45);
    int A2_minute = EEPROM.read(50);
    long A2_delay = EEPROM.get(55,  A2_delay);
    const
    time_t ALARM_1_INTERVAL(t_to_sec(A1_hour, A1_minute, A1_day));  // alarm interval in seconds
    const time_t ALARM_2_INTERVAL(t_to_sec(A2_hour, A2_minute, A2_day));  // alarm interval in seconds
    void setup()
    //Serial.begin(115200);
    pinMode(Output1, OUTPUT);
    pinMode(Output2, OUTPUT);
    digitalWrite(Output1, HIGH);
    digitalWrite(Output2, HIGH);
    //Serial.println("Couldn't find RTC");
    while (1);
      if (
    rtc.lostPower()) {
    //Serial.println("RTC lost power, lets set the time!");
    // only If you need to set the time    uncomment line 1 or 2
      // April 21, 2020 at 23pm you would call:
      //rtc.adjust(DateTime(2020, 4, 21, 23, 59, 59));
    analogButtons.add(b1);
    analogButtons.add(b2);
    analogButtons.add(b3);
    analogButtons.add(b4);
    lcd.begin();
    lcd.clear();
    lcd.setCursor(0, 0);
    lcd.print("*Hamid Samadi 99*");
    lcd.setCursor (0, 1);
    lcd.print(">Arduino Pro CLOCK");
    delay(3000);
    lcd.clear();
    delay(1000);
    //Serial << F( "\n" __FILE__ " " __DATE__ " " __TIME__ "\n" );
    //Serial.print("A1_delay:");
      //Serial.println(A1_delay);
      //Serial.println(A2_delay);
    RTC.alarm(ALARM_1);
    RTC.alarm(ALARM_2);
    //Serial << millis() << F(" Current RTC time ") << timestamp << endl;
    tmElements_t tm;
      //tm.Minute = 00;
    tm.Second = 00;
      //Serial << F("A1:") << timestamp << endl;
    lcd.setCursor (0, 2);
    lcd.print("A1:");
    lcd.print(timestamp);
    formatTime(timestamp2, a2);
    timestamp2[17] = 0;                  // keep just hh:mm weekday DD MM
      //Serial << F("A2:") << timestamp2 << endl;
    lcd.setCursor (0, 3);
    lcd.print("A2:");
    lcd.print(timestamp2);
    void loop()
    char buffer4[] = "hh:mm:ss";
    //Serial.println(now.toString(buffer4));
    delay(1000);
      // To check values when button are pressed
    analogButtons.check();
    // calculate a date which is 7 days and 30 seconds into the future
      //DateTime future (now + TimeSpan(7,12,30,6));
    lcd.print(now.toString(buffer1));
    lcd.setCursor(10, 0);
    lcd.print(rtc.getTemperature());
    lcd.print("\337");
    lcd.setCursor(0, 1);
    char buffer3[] = "YYYY/MM/DD";
    lcd.print(now.toString(buffer3));
    //lcd.print("  ");
    char buffer2[] = " [DDD]";
    lcd.print(now.toString(buffer2));
    lcd.print("A1:");
    lcd.print("A2:");
      if (
    key == 0 && key_SET == 0 && key_DOWN == 1 && key_UP == 1) {
    key_SET = 1;
    key = 1;
    _hour = now.hour();
    _minute = now.minute();
    _year = now.year();
    _month = now.month();
    _day = now.day();
    SET_hour();
      if (
    key == 1 && key_SET == 1 && key_DOWN == 1 && key_UP == 1) {
    key = 0;
        if (
    //formatTime(timestamp, RTC.get());   // get current RTC time
    lcd.clear();
    lcd.print("A1 Fired: ");
    lcd.print("Relay1 is on ");
    digitalWrite(Output1, LOW);
    //Serial <<  F(" Alarm1 Fired:")  << endl;
    // set the alarm
          //Serial << F("NEXT A1:") << timestamp << endl;
    lcd.print("A1:");
    delay((A1_delay * 1000) * 60);
    lcd.clear();
        if (
    RTC.alarm(ALARM_2))
    //formatTime(timestamp2, RTC.get());   // get current RTC time
    lcd.clear();
    lcd.print("A2 Fired: ");
    lcd.print("Relay2 is on ");
    digitalWrite(Output2, LOW);
    //Serial << F(" Alarm2 Fired:")  << endl;
    // set the alarm
          //Serial << F("NEXT A2:") << timestamp2 << endl;
    lcd.print("A2:");
    delay((A2_delay * 1000) * 60);
    lcd.clear();
    /*switch (show) {
        // case 0:
        //   break;
        //case 1:
        //break;
        //case 2:
        // break;
        // default:;
    void SET_hour() {
    lcd.clear();
      while (
    1) {
    lcd.print(">SET Hour");
    lcd.print("Hour  = ");
    lcd.print(_hour);
        if (
    key == 0 && key_SET == 1 && key_DOWN == 0 && key_UP == 1) {
    key_DOWN = 1;
    key = 1;
          if (
    _hour == 0) {
    _hour = 23;
          } else {
    _hour--;
        if (
    key == 0 && key_SET == 1 && key_DOWN == 1 && key_UP == 0) {
    key_UP = 1;
    key = 1;
          if (
    _hour == 23) {
    _hour = 0;
          } else {
    _hour++;
        if (
    key_SET = 1;
    key = 1;
          break;
        if (
    key = 0;
    SET_minute();
    //*********************************************Subprogram SET_minute()
    void SET_minute() {
    lcd.clear();
      while (
    1) {
    lcd.print(">SET Minute");
    lcd.print("Minute= ");
    lcd.print(_minute);
        if (
    key_DOWN = 1;
    key = 1;
          if (
    _minute == 0) {
    _minute = 59;
          } else {
    _minute--;
        if (
    key_UP = 1;
    key = 1;
          if (
    _minute == 59) {
    _minute = 0;
          } else {
    _minute++;
        if (
    key_SET = 1;
    key = 1;
          break;
        if (
    key = 0;
    SET_year();
    //*********************************************Subprogram SET_year()
    void SET_year() {
    lcd.clear();
      while (
    1) {
    lcd.print(">SET Year");
    lcd.print("Year  = ");
    lcd.print(_year);
        if (
    key_DOWN = 1;
    key = 1;
          if (
    _year == 2014) {
    _year = 2030;
          } else {
    _year--;
        if (
    key_UP = 1;
    key = 1;
          if (
    _year == 2030) {
    _year = 2014;
          } else {
    _year++;
        if (
    key_SET = 1;
    key = 1;
          break;
        if (
    key = 0;
    SET_month();
    //*********************************************Subprogram SET_month()
    void SET_month() {
    lcd.clear();
      while (
    1) {
    lcd.print(">SET Month");
    lcd.print("Month = ");
    lcd.print(_month);
        if (
    key_DOWN = 1;
    key = 1;
          if (
    _month == 1) {
    _month = 12;
          } else {
    _month--;
        if (
    key_UP = 1;
    key = 1;
          if (
    _month == 12) {
    _month = 1;
          } else {
    _month++;
        if (
    key_SET = 1;
    key = 1;
          break;
        if (
    key = 0;
    SET_day();
    //*********************************************Subprogram SET_day()
    void SET_day() {
    lcd.clear();
      while (
    1) {
    lcd.print(">SET Day");
