پاسخ : مشکل با AVR و SIM 900
ممنون از آقا سینا
من با بسکام تاحالا کار نکردم
فعلا منتظر بقیه دوستان گل هستم
واقعا دمتون گرم
ممنون از آقا سینا
واقعا دمتون گرم
at+cmgd=0,4;
at+cmgd=0,4;
This program was produced by the
CodeWizardAVR V2.04.4a Advanced
Automatic Program Generator
© Copyright 1998-2009 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 2013/07/27
Author : NeVaDa
Company :
Comments:
Chip type : ATmega32
Program type : Application
AVR Core Clock frequency: 11.059200 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 512
#include <mega32.h>
#include <delay.h>
#asm
.equ __lcd_port=0x1B ;PORTA
#endasm
#include <lcd.h>
#ifndef RXB8
#define RXB8 1
#endif
#ifndef TXB8
#define TXB8 0
#endif
#ifndef UPE
#define UPE 2
#endif
#ifndef DOR
#define DOR 3
#endif
#ifndef FE
#define FE 4
#endif
#ifndef UDRE
#define UDRE 5
#endif
#ifndef RXC
#define RXC 7
#endif
#define FRAMING_ERROR (1<<FE)
#define PARITY_ERROR (1<<UPE)
#define DATA_OVERRUN (1<<DOR)
#define DATA_REGISTER_EMPTY (1<<UDRE)
#define RX_COMPLETE (1<<RXC)
// USART Receiver buffer
#define RX_BUFFER_SIZE 8
char rx_buffer[RX_BUFFER_SIZE];
#if RX_BUFFER_SIZE <= 256
unsigned char rx_wr_index,rx_rd_index,rx_counter;
#else
unsigned int rx_wr_index,rx_rd_index,rx_counter;
#endif
// This flag is set on USART Receiver buffer overflow
bit rx_buffer_overflow;
// USART Receiver interrupt service routine
interrupt [USART_RXC] void usart_rx_isr(void)
char status,data;
status=UCSRA;
data=UDR;
if ((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN))==0)
rx_buffer[rx_wr_index++]=data;
#if RX_BUFFER_SIZE == 256
// special case for receiver buffer size=256
if (++rx_counter == 0) rx_buffer_overflow=1;
#else
if (rx_wr_index == RX_BUFFER_SIZE) rx_wr_index=0;
if (++rx_counter == RX_BUFFER_SIZE)
rx_counter=0;
#endif
#ifndef _DEBUG_TERMINAL_IO_
// Get a character from the USART Receiver buffer
#define _ALTERNATE_GETCHAR_
#pragma used+
char getchar(void)
char data;
while (rx_counter==0);
data=rx_buffer[rx_rd_index++];
#if RX_BUFFER_SIZE != 256
if (rx_rd_index == RX_BUFFER_SIZE) rx_rd_index=0;
#endif
#asm("cli")
--rx_counter;
#asm("sei")
return data;
#pragma used-
#endif
// Standard Input/Output functions
#include <stdio.h>
char Enter=13;
char double_quote=34;
char Ctrlz=26;
char TELL[12]="09195151488";
void main(void)
DDRD.5=0;
PORTD.5=1;
// USART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// USART Receiver: On
// USART Transmitter: On
// USART Mode: Asynchronous
// USART Baud Rate: 9600
UCSRA=0x00;
UCSRB=0x98;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=0x47;
// Alphanumeric LCD initialization
// Connections are specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTA Bit 7
// RD - PORTA Bit 1
// EN - PORTA Bit 2
// D4 - PORTA Bit 3
// D5 - PORTA Bit 4
// D6 - PORTA Bit 5
// D7 - PORTA Bit 6
// Characters/line: 16
// Global enable interrupts
#asm("sei")
lcd_init(16);
lcd_putsf(" W E L C O M E");
delay_ms(300);
lcd_clear();
while (1)
if(PIND.5==0)
while(PIND.5==0);
delay_ms(20);
printf("at+cmgs=%c%s%c%c",double_quote,TELL,double_quote,Enter);
delay_ms(1000);
printf("MORTEZA %c",Ctrlz);
delay_ms(1000);
lcd_putsf("goodbye");
delay_ms(300);
lcd_clear();
