پاسخ : راه اندازی ماژول +nRF24L01
ماژول USB NRF24L01P
10 تومان، خیلی حال کردم باهاش
ماژول USB NRF24L01P
/* * @author * Copyright (C) 2012 Luis R. Hilario http://www.luisdigital.com * */ // Bits /** * Data Ready RX FIFO interrupt */ #define _RX_DR (1<<6) /** * Data Sent TX FIFO interrupt */ #define _TX_DS (1<<5) /** * Maximum number of TX retransmits interrupt */ #define _MAX_RT (1<<4) /** Power Down mode * * Minimal current consumption, SPI can be activated * * @see NRF24L01_Set_Power(char Mode) */ #define _POWER_DOWN 0 /** Power Up mode * * Standby-I mode * * @see NRF24L01_Set_Power(char Mode) */ #define _POWER_UP (1<<1) /** Mode radio transmitter * * @see NRF24L01_Set_Device_Mode(char Device_Mode) * @see NRF24L01_Init(char Device_Mode, char CH, char DataRate, char *Address, char Address_Width, char Size_Payload) */ #define _TX_MODE 0 /** Mode radio receiver * * @see NRF24L01_Set_Device_Mode(char Device_Mode) * @see NRF24L01_Init(char Device_Mode, char CH, char DataRate, char *Address, char Address_Width, char Size_Payload) */ #define _RX_MODE 1 /** Air data rate = 1 Mbps * * * @see NRF24L01_Init(char Device_Mode, char CH, char DataRate, char *Address, char Address_Width, char Size_Payload) */ #define _1Mbps 0 /** Air data rate = 2 Mbps * * @see NRF24L01_Init(char Device_Mode, char CH, char DataRate, char *Address, char Address_Width, char Size_Payload) */ #define _2Mbps (1<<3) #define _250kbps (1<<5) /** Enable ShockBurst Automatic Retransmission (Up to 1 Re-Transmit on fail of AA) Auto Acknowledgment (data pipe 0) @see NRF24L01_Set_ShockBurst(char Mode) */ #define _ShockBurst_ON 1 /** Disable ShockBurst * @see NRF24L01_Set_ShockBurst(char Mode) */ #define _ShockBurst_OFF 0 // REGISTERS #define CONFIG 0x00 #define EN_AA 0x01 #define EN_RXADDR 0x02 #define SETUP_AW 0x03 #define SETUP_RETR 0x04 #define RF_CH 0x05 #define RF_SETUP 0x06 #define STATUS 0x07 #define OBSERVE_TX 0x08 #define CD 0x09 #define RX_ADDR_P0 0x0A #define RX_ADDR_P1 0x0B #define RX_ADDR_P2 0x0C #define RX_ADDR_P3 0x0D #define RX_ADDR_P4 0x0E #define RX_ADDR_P5 0x0F #define TX_ADDR 0x10 #define RX_PW_P0 0x11 #define RX_PW_P1 0x12 #define RX_PW_P2 0x13 #define RX_PW_P3 0x14 #define RX_PW_P4 0x15 #define RX_PW_P5 0x16 #define FIFO_STATUS 0x17 #define DYNPD 0x1C #define FEATURE 0x1D // COMMANDS #define R_REGISTER 0x00 #define W_REGISTER 0x20 #define R_RX_PAYLOAD 0x61 #define W_TX_PAYLOAD 0xA0 #define FLUSH_TX 0xE1 #define FLUSH_RX 0xE2 #define REUSE_TX_PL 0xE3 #define ACTIVATE 0x50 #define R_RX_PL_WID 0x60 #define W_ACK_PAYLOAD 0xA8 #define W_TX_PAYLOAD_NOACK 0x58 #define NOP 0xFF /* * SPI functions for NRF24L01 */ char NRF24L01_ReadReg(char Reg); char NRF24L01_WriteReg(char Reg, char Value); char NRF24L01_ReadRegBuf(char Reg, char *Buf, int Size); char NRF24L01_WriteRegBuf(char Reg, char *Buf, int Size); /* * NRF24L01 functions */ char NRF24L01_Get_Status(void); char NRF24L01_Get_CD(void); void NRF24L01_Set_Power(char Mode); void NRF24L01_Set_CH(char CH); void NRF24L01_Set_ShockBurst(char Mode); void NRF24L01_Set_Address_Width(char Width); void NRF24L01_Set_Device_Mode(char Device_Mode); void NRF24L01_Set_RX_Pipe(char PipeNum, char *Address, int AddressSize, char PayloadSize); void NRF24L01_Disable_All_Pipes(void); char NRF24L01_Clear_Interrupts(void); void NRF24L01_Set_TX_Address(char *Address, int Size); void NRF24L01_Flush_TX(void); void NRF24L01_Flush_RX(void); void NRF24L01_Init(char Device_Mode, char CH, char DataRate, char *Address, char Address_Width, char Size_Payload); void NRF24L01_RF_TX(void); void NRF24L01_Write_TX_Buf(char *Buf, int Size); void NRF24L01_Read_RX_Buf(char *Buf, int Size);
oo:nrf_csn=low; spi(ACTIVATE); spi(0x73); nrf_csn=high; NRF24L01_WriteReg(DYNPD,0x01); //Enable dyn. payload length data pipe 0. NRF24L01_WriteReg(FEATURE,0x01);//Enables Dynamic Payload Length & Enables Payload with ACK
nrf_csn=low; spi(W_ACK_PAYLOAD); for(i=0 ; i<lenth ;i ++ ) spi ( PLD[i] ); nrf_csn=high;
nrf_csn=low; spi(R_RX_PAYLOAD); for(i=0 ; i<lenth ;i ++ ) pld[i]=spi ( 0x00 ); nrf_csn=high;