    lcd.print("Day   = ");
    lcd.print(_day);
        if (
    key_DOWN = 1;
    key = 1;
          if (
    _day == 1) {
    _day = 31;
          } else {
    _day--;
        if (
    key_UP = 1;
    key = 1;
          if (
    _day == 31) {
    _day = 1;
          } else {
    _day++;
        if (
    key_SET = 1;
    key = 1;
          break;
        if (
    key = 0;
    SET_Alarm1_day();
    //*********************************************Subprogram SET_Alarm1_day()
    void SET_Alarm1_day() {
    lcd.clear();
      while (
    1) {
    lcd.print("SET A1 Every Few Day");
    lcd.print(A1_day);
        if (
    key_DOWN = 1;
    key = 1;
          if (
    A1_day == 0) {
    A1_day = 31;
          } else {
    A1_day--;
        if (
    key_UP = 1;
    key = 1;
          if (
    A1_day == 31) {
    A1_day = 0;
          } else {
    A1_day++;
        if (
    key_SET = 1;
    key = 1;
          break;
        if (
    key = 0;
    SET_Alarm1_hour();
    //*********************************************Subprogram SET_Alarm1_hour()
    void SET_Alarm1_hour() {
    lcd.clear();
      while (
    1) {
    lcd.print(">SET A1 Match Hour");
    lcd.print(A1_hour);
        if (
    key_DOWN = 1;
    key = 1;
          if (
    A1_hour == 0) {
    A1_hour = 23;
          } else {
    A1_hour--;
        if (
    key_UP = 1;
    key = 1;
          if (
    A1_hour == 23) {
    A1_hour = 0;
          } else {
    A1_hour++;
        if (
    key_SET = 1;
    key = 1;
          break;
        if (
    key = 0;
    SET_Alarm1_minute();
    //*********************************************Subprogram SET_Alarm1_minute()
    void SET_Alarm1_minute() {
    lcd.clear();
      while (
    1) {
    lcd.print(">SET A1 Match Minute");
    lcd.print(A1_minute);
        if (
    key_DOWN = 1;
    key = 1;
          if (
    A1_minute == 0) {
    A1_minute = 59;
          } else {
    A1_minute--;
        if (
    key_UP = 1;
    key = 1;
          if (
    A1_minute == 59) {
    A1_minute = 0;
          } else {
    A1_minute++;
        if (
    key_SET = 1;
    key = 1;
          break;
        if (
    key = 0;
    SET_Alarm1_delay();
    //*********************************************Subprogram SET_Alarm1_delay()
    void SET_Alarm1_delay() {
    lcd.clear();
      while (
    1) {
    lcd.print(">SET A1 Amount Delay");
    lcd.print("Delay = ");
    lcd.print(A1_delay);
    lcd.setCursor (12, 1);
    lcd.print("*Minute");
        if (
    key_DOWN = 1;
    key = 1;
          if (
    A1_delay == 1) {
    A1_delay = 360;
          } else {
    A1_delay--;
        if (
    key_UP = 1;
    key = 1;
          if (
    A1_delay == 360) {
    A1_delay = 1;
          } else {
    A1_delay++;
        if (
    key_SET = 1;
    key = 1;
          break;
        if (
    key = 0;
    SET_Alarm2_day();
    //*********************************************Subprogram SET_Alarm2_day()
    void SET_Alarm2_day() {
    lcd.clear();
      while (
    1) {
    lcd.print("SET A2 Every Few Day");
    lcd.print(A2_day);
        if (
    key_DOWN = 1;
    key = 1;
          if (
    A2_day == 0) {
    A2_day = 31;
          } else {
    A2_day--;
        if (
    key_UP = 1;
    key = 1;
          if (
    A2_day == 31) {
    A2_day = 0;
          } else {
    A2_day++;
        if (
    key_SET = 1;
    key = 1;
          break;
        if (
    key = 0;
    SET_Alarm2_hour();
    //*********************************************Subprogram SET_Alarm2_hour()
    void SET_Alarm2_hour() {
    lcd.clear();
      while (
    1) {
    lcd.print(">SET A2 Match Hour");
    lcd.print(A2_hour);
        if (
    key_DOWN = 1;
    key = 1;
          if (
    A2_hour == 0) {
    A2_hour = 23;
          } else {
    A2_hour--;
        if (
    key_UP = 1;
    key = 1;
          if (
    A2_hour == 23) {
    A2_hour = 0;
          } else {
    A2_hour++;
        if (
    key_SET = 1;
    key = 1;
          break;
        if (
    key = 0;
    SET_Alarm2_minute();
    //*********************************************Subprogram SET_Alarm2_minute()
    void SET_Alarm2_minute() {
    lcd.clear();
      while (
    1) {
    lcd.print(">SET A2 Match Minute");
    lcd.print(A2_minute);
        if (
    key_DOWN = 1;
    key = 1;
          if (
    A2_minute == 0) {
    A2_minute = 59;
          } else {
    A2_minute--;
        if (
    key_UP = 1;
    key = 1;
          if (
    A2_minute == 59) {
    A2_minute = 0;
          } else {
    A2_minute++;
        if (
    key_SET = 1;
    key = 1;
          break;
        if (
    key = 0;
    SET_Alarm2_delay();
    //*********************************************Subprogram SET_Alarm2_delay()
    void SET_Alarm2_delay() {
    lcd.clear();
      while (
    1) {
    lcd.print(">SET A2 Amount Delay");
    lcd.print(A2_delay);
    lcd.print(" *Minute");
        if (
    key_DOWN = 1;
    key = 1;
          if (
    A2_delay == 1) {
    A2_delay = 360;
          } else {
    A2_delay--;
        if (
    key_UP = 1;
    key = 1;
          if (
    A2_delay == 360) {
    A2_delay = 1;
          } else {
    A2_delay++;
        if (
    key_SET = 1;
    key = 1;
          break;
        if (
    key = 0;
    Save();
    //*********************************************Subprogram Save()
    void Save() {
    lcd.clear();
    lcd.print(">    Save...    ");
    lcd.print("*Zakhire Tanzimat*");
    EEPROM.write(20, A1_day);
    EEPROM.write(25, A1_hour);
    EEPROM.write(30, A1_minute);
    EEPROM.put(35,  A1_delay);
    EEPROM.write(40, A2_day);
    EEPROM.write(45, A2_hour);
    EEPROM.write(50, A2_minute);
    EEPROM.put(55, A2_delay);
    // set the alarm
    //////formatTime(timestamp, a1);
      //////Serial << F("A1:") << timestamp << endl;
    // set the alarm
    //////formatTime(timestamp2, a2);
      //////Serial << F("A2:") << timestamp2 << endl;
      if (
    DateTime(_year, _month, _day, _hour, _minute, 0) > DateTime(now))
    rtc.adjust(DateTime(_year, _month, _day, _hour, _minute, 0));
    delay(2000);
    lcd.clear();
    جدیدترین ویرایش توسط حمید حمید; 2020/04/12, 22:18. دلیل: تکمیل و رفع چند ایراد کد
      بسم الله
      به کدفوق ، سنسور دما و رطوبت AM2302 با قابلیت کنترل دما و رطوبت اضافه شد.
      نکته:کد روی میکروکنترلر بر پایه ATmega32u4 اجرا می شود.
      کد PHP:
      #include <EEPROM.h>
      #include "RTClib.h"
      #include "Wire.h"
      RTC_DS3231 rtc;
      #include <AnalogButtons.h> //https://github.com/rlogiacco/AnalogButtons
      #include <Wire.h>
      #include <LiquidCrystal_I2C.h>  //https://github.com/fdebrabander/Arduino-LiquidCrystal-I2C-library
      // Set the LCD address to 0x27 or 0x3F for a 20 chars and 4 line display
      // pin definitions
      //#define Input1 A3
      //#define Input2 A4
      #define RELAY_Temp1 8
      #define RELAY_Hum2 7
      boolean key = 0;
      int _hour, _minute;
      boolean key_SET = 1 , key_SET2 = 1 , key_DOWN = 1, key_UP = 1;
      int show = 0;
      // pin definitions
      char timestamp[32];
      void b1Click() {
      show = 0;
      lcd.clear();
      void b1Hold() {
      key_SET = 0;
      void b2Click() {
      show = 1;
      lcd.clear();
      void b2Hold() {
      key_SET2 = 0;
      void b3Click() {
      key_DOWN = 0;
      lcd.clear();
      void b3Hold() {
      key_DOWN = 0;
      void b4Click() {
      key_UP = 0;
      lcd.clear();
      void b4Hold() {
      key_UP = 0;
      Button b1 = Button(692, &b1Click, &b1Hold, 2500, 2500);
      Button b2 = Button(857, &b2Click, &b2Hold, 2500, 2500);
      Button b3 = Button(880, &b3Click, &b3Hold, 500, 200);
      Button b4 = Button(904, &b4Click, &b4Hold, 500, 200);
        return
      t_to_sec;
      #include "DHT.h"
      #define DHTPIN A0
      #define DHTTYPE DHT22
      DHT dht(DHTPIN, DHTTYPE);
      const
      float temp, hum, hic;
      boolean temperaturestate = EEPROM.get(80, temperaturestate);
      boolean humiditystate = EEPROM.get(85, humiditystate);
      float mintemp = EEPROM.get(90, mintemp);
      float maxtemp =  EEPROM.get(95, maxtemp);
      float  minhum =  EEPROM.get(100, minhum);
      float maxhum = EEPROM.get(105,  maxhum);
      void setup()
      dht.begin();
      pinMode(RELAY_Temp1, OUTPUT);
      pinMode(RELAY_Hum2, OUTPUT);
      digitalWrite(RELAY_Temp1, HIGH);
      digitalWrite(RELAY_Hum2, HIGH);
      while (1);
        if (
      rtc.lostPower()) {
      // 1>only If you need to set the time    uncomment line 3 or 6
        // 2>following line sets the RTC to the date & time this sketch was compiled
        // 4>This line sets the RTC with an explicit date & time, for example to set
        // 5>April 21, 2020 at 23pm you would call:
      lcd.begin();
      lcd.clear();
      delay(2000);
      lcd.clear();
      delay(300);
      RTC.alarm(ALARM_1);
      RTC.alarm(ALARM_2);
      //formatTime(timestamp, t);
      time_t a1 = EEPROM.get(60, a1); ;   // calculate the alarm time
      //timestamp[17] = 0;                   // keep just hh:mm weekday DD MM
      RTC.alarmInterrupt(ALARM_1, true);  //faal kardane zang
      time_t a2 = EEPROM.get(65, a2);;    // calculate the alarm time
      //timestamp2[17] = 0;                  // keep just hh:mm weekday DD MM
      RTC.alarmInterrupt(ALARM_2, true);  //faal kardane zang
      void loop()
        if (
      show == 0) {
      lcd.print("\337");
      lcd.print("A1:");
      timestamp[17] = 0;
      lcd.print("A2:");
      timestamp2[17] = 0;
          if (
      key_SET = 1;
      key = 1;
      _hour = now.hour();
      _year = now.year();
      _day = now.day();
      SET_hour();
          if (
      key = 0;
      } else {
      temp = dht.readTemperature();
      lcd.print("Temp:");
      lcd.print(temp, 1);
      lcd.print("\337");
          if (
      mintemp == maxtemp || !temperaturestate ) {
      lcd.print("  OFF!");
          if (
      mintemp != maxtemp && mintemp > maxtemp ) {
      //Cooling mode system
      if (temp > mintemp && temperaturestate) {
      lcd.print(" Too warm");
            if (
      temp < mintemp && temp > maxtemp && temperaturestate) {
      lcd.print(" Cooling");
            if (
      temp < maxtemp && temperaturestate) {
      lcd.print(" Too cool");
          if (
      mintemp != maxtemp && mintemp < maxtemp) {
      //Heating mode system
      if (temp < mintemp && temperaturestate) {
            if (
      temp > mintemp && temp < maxtemp && temperaturestate) {
      lcd.print(" Heating");
            if (
      lcd.print("TMin<");
      lcd.print(mintemp, 1);
      lcd.print("  TMax<");
      lcd.print(maxtemp, 1);
      hum = dht.readHumidity();
      lcd.setCursor(0, 2);
      lcd.print("Hum :");
      lcd.print(hum, 1);
      lcd.print("%");
          if (
      minhum == maxhum || !humiditystate ) {
      lcd.print("  OFF!");
          if (
      minhum != maxhum && minhum > maxhum ) {
      //Dehumidification mode system
      if (hum > minhum && humiditystate) {
      lcd.print(" Too humid");
            if (
      hum < minhum && hum > maxhum && humiditystate) {
      lcd.print(" Dehumidif");
            if (
      hum < maxhum && humiditystate) {
      lcd.print(" Too dry");
          if (
      minhum != maxhum && minhum < maxhum) {
      //Humidification mode system
      if (hum < minhum && humiditystate) {
            if (
      hum > minhum && hum < maxhum && humiditystate) {
      lcd.print(" Humidific");
            if (
      lcd.setCursor(0, 3);
      lcd.print("HMin<");
      lcd.print(minhum, 1);
      lcd.print("  HMax<");
      lcd.print(maxhum, 1);
      //Heat index= mohasebe dama ba tavajoh be rotobat
          //hic = dht.computeHeatIndex(temp, hum, false);
          //Serial.print(F("Heat  index: "));
          //Serial.print(hic);
          //Serial.println(F("°C "));
          //Serial.print(F("Temperature: "));
          //Serial.print(temp, 1);
          //Serial.println(F(" °C"));
          //Serial.print(F("Humidity: "));
          //Serial.print(hum, 1);
          //Serial.println(F("%"));
          //Serial.println("-----------------------");
      if (key == 0 && key_SET2 == 0 && key_DOWN == 1 && key_UP == 1) {
      key_SET2 = 1;
      key = 1;
      SET_systemp();
          if (
      key == 1 && key_SET2 == 1 && key_DOWN == 1 && key_UP == 1) {
      key = 0;
      TempRelay();
      HumRelay();
          if (
      //Serial <<  F(" Alarm1 Fired")  << endl;
      lcd.clear();
      digitalWrite(RELAY_Temp1, LOW);
      //tanzim caat be 00:00:00 be jahate match shodane ba time alarm
      tmElements_t tm;
      breakTime(t  , tm);
      tm.Minute = 00;
      tm.Second = 00;
      time_t a1 = makeTime(tm) + ALARM_1_INTERVAL;
      EEPROM.put(60, a1);
      // set the alarm
      lcd.print("A1:");
      lcd.clear();
          if (
      RTC.alarm(ALARM_2))
      lcd.clear();
      digitalWrite(RELAY_Hum2, LOW);
      //Serial << F(" Alarm2 Fired")  << endl;
      tmElements_t tm;
      breakTime(t  , tm);
      tm.Minute = 00;
      tm.Second = 00;
      EEPROM.put(65, a2);
      // set the alarm
      lcd.print("A2:");
      lcd.clear();
      configure();
      void configure() {
      unsigned int value = analogRead(ANALOG_PIN);
      //Serial.println(value);
      delay(250);
      //*********************************************Subprogram SET_hour()
      void SET_hour() {
      lcd.clear();
        while (
      1) {
      lcd.print(_hour);
          if (
      key_DOWN = 1;
      key = 1;
            if (
      _hour == 0) {
      _hour = 23;
            } else {
      _hour--;
          if (
      key_UP = 1;
      key = 1;
            if (
      _hour == 23) {
      _hour = 0;
            } else {
      _hour++;
          if (
      key_SET = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_minute();
      void SET_minute() {
      lcd.clear();
        while (
      1) {
      lcd.print(_minute);
          if (
      key_DOWN = 1;
      key = 1;
            if (
      _minute == 0) {
      _minute = 59;
            } else {
      _minute--;
          if (
      key_UP = 1;
      key = 1;
            if (
      _minute == 59) {
      _minute = 0;
            } else {
      _minute++;
          if (
      key_SET = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_year();
      void SET_year() {
      lcd.clear();
        while (
      1) {
      lcd.print(_year);
          if (
      key_DOWN = 1;
      key = 1;
            if (
      _year == 2015) {
      _year = 2030;
            } else {
      _year--;
          if (
      key_UP = 1;
      key = 1;
            if (
      _year == 2030) {
      _year = 2015;
            } else {
      _year++;
          if (
      key_SET = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_month();
      void SET_month() {
      lcd.clear();
        while (
      1) {
      lcd.print(_month);
          if (
      key_DOWN = 1;
      key = 1;
            if (
      _month == 1) {
      _month = 12;
            } else {
      _month--;
          if (
      key_UP = 1;
      key = 1;
            if (
      _month == 12) {
      _month = 1;
            } else {
      _month++;
          if (
      key_SET = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_day();
      void SET_day() {
      lcd.clear();
        while (
      1) {
      lcd.print(_day);
          if (
      key_DOWN = 1;
      key = 1;
            if (
      _day == 1) {
      _day = 31;
            } else {
      _day--;
          if (
      key_UP = 1;
      key = 1;
            if (
      _day == 31) {
      _day = 1;
            } else {
      _day++;
          if (
      key_SET = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_Alarm1_day();
      lcd.clear();
        while (
      1) {
      lcd.print(A1_day);
          if (
      key_DOWN = 1;
      key = 1;
            if (
      A1_day == 1) {
      A1_day = 31;
            } else {
      A1_day--;
          if (
      key_UP = 1;
      key = 1;
            if (
      A1_day == 31) {
      A1_day = 1;
            } else {
      A1_day++;
          if (
      key_SET = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_Alarm1_hour();
      lcd.clear();
        while (
      1) {
      lcd.print(A1_hour);
          if (
      key_DOWN = 1;
      key = 1;
            if (
      A1_hour == 0) {
      A1_hour = 23;
            } else {
      A1_hour--;
          if (
      key_UP = 1;
      key = 1;
            if (
      A1_hour == 23) {
      A1_hour = 0;
            } else {
      A1_hour++;
          if (
      key_SET = 1;
      key = 1;
            break;
          if (
      key = 0;
      lcd.clear();
        while (
      1) {
          if (
      key_DOWN = 1;
      key = 1;
            if (
      A1_minute == 0) {
      A1_minute = 59;
            } else {
      A1_minute--;
          if (
      key_UP = 1;
      key = 1;
            if (
      A1_minute == 59) {
      A1_minute = 0;
            } else {
      A1_minute++;
          if (
      key_SET = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_Alarm1_delay();
      lcd.clear();
        while (
      1) {
          if (
      key_DOWN = 1;
      key = 1;
            if (
      A1_delay == 0) {
      A1_delay = 1400;
            } else {
      A1_delay--;
          if (
      key_UP = 1;
      key = 1;
            if (
      A1_delay == 1400) {
      A1_delay = 0;
            } else {
      A1_delay++;
          if (
      key_SET = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_Alarm2_day();
      lcd.clear();
        while (
      1) {
      lcd.print(A2_day);
          if (
      key_DOWN = 1;
      key = 1;
            if (
      A2_day == 1) {
      A2_day = 31;
            } else {
      A2_day--;
          if (
      key_UP = 1;
      key = 1;
            if (
      A2_day == 31) {
      A2_day = 1;
            } else {
      A2_day++;
          if (
      key_SET = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_Alarm2_hour();
      lcd.clear();
        while (
      1) {
      lcd.print(A2_hour);
          if (
      key_DOWN = 1;
      key = 1;
            if (
      A2_hour == 0) {
      A2_hour = 23;
            } else {
      A2_hour--;
          if (
      key_UP = 1;
      key = 1;
            if (
      A2_hour == 23) {
      A2_hour = 0;
            } else {
      A2_hour++;
          if (
      key_SET = 1;
      key = 1;
            break;
          if (
      key = 0;
      lcd.clear();
        while (
      1) {
          if (
      key_DOWN = 1;
      key = 1;
            if (
      A2_minute == 0) {
      A2_minute = 59;
            } else {
      A2_minute--;
          if (
      key_UP = 1;
      key = 1;
            if (
      A2_minute == 59) {
      A2_minute = 0;
            } else {
      A2_minute++;
          if (
      key_SET = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_Alarm2_delay();
      lcd.clear();
        while (
      1) {
          if (
      key_DOWN = 1;
      key = 1;
            if (
      A2_delay == 0) {
      A2_delay = 1400;
            } else {
      A2_delay--;
          if (
      key_UP = 1;
      key = 1;
            if (
      A2_delay == 1400) {
      A2_delay = 0;
            } else {
      A2_delay++;
          if (
      key_SET = 1;
      key = 1;
            break;
          if (
      key = 0;
      Save();
      void Save() {
      lcd.clear();
      tmElements_t tm;
      breakTime(t  , tm);
      tm.Minute = 00;
      tm.Second = 00;
      // set the alarm
      // set the alarm
        if (
      EEPROM.put(60, a1);
      EEPROM.put(65, a2);
      delay(2000);
      lcd.clear();
      //*********************************************Subprogram SET_SystemTemp()
      void SET_systemp() {
      lcd.clear();
        while (
      1) {
      lcd.print(">SET System Temp");
      lcd.print("System Temp  = ");
          if (
      temperaturestate) {
      lcd.print("ON");
          } else {
      lcd.print("OFF");
          if (
      key == 0 && key_SET2 == 1 && key_DOWN == 0 && key_UP == 1) {
      key_DOWN = 1;
      key = 1;
      temperaturestate = !temperaturestate;
          if (
      key == 0 && key_SET2 == 1 && key_DOWN == 1 && key_UP == 0) {
      key_UP = 1;
      key = 1;
          if (
      key_SET2 = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_syshum();
      //*********************************************Subprogram SET_SystemHum()
      void SET_syshum() {
      lcd.clear();
        while (
      1) {
      lcd.print(">SET System Hum");
      lcd.print("System Hum  = ");
          if (
      humiditystate) {
      lcd.print("ON");
          } else {
      lcd.print("OFF");
          if (
      key_DOWN = 1;
      key = 1;
      humiditystate = !humiditystate;
          if (
      key_UP = 1;
      key = 1;
          if (
      key_SET2 = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_mintemp();
      //*********************************************Subprogram SET_MinTemp()
      void SET_mintemp() {
      lcd.clear();
        while (
      1) {
      lcd.print(">SET MinTemp");
      lcd.print("Temp  = ");
          if (
      key_DOWN = 1;
      key = 1;
            if (
      mintemp == -40) {
      mintemp = 80;
            } else {
      mintemp -= 0.1;
          if (
      key_UP = 1;
      key = 1;
            if (
      mintemp == 80) {
      mintemp = -40;
            } else {
      mintemp += 0.1;
          if (
      key_SET2 = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_maxtemp();
      //*********************************************Subprogram SET_MaxTemp()
      void SET_maxtemp() {
      lcd.clear();
        while (
      1) {
      lcd.print(">SET MaxTemp");
          if (
      key_DOWN = 1;
      key = 1;
            if (
      maxtemp == -40) {
      maxtemp = 80;
            } else {
      maxtemp -= 0.1;
          if (
      key_UP = 1;
      key = 1;
            if (
      maxtemp == 80) {
      maxtemp = -40;
            } else {
      maxtemp += 0.1;
          if (
      key_SET2 = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_minhum();
      //*********************************************Subprogram SET_MinHum()
      void SET_minhum() {
      lcd.clear();
        while (
      1) {
      lcd.print(">SET MinHum");
      lcd.print("Hum  = ");
          if (
      key_DOWN = 1;
      key = 1;
            if (
      minhum == 0) {
      minhum = 100;
            } else {
      minhum -= 0.1;
          if (
      key_UP = 1;
      key = 1;
            if (
      minhum == 100) {
      minhum = 0;
            } else {
      minhum += 0.1;
          if (
      key_SET2 = 1;
      key = 1;
            break;
          if (
      key = 0;
      SET_maxhum();
      //*********************************************Subprogram SET_MaxHum()
      void SET_maxhum() {
      lcd.clear();
        while (
      1) {
      lcd.print(">SET MaxHum");
          if (
      key_DOWN = 1;
      key = 1;
            if (
      maxhum == 0) {
      maxhum = 100;
            } else {
      maxhum -= 0.1;
          if (
      key_UP = 1;
      key = 1;
            if (
      maxhum == 100) {
      maxhum = 0;
            } else {
      maxhum += 0.1;
          if (
      key_SET2 = 1;
      key = 1;
            break;
          if (
      key = 0;
      Save2();
      void Save2() {
      lcd.clear();
      EEPROM.put(80,  temperaturestate);
      EEPROM.put(85, humiditystate);
      EEPROM.put(90, mintemp);
      EEPROM.put(95, maxtemp);
      EEPROM.put(100, minhum);
      EEPROM.put(105,  maxhum);
      delay(2000);
      lcd.clear();
      void TempRelay() {
        if (
      digitalWrite (RELAY_Temp1, HIGH);
        if (
      digitalWrite (RELAY_Temp1, LOW);
          if (
        if (
          if (
      delay(5);
      void HumRelay() {
        if (
      digitalWrite (RELAY_Hum2, HIGH);
        if (
      digitalWrite (RELAY_Hum2, LOW);
          if (
        if (
          if (
      delay(5);
      جدیدترین ویرایش توسط حمید حمید; 2020/04/15, 10:15. دلیل: تکمیل و رفع چند ایراد کد
        بسم الله
        مدتی بود دنبال یک دستگاه بودم که هم بتونم کنترل دما و رطوبت را باهاش انجام بدهم هم یک قابلیت زمانبدی قطع و وصل رله را داشته باشه.
        بعد از جستجو تو سایتهای مختلف و پیدا نکردن یک همچین موجودی ،خودم دست به کار شدم و همچین موجودی را ساختم.
        قطعات مورد نیاز:
        1- LCD 20x4
        2-ماژول تبدیل LCD به i2c
        3-ماژول رله 2 کانال 5 ولت
        4- سنسور دما و رطوبت DHT21 یا DHT22
        5- ماژول ساعت DS3231
        6- چهار عدد تک سوئیچ
        7-شش عدد مقاومت جهت ساخت سوئیچ آنالوگ و یکی برای پول آپ سنسور
        8-دو عدد برد سوراخدار 250 نقطه
        9-ماژول تغذیه کاهنده LM2596
        10-یک یا 2 متر سیم برق
        11-سیم جامپر نر به ماده 20cm فلت 40 رشته
        12-حداکثر 20 متر سیم 3 رشته یا 2 زوج مسی برای سنسور دما و رطوبت(کابل تلفن مسی هم جواب میده)
        13- 2 عدد پریز توکار دربدار تابلویی
        14-چند ترمینال پیچی مدل KF350-Pin دو و سه پین
        15-یک عدد آداپتور 24 ولت حداقل 1آمپری(اختیاری)
        16- یک عدد جک آداپتور روپنلی مدل DC-025M (اختیاری)
        17- یک عدد آداپتور 5 ولت 1.5 آمپری
        18-یک عدد جعبه 10x15
        20- یک عدد میکرو پرو بخاطر کوچک شدن سایز دستگاه وگرنه هر میکروی دیگری میتوان استفاده شود
        بعد از سر هم کردن قطعات برنامه زیر را هم روش بار گذاری بفرمایید
        ,والسلام
        هدیه نثار روح شهدا و امام شهدا الفاتحه مع صلوات بر محمد و آل محمد
        #include <EEPROM.h>
        #define ANALOG_PIN A0
        #include <Wire.h>
        #include "DHT.h"
        #define DHTPIN A1
        // pin definitions
        //#define Input1 A3
        //#define Input2 A4
        boolean key = 0;
        int _hour, _minute;
        boolean show = 0;
        // pin definitions
        char timestamp[32];
        void b1Click() {
        show = 0;
        lcd.clear();
        void b1Hold() {
        key_SET = 0;
        void b2Click() {
        show = 1;
        lcd.clear();
        void b2Hold() {
        key_SET2 = 0;
        void b3Click() {
        key_DOWN = 0;
        lcd.clear();
        void b3Hold() {
        key_DOWN = 0;
        void b4Click() {
        key_UP = 0;
        lcd.clear();
        void b4Hold() {
        key_UP = 0;
        Button b1 = Button(693, &b1Click, &b1Hold, 2500, 2500);
        Button b3 = Button(881, &b3Click, &b3Hold, 500, 200);
        return t_to_sec;
        const time_t ALARM_1_INTERVAL(t_to_sec(A1_hour, A1_minute, A1_day)); // alarm interval in seconds
        //**************************************************************************Setup()
        void setup()
        dht.begin();
        //Serial.begin(9600);
        lcd.begin();
        lcd.clear();
        lcd.print(" *Besme allah*");
        lcd.print(" CLOCK Pro");
        lcd.print(" TEMP & HUM");
        delay(5000);
        lcd.clear();
        RTC.alarm(ALARM_1);
        RTC.alarm(ALARM_2);
        // the current time
        tmElements_t tm;
        breakTime(t , tm);
        tm.Minute = 00;
        tm.Second = 00;
        // calculate the alarm1
        time_t a_1 = makeTime(tm) + ALARM_1_INTERVAL;
        if (t < a1) {
        } else {
        RTC.setAlarm(ALM1_MATCH_DATE, minute(a_1), hour(a_1), day(a_1));
        formatTime(timestamp, a_1);
        RTC.alarmInterrupt(ALARM_1, true); //faal kardane Alarm1
        // calculate the alarm2
        time_t a_2 = makeTime(tm) + ALARM_2_INTERVAL;
        if (t < a2) {
        } else {
        RTC.setAlarm(ALM2_MATCH_DATE, minute(a_2), hour(a_2), day(a_2));
        formatTime(timestamp2, a_2);
        RTC.alarmInterrupt(ALARM_2, true); //faal kardane Alarm2
        //**********************************************************loop()
        void loop()
        //***************************************************Namayesh Clock & Alarms
        if (show == 0) {
        char buf_time[20];
        char buf_date[20];
        sprintf(buf_time, "%.2d:%.2d:%.2d",
        hour(t), minute(t), second(t));
        sprintf(buf_date, "%.4d/%.2d/%.2d [%s]",
        year(t) , month(t), day(t), dayShortStr(weekday(t)));
        lcd.print(buf_time);
        lcd.print(" ");
        lcd.print(RTC.temperature() / 4.0);
        lcd.print("\337");
        lcd.print(buf_date);
        lcd.print("A1:");
        timestamp[14] = 0;
        lcd.print("A2:");
        timestamp2[14] = 0;
        if (key == 0 && key_SET == 0 && key_DOWN == 1 && key_UP == 1) {
        key_SET = 1;
        key = 1;
        _hour = hour(t);
        _minute = minute(t);
        _year = year(t);
        _month = month(t);
        _day = day(t);
        SET_hour();
        if (key == 1 && key_SET == 1 && key_DOWN == 1 && key_UP == 1) {
        key = 0;
        //***************************************************Namayesh TEMP & HUM
        } else {
        lcd.print("Temp:");
        lcd.print(temp, 1);
        lcd.print("\337");
        if (mintemp == maxtemp || !temperaturestate ) {
        lcd.print(" OFF! ");
        if ( mintemp != maxtemp && mintemp > maxtemp ) {
        lcd.print(" Warm ");
        if (temp < mintemp && temp > maxtemp && temperaturestate && !digitalRead(RELAY_Temp1)) {
        if (temp < maxtemp && temperaturestate) {
        lcd.print(" Cold ");
        if (mintemp != maxtemp && mintemp < maxtemp) {
        if (temp > mintemp && temp < maxtemp && temperaturestate && !digitalRead(RELAY_Temp1)) {
        if (temp > maxtemp && temperaturestate) {
        lcd.print("TMin");
        lcd.print(" TMax");
        lcd.print("Hum :");
        lcd.print(hum, 1);
        lcd.print("%");
        if (minhum == maxhum || !humiditystate ) {
        if ( minhum != maxhum && minhum > maxhum ) {
        lcd.print(" Wet ");
        if (hum < minhum && hum > maxhum && humiditystate && !digitalRead(RELAY_Hum2)) {
        if (hum < maxhum && humiditystate) {
        lcd.print(" Dry ");
        if (minhum != maxhum && minhum < maxhum) {
        lcd.print(" Dry ");
        if (hum > minhum && hum < maxhum && humiditystate && !digitalRead(RELAY_Hum2)) {
        if (hum > maxhum && humiditystate) {
        lcd.print(" Wet ");
        lcd.print("HMin");
        lcd.print(" HMax");
        key_SET2 = 1;
        key = 1;
        SET_systemp();
        if (key == 1 && key_SET2 == 1 && key_DOWN == 1 && key_UP == 1) {
        key = 0;
        TempRelay();
        HumRelay();
        lcd.clear();
        tmElements_t tm;
        breakTime(t , tm);
        tm.Minute = 00;
        tm.Second = 00;
        EEPROM.put(60, a1);
        // set the alarm
        timestamp[14] = 0; // keep just hh:mm weekday DD MM
        lcd.print("A1:");
        lcd.clear();
        if (RTC.alarm(ALARM_2))
        lcd.clear();
        tmElements_t tm;
        breakTime(t , tm);
        tm.Minute = 00;
        tm.Second = 00;
        EEPROM.put(65, a2);
        // set the alarm
        timestamp2[14] = 0; // keep just hh:mm weekday DD MM
        lcd.print("A2:");
        lcd.clear();
        //baraye be dast avardane maghadir switch analog az in ghesmat estefade shavad
        //configure();
        //void configure() {
        //unsigned int value = analogRead(ANALOG_PIN);
        //lcd.setCursor (17, 0);
        //lcd.print(value);
        //delay(250);
        //*********************************************Subprogram TempRelay()
        void TempRelay() {
        //delay(5);
        //*********************************************Subprogram HumRelay()
        void HumRelay() {
        //lcd.setCursor(12, 0);
        //lcd.print("ON");
        //lcd.setCursor(12, 2);
        //lcd.print("ON");
        //delay(5);
        sprintf(buf, "%.2d:%.2d %s%.2d%s",
        hour(t), minute(t), dayShortStr(weekday(t)), day(t), m);
        void SET_hour() {
        lcd.clear();
        while (1) {
        lcd.print(_hour);
        if (key == 0 && key_SET == 1 && key_DOWN == 0 && key_UP == 1) {
        key_DOWN = 1;
        key = 1;
        if (_hour == 0) {
        _hour = 23;
        } else {
        _hour--;
        if (key == 0 && key_SET == 1 && key_DOWN == 1 && key_UP == 0) {
        key_UP = 1;
        key = 1;
        if (_hour == 23) {
        _hour = 0;
        } else {
        _hour++;
        key_SET = 1;
        key = 1;
        break;
        key = 0;
        SET_minute();
        void SET_minute() {
        lcd.clear();
        while (1) {
        lcd.print(_minute);
        key_DOWN = 1;
        key = 1;
        if (_minute == 0) {
        _minute = 59;
        } else {
        _minute--;
        key_UP = 1;
        key = 1;
        if (_minute == 59) {
        _minute = 0;
        } else {
        _minute++;
        key_SET = 1;
        key = 1;
        break;
        key = 0;
        SET_year();
        void SET_year() {
        lcd.clear();
        while (1) {
        lcd.print(_year);
        key_DOWN = 1;
        key = 1;
        if (_year == 2015) {
        _year = 2030;
        } else {
        _year--;
        key_UP = 1;
        key = 1;
        if (_year == 2030) {
        _year = 2015;
        } else {
        _year++;
        key_SET = 1;
        key = 1;
        break;
        key = 0;
        SET_month();
        void SET_month() {
        lcd.clear();
        while (1) {
        lcd.print(_month);
        key_DOWN = 1;
        key = 1;
        if (_month == 1) {
        _month = 12;
        } else {
        _month--;
        key_UP = 1;
        key = 1;
        if (_month == 12) {
        _month = 1;
        } else {
        _month++;
        key_SET = 1;
        key = 1;
        break;
        key = 0;
        SET_day();
        void SET_day() {
        lcd.clear();
        while (1) {
        lcd.print(_day);
        key_DOWN = 1;
        key = 1;
        if (_day == 1) {
        _day = 31;
        } else {
        _day--;
        key_UP = 1;
        key = 1;
        if (_day == 31) {
        _day = 1;
        } else {
        _day++;
        key_SET = 1;
        key = 1;
        break;
        key = 0;
        SET_Alarm1_day();
        lcd.clear();
        while (1) {
        lcd.print(A1_day);
        key_DOWN = 1;
        key = 1;
        if (A1_day == 1) {
        A1_day = 31;
        } else {
        A1_day--;
        key_UP = 1;
        key = 1;
        if (A1_day == 31) {
        A1_day = 1;
        } else {
        A1_day++;
        key_SET = 1;
        key = 1;
        break;
        key = 0;
        SET_Alarm1_hour();
        lcd.clear();
        while (1) {
        lcd.print(A1_hour);
        key_DOWN = 1;
        key = 1;
        if (A1_hour == 0) {
        A1_hour = 23;
        } else {
        A1_hour--;
        key_UP = 1;
        key = 1;
        if (A1_hour == 23) {
        A1_hour = 0;
        } else {
        A1_hour++;
        key_SET = 1;
        key = 1;
        break;
        key = 0;
        lcd.clear();
        while (1) {
        key_DOWN = 1;
        key = 1;
        if (A1_minute == 0) {
        A1_minute = 59;
        } else {
        A1_minute--;
        key_UP = 1;
        key = 1;
        if (A1_minute == 59) {
        A1_minute = 0;
        } else {
        A1_minute++;
        key_SET = 1;
        key = 1;
        break;
        key = 0;
        SET_Alarm1_delay();
        lcd.clear();
        while (1) {
        key_DOWN = 1;
        key = 1;
        if (A1_delay == 0) {
        A1_delay = 1400;
        } else {
        A1_delay--;
        key_UP = 1;
        key = 1;
        if (A1_delay == 1400) {
        A1_delay = 0;
        } else {
        A1_delay++;
        key_SET = 1;
        key = 1;
        break;
        key = 0;
        SET_Alarm2_day();
        lcd.clear();
        while (1) {
        lcd.print(A2_day);
        key_DOWN = 1;
        key = 1;
        if (A2_day == 1) {
        A2_day = 31;
        } else {
        A2_day--;
        key_UP = 1;
        key = 1;
        if (A2_day == 31) {
        A2_day = 1;
        } else {
        A2_day++;
        key_SET = 1;
        key = 1;
        break;
        key = 0;
        SET_Alarm2_hour();
        lcd.clear();
        while (1) {
        lcd.print(A2_hour);
        key_DOWN = 1;
        key = 1;
        if (A2_hour == 0) {
        A2_hour = 23;
        } else {
        A2_hour--;
        key_UP = 1;
        key = 1;
        if (A2_hour == 23) {
        A2_hour = 0;
        } else {
        A2_hour++;
        key_SET = 1;
        key = 1;
        break;
        key = 0;
        lcd.clear();
        while (1) {
        key_DOWN = 1;
        key = 1;
        if (A2_minute == 0) {
        A2_minute = 59;
        } else {
        A2_minute--;
        key_UP = 1;
        key = 1;
        if (A2_minute == 59) {
        A2_minute = 0;
        } else {
        A2_minute++;
        key_SET = 1;
        key = 1;
        break;
        key = 0;
        SET_Alarm2_delay();
        lcd.clear();
        while (1) {
        key_DOWN = 1;
        key = 1;
        if (A2_delay == 0) {
        A2_delay = 1400;
        } else {
        A2_delay--;
        key_UP = 1;
        key = 1;
        if (A2_delay == 1400) {
        A2_delay = 0;
        } else {
        A2_delay++;
        key_SET = 1;
        key = 1;
        break;
        key = 0;
        Save();
        void Save() {
        lcd.clear();
        lcd.print("> Save...");
        lcd.print("> *Zakhire*");
        tmElements_t tm;
        breakTime(t , tm);
        tm.Minute = 00;
        tm.Second = 00;
        // set the alarm
        // set the alarm
        tm.Year = _year - 1970;
        tm.Month = _month;
        tm.Day = _day;
        tm.Hour = _hour;
        tm.Minute = _minute;
        tm.Second = 0;
        if (makeTime(tm) > t)
        RTC.write(tm);
        EEPROM.put(60, a1);
        EEPROM.put(65, a2);
        delay(2000);
        lcd.clear();
        lcd.clear();
        while (1) {
        if (temperaturestate) {
        lcd.print("ON");
        } else {
        lcd.print("OFF");
        if (key == 0 && key_SET2 == 1 && key_DOWN == 0 && key_UP == 1) {
        key_DOWN = 1;
        key = 1;
        if (key == 0 && key_SET2 == 1 && key_DOWN == 1 && key_UP == 0) {
        key_UP = 1;
        key = 1;
        key_SET2 = 1;
        key = 1;
        break;
        key = 0;
        SET_syshum();
        void SET_syshum() {
        lcd.clear();
        while (1) {
        if (humiditystate) {
        lcd.print("ON");
        } else {
        lcd.print("OFF");
        key_DOWN = 1;
        key = 1;
        key_UP = 1;
        key = 1;
        key_SET2 = 1;
        key = 1;
        break;
        key = 0;
        SET_mintemp();
        lcd.clear();
        while (1) {
        key_DOWN = 1;
        key = 1;
        if (mintemp == -40) {
        mintemp = 80;
        } else {
        mintemp -= 0.1;
        key_UP = 1;
        key = 1;
        if (mintemp == 80) {
        mintemp = -40;
        } else {
        mintemp += 0.1;
        key_SET2 = 1;
        key = 1;
        break;
        key = 0;
        SET_maxtemp();
        lcd.clear();
        while (1) {
        key_DOWN = 1;
        key = 1;
        if (maxtemp == -40) {
        maxtemp = 80;
        } else {
        maxtemp -= 0.1;
        key_UP = 1;
        key = 1;
        if (maxtemp == 80) {
        maxtemp = -40;
        } else {
        maxtemp += 0.1;
        key_SET2 = 1;
        key = 1;
        break;
        key = 0;
        SET_minhum();
        void SET_minhum() {
        lcd.clear();
        while (1) {
        key_DOWN = 1;
        key = 1;
        if (minhum == 0) {
        minhum = 100;
        } else {
        minhum -= 0.1;
        key_UP = 1;
        key = 1;
        if (minhum == 100) {
        minhum = 0;
        } else {
        minhum += 0.1;
        key_SET2 = 1;
        key = 1;
        break;
        key = 0;
        SET_maxhum();
        void SET_maxhum() {
        lcd.clear();
        while (1) {
        key_DOWN = 1;
        key = 1;
        if (maxhum == 0) {
        maxhum = 100;
        } else {
        maxhum -= 0.1;
        key_UP = 1;
        key = 1;
        if (maxhum == 100) {
        maxhum = 0;
        } else {
        maxhum += 0.1;
        key_SET2 = 1;
        key = 1;
        break;
        key = 0;
        Save2();
        //***************************************************Subprogram Save()
        void Save2() {
        lcd.clear();
        delay(2000);
        lcd.clear();
        از نظرات برنامه نویسان متخصص محترم استقبال میکنم.
          18-یک عدد جعبه 12x12x10 پارسا
          نکته:در صورت استفاده از آداپتور 24ولت 1 آمپری سوئیچینگ، باید حرارت داخل جعبه که توسط آداپتور بوجود می آید کنترل بشه وگرنه با بالا رفتن حرارت داخل جعبه میکرو هنگ میکنه و در همون حالت رله باقی میمونه تا به دادش برسید.
          جدیدترین ویرایش توسط حمید حمید; 2020/04/22, 23:56.
            با عرض سلام
            و عرض تبریک بمناسبت فرارسیدن ماه مبارک رمضان ماه مهمانی خداوند مهربان به خدمت همه بندگان خدا
            چند نکته تجربی که در رابطه با این دستگاه داشتم را با شما عزیزان به اشتراک می گذارم.
            ایجاد تاخیر حدود 3 میلی ثانیه ای در خطوط 440 و 469 برنامه.
            حذف قطعات زیر میتونه تو بهبود عملکرد دستگاه به شما کمک کند.
            که البته وجود آداپتور 5 ولتی، 1 آمپری ضروریست . بنده در این دستگاه از یک عدد برد آداپتور 700 میلی آمپری مبایل استفاده کردم.
            نکته :درباره هنگ گاه به گاه میکرو هم باید یک تدبیری داشته باشید که بنده هنوز راهی برای این مسئله ندارم.
            جدیدترین ویرایش توسط حمید حمید; 2020/04/25, 06:46.
              سلام علیکم
              با آرزوی قبولی نماز و روزه همه بندگان خدا
              تغییرات در این نسخه جدید :
              1- اضافه شدن watchdog برای رفع مشکل هنگ میکرو
              2- اصلاح نمایش اعداد بین 0 تا 10 در زمان افزایش و کاهش سریع
              3- اصلاح وقفه فعال سازی رله، از حالت delay به حالت timer. با استفاده از pulseImmediate
              4- اصلاح و تغییر نوع چند متغیر برای ذخیره صحیح داده.
              5-ایجاد یک ارتباط منطقی در زمان فعال سازی رله ها و حدود بالا و پائین دما و رطوبت.
              6- اضافه کردن لینک کتابخانه های مورد استفاده در سورس کد.
              و...
              #include <DS3232RTC.h>        // https://github.com/JChristensen/DS3232RTC    https://github.com/PaulStoffregen/Time
              #include <EEPROM.h>
              #include <avr/wdt.h>
              #include "Timer.h" //https://github.com/JChristensen/Timer
              Timer Ti1;
              Timer Ti2;
              #include <Wire.h>
              #include "DHT.h" //https://github.com/adafruit/DHT-sensor-library
              #define DHTPIN A1
              // pin definitions
              //#define Input1 A3
              //#define Input2 A4
              boolean key = 0 , key_SET = 1 , key_SET2 = 1 , key_DOWN = 1, key_UP = 1 , show = 0;
              int _hour, _minute;
              // pin definitions
              char timestamp[32];
              void b1Click() {
              show = 0;
              lcd.clear();
              void b1Hold() {
              key_SET = 0;
              void b2Click() {
              show = 1;
              lcd.clear();
              void b2Hold() {
              key_SET2 = 0;
              void b3Click() {
              key_DOWN = 0;
              lcd.clear();
              void b3Hold() {
              key_DOWN = 0;
              void b4Click() {
              key_UP = 0;
              lcd.clear();
              void b4Hold() {
              key_UP = 0;
              long t_to_sec( long days_, long h_, int m_ )
              long t_to_sec = ((((days_ * 24) * 60) * 60) + ((h_ * 60) * 60) + (m_ * 60));
              return t_to_sec;
              const time_t ALARM_1_INTERVAL(t_to_sec( A1_day, A1_hour, A1_minute)); // alarm interval in seconds
              const time_t ALARM_2_INTERVAL(t_to_sec(A2_day, A2_hour, A2_minute)); // alarm interval in seconds
              void setup()
              dht.begin();
              lcd.begin();
              lcd.clear();
              lcd.print(" *Besme Allah*");
              delay(5000);
              lcd.clear();
              RTC.alarm(ALARM_1);
              RTC.alarm(ALARM_2);
              // the current time
              tmElements_t tm;
              breakTime(t , tm);
              tm.Minute = 00;
              tm.Second = 00;
              // calculate the next alarm time //for lost power
              if (t < a1) {
              } else {
              if (t < a2) {
              } else {
              wdt_enable(WDTO_8S);
              void loop()
              wdt_reset();
              if (show == 0) {
              char buf_time[20];
              char buf_date[20];
              lcd.print(" ");
              lcd.print("\337");
              lcd.print("A1:");
              timestamp[14] = 0;
              lcd.print("A2:");
              timestamp2[14] = 0;
              key_SET = 1;
              key = 1;
              _hour = hour(t);
              _year = year(t);
              _month = month(t);
              _day = day(t);
              SET_hour();
              key = 0;
              } else {
              lcd.print("Temp:");
              lcd.print(temp, 1);
              lcd.print("\337");
              if ( !temperaturestate ) { //mintemp == maxtemp ||
              if ( mintemp > maxtemp ) { //mintemp != maxtemp &&
              if ( mintemp < maxtemp) { //mintemp != maxtemp &&
              lcd.print("TMin");
              lcd.print(" TMax");
              lcd.print("Hum :");
              lcd.print(hum, 1);
              lcd.print("%");
              if ( !humiditystate ) { //minhum == maxhum ||
              if ( minhum > maxhum ) { //minhum != maxhum &&
              lcd.print(" Wet ");
              lcd.print(" Dry ");
              if ( minhum < maxhum) { //minhum != maxhum &&
              lcd.print(" Dry ");
              lcd.print(" Wet ");
              lcd.print("HMin");
              lcd.print(" HMax");
              key_SET2 = 1;
              key = 1;
              SET_systemp();
              key = 0;
              TempRelay();
              HumRelay();
              //update state of relay for delay timer
              Ti1.update();
              Ti2.update();
              lcd.clear();
              tmElements_t tm;
              breakTime(t , tm);
              tm.Minute = 00;
              tm.Second = 00;
              EEPROM.put(60, a1);
              // set the alarm
              lcd.print("A1:");
              Ti1.pulseImmediate(RELAY_Temp1, A1_delay * 60 * 1000UL, LOW);
              delay(3000);
              lcd.clear();
              lcd.clear();
              tmElements_t tm;
              breakTime(t , tm);
              tm.Minute = 00;
              tm.Second = 00;
              EEPROM.put(65, a2);
              // set the alarm
              lcd.print("A2:");
              Ti2.pulseImmediate(RELAY_Hum2, A2_delay * 60 * 1000UL, LOW);
              delay(3000);
              lcd.clear();
              //configure();
              //lcd.print(value);
              //delay(250);
              void TempRelay() {
              //if (mintemp == maxtemp || !temperaturestate ) {
              //digitalWrite (RELAY_Temp1, HIGH);
              delay(2);
              void HumRelay() {
              //if (minhum == maxhum || !humiditystate ) {
              //digitalWrite (RELAY_Hum2, HIGH);
              delay(2);
              void SET_hour() {
              lcd.clear();
              wdt_disable();
              while (1) {
              if (_hour < 10) lcd.print(" ");
              lcd.print(_hour);
              key_DOWN = 1;
              key = 1;
              if (_hour == 0) {
              _hour = 23;
              } else {
              _hour--;
              key_UP = 1;
              key = 1;
              if (_hour == 23) {
              _hour = 0;
              } else {
              _hour++;
              key_SET = 1;
              key = 1;
              break;
              key = 0;
              SET_minute();
              void SET_minute() {
              lcd.clear();
              while (1) {
              if (_minute < 10) lcd.print(" ");
              lcd.print(_minute);
              key_DOWN = 1;
              key = 1;
              if (_minute == 0) {
              _minute = 59;
              } else {
              _minute--;
              key_UP = 1;
              key = 1;
              _minute = 0;
              } else {
              _minute++;
              key_SET = 1;
              key = 1;
              break;
              key = 0;
              SET_year();
              void SET_year() {
              lcd.clear();
              while (1) {
              lcd.print(_year);
              key_DOWN = 1;
              key = 1;
              _year = 2030;
              } else {
              _year--;
              key_UP = 1;
              key = 1;
              _year = 2015;
              } else {
              _year++;
              key_SET = 1;
              key = 1;
              break;
              key = 0;
              SET_month();
              void SET_month() {
              lcd.clear();
              while (1) {
              if (_month < 10) lcd.print(" ");
              lcd.print(_month);
              key_DOWN = 1;
              key = 1;
              if (_month == 1) {
              _month = 12;
              } else {
              _month--;
              key_UP = 1;
              key = 1;
              if (_month == 12) {
              _month = 1;
              } else {
              _month++;
              key_SET = 1;
              key = 1;
              break;
              key = 0;
              SET_day();
              void SET_day() {
              lcd.clear();
              while (1) {
              if (_day < 10) lcd.print(" ");
              lcd.print(_day);
              key_DOWN = 1;
              key = 1;
              if (_day == 1) {
              _day = 31;
              } else {
              _day--;
              key_UP = 1;
              key = 1;
              if (_day == 31) {
              _day = 1;
              } else {
              _day++;
              key_SET = 1;
              key = 1;
              break;
              key = 0;
              SET_Alarm1_day();
              lcd.clear();
              while (1) {
              if (A1_day < 10) lcd.print(" ");
              lcd.print(A1_day);
              key_DOWN = 1;
              key = 1;
              if (A1_day == 1) {
              A1_day = 31;
              } else {
              A1_day--;
              key_UP = 1;
              key = 1;
              if (A1_day == 31) {
              A1_day = 1;
              } else {
              A1_day++;
              key_SET = 1;
              key = 1;
              break;
              key = 0;
              SET_Alarm1_hour();
              lcd.clear();
              while (1) {
              if (A1_hour < 10) lcd.print(" ");
              lcd.print(A1_hour);
              key_DOWN = 1;
              key = 1;
              if (A1_hour == 0) {
              A1_hour = 23;
              } else {
              A1_hour--;
              key_UP = 1;
              key = 1;
              A1_hour = 0;
              } else {
              A1_hour++;
              key_SET = 1;
              key = 1;
              break;
              key = 0;
              lcd.clear();
              while (1) {
              if (A1_minute < 10) lcd.print(" ");
              key_DOWN = 1;
              key = 1;
              A1_minute = 59;
              } else {
              A1_minute--;
              key_UP = 1;
              key = 1;
              A1_minute = 0;
              } else {
              A1_minute++;
              key_SET = 1;
              key = 1;
              break;
              key = 0;
              SET_Alarm1_delay();
              lcd.clear();
              while (1) {
              if (A1_delay < 10) lcd.print(" ");
              key_DOWN = 1;
              key = 1;
              A1_delay = 1400;
              } else {
              A1_delay--;
              key_UP = 1;
              key = 1;
              A1_delay = 0;
              } else {
              A1_delay++;
              key_SET = 1;
              key = 1;
              break;
              key = 0;
              SET_Alarm2_day();
              lcd.clear();
              while (1) {
              if (A2_day < 10) lcd.print(" ");
              lcd.print(A2_day);
              key_DOWN = 1;
              key = 1;
              if (A2_day == 1) {
              A2_day = 31;
              } else {
              A2_day--;
              key_UP = 1;
              key = 1;
              if (A2_day == 31) {
              A2_day = 1;
              } else {
              A2_day++;
              key_SET = 1;
              key = 1;
              break;
              key = 0;
              SET_Alarm2_hour();
              lcd.clear();
              while (1) {
              if (A2_hour < 10) lcd.print(" ");
              lcd.print(A2_hour);
              key_DOWN = 1;
              key = 1;
              if (A2_hour == 0) {
              A2_hour = 23;
              } else {
              A2_hour--;
              key_UP = 1;
              key = 1;
              A2_hour = 0;
              } else {
              A2_hour++;
              key_SET = 1;
              key = 1;
              break;
              key = 0;
              lcd.clear();
              while (1) {
              if (A2_minute < 10) lcd.print(" ");
              key_DOWN = 1;
              key = 1;
              A2_minute = 59;
              } else {
              A2_minute--;
              key_UP = 1;
              key = 1;
              A2_minute = 0;
              } else {
              A2_minute++;
              key_SET = 1;
              key = 1;
              break;
              key = 0;
              SET_Alarm2_delay();
              lcd.clear();
              while (1) {
              if (A2_delay < 10) lcd.print(" ");
              key_DOWN = 1;
              key = 1;
              A2_delay = 1400;
              } else {
              A2_delay--;
              key_UP = 1;
              key = 1;
              A2_delay = 0;
              } else {
              A2_delay++;
              key_SET = 1;
              key = 1;
              break;
              key = 0;
              Save();
              void Save() {
              lcd.clear();
              tmElements_t tm;
              breakTime(t , tm);
              tm.Minute = 00;
              tm.Second = 00;
              time_t ALARM_1_INTERVAL(t_to_sec(A1_day, A1_hour, A1_minute )); // alarm interval in seconds
              // set the alarm
              time_t ALARM_2_INTERVAL(t_to_sec( A2_day, A2_hour, A2_minute));
              // set the alarm
              tm.Month = _month;
              tm.Day = _day;
              tm.Hour = _hour;
              tm.Second = 0;
              RTC.write(tm);
              EEPROM.put(60, a1);
              EEPROM.put(65, a2);
              delay(2000);
              lcd.clear();
              lcd.clear();
              wdt_disable();
              while (1) {
              lcd.print("ON");
              } else {
              lcd.print("OFF");
              key_DOWN = 1;
              key = 1;
              key_UP = 1;
              key = 1;
              key_SET2 = 1;
              key = 1;
              break;
              key = 0;
              SET_syshum();
              void SET_syshum() {
              lcd.clear();
              while (1) {
              lcd.print("ON");
              } else {
              lcd.print("OFF");
              key_DOWN = 1;
              key = 1;
              key_UP = 1;
              key = 1;
              key_SET2 = 1;
              key = 1;
              break;
              key = 0;
              SET_mintemp();
              lcd.clear();
              while (1) {
              key_DOWN = 1;
              key = 1;
              mintemp = 80;
              } else {
              mintemp -= 0.1;
              key_UP = 1;
              key = 1;
              mintemp = -40;
              } else {
              mintemp += 0.1;
              key_SET2 = 1;
              key = 1;
              break;
              key = 0;
              SET_maxtemp();
              lcd.clear();
              while (1) {
              key_DOWN = 1;
              key = 1;
              maxtemp = 80;
              } else {
              maxtemp -= 0.1;
              key_UP = 1;
              key = 1;
              maxtemp = -40;
              } else {
              maxtemp += 0.1;
              key_SET2 = 1;
              key = 1;
              break;
              key = 0;
              SET_minhum();
              void SET_minhum() {
              lcd.clear();
              while (1) {
              key_DOWN = 1;
              key = 1;
              if (minhum == 0) {
              minhum = 100;
              } else {
              minhum -= 0.1;
              key_UP = 1;
              key = 1;
              lcd.clear();
              minhum = 0;
              } else {
              minhum += 0.1;
              key_SET2 = 1;
              key = 1;
              break;
              key = 0;
              SET_maxhum();
              void SET_maxhum() {
              lcd.clear();
              while (1) {
              key_DOWN = 1;
              key = 1;
              if (maxhum == 0) {
              maxhum = 100;
              } else {
              maxhum -= 0.1;
              key_UP = 1;
              key = 1;
              lcd.clear();
              maxhum = 0;
              } else {
              maxhum += 0.1;
              key_SET2 = 1;
              key = 1;
              break;
              key = 0;
              Save2();
              void Save2() {
              lcd.clear();
              delay(2000);
              lcd.clear();
