ایا میشه خروجی سنسور dht22 از نوع float هست رو ...
    سلام به دوستان
    ایا راهی هست خروجی سنسور dht22 از نوع float هست رو به char تغییر داد .
    دو نوع کد دارم من که هرکدوم به روشی از سنسور مربوط خروجی میگیرند
    کد اول :
    char temperature[] = " 00.00";
    char temperature_msb;
    if(temperature_msb < 0){
    temperature_msb = abs(temperature_msb);
    temperature[0] = '-';
    else
    temperature[0] = ' ';
    temperature_lsb >>= 6;
    temperature[2] = temperature_msb % 10 + 48;
    temperature[1] = temperature_msb / 10 + 48;
    if(temperature_lsb == 0 || temperature_lsb == 2){
    temperature[5] = '0';
    if(temperature_lsb == 0) temperature[4] = '0';
    else temperature[4] = '5';
    if(temperature_lsb == 1 || temperature_lsb == 3){
    temperature[5] = '5';
    if(temperature_lsb == 1) temperature[4] = '2';
    else temperature[4] = '7';
    // Temperature (Celcius)
    و کد دوم
    //include library
    #include "DHT.h"
    //Define the input pin (pin #2)
    #define I_DHT22 19
    //Define the sensor type (here DHT22)
    #define DHTTYPE DHT22
    //Object declaration
    DHT dht(I_DHT22, DHTTYPE);
    void setup() {
    //Serial port communication
    Serial.begin(9600);
    Serial.println("DHT22 - Test");
    //Initialization
    dht.begin();
    void loop() {
    //2 seconds delay between measurements
    delay(2000);
    //Temperature (Celcius)
    float temperature = dht.readTemperature();
    if (isnan(temperature)) {
    Serial.println("Failed to read temperature from DHT sensor.");
    else {
    Serial.print("Temperature: ");
    Serial.print(temperature);
    Serial.print(" *C\r\n");
    //Humidity
    float humidity = dht.readHumidity();
    if (isnan(humidity)) {
    Serial.println("Failed to read humidity from DHT sensor.");
    else {
    Serial.print("Humidity: ");
    Serial.print(humidity);
    Serial.print(" %\r\n");
    //Heat index
    if (isnan(temperature) || isnan(humidity)) {
    Serial.println("Unable to compute heat index (missing parameters).");
    else {
    float heatIndex = dht.computeHeatIndex(temperature, humidity, false);
    if (isnan(heatIndex)) {
    Serial.println("Failed to compute heat index.");
    else {
    Serial.print("Heat index: ");
    Serial.print(heatIndex);
    در کل کد ها زمین تا اسمون با هم فرق دارن
    ایا راهی هست بشه خروجی ها به char تبدیل کرد ؟؟؟
    پاسخ : ایا میشه خروجی سنسور dht22 از نوع float هست رو ...
    با سلام .
    منظورت اینه که عدد فلوت به رشته قابل چاپ روی lcd تبدیل بشه?
    به زبان C باید باشه ؟ این کد ظاهرا به زبان C هست.
    جدیدترین ویرایش توسط hossein_10; 2018/11/09, 23:32.
      درود . کد دوم که برای آردو هست ، هدف شما از تبدیل به char چیه ?
        اره برای نمایشش توی نمایشگر چون خطا کانورت میگیره ؟
          نوشته اصلی توسط systam نمایش پست ها
          با سلام . من برای زبان c بلدم . و با کدویژن اینکار رو انجام دادم .
          اول هدر stdio.h رو باید اینکلود بکنی .توی کد ویژن اینطوریه #include <stdio.h>
          بعد یه آررایه تعریف میکنی به این صورت char lcd_Buf[n] که این n در واقع بایدحداقل 1 عدد از طول رشته ای که میخوای چاپ کنی بیشتر باشه مثلا اگر طول رشته 20 میشه
          شما باید طول آرایه رو حداقل n=21 انتخاب کنی .
          حالا با sprintf( lcd_buf , " mytext %5.2f %5.2f " , arg1 , arg2 ) این تابع میتونی اعداد اعشاری رو به رشته تبدیل کنی هرچی توی رشته بنویسی مثلا mytext به همراه اعداد اعشاری با فرمتی که خودت تععیین میکنی مثل 5.2f% ; کلا به یک رشته تبدیل میشه و توی lcd buf قرار میگیره و فقط دقت کن طول رشته با احتساب فاصله ها از طول lcd_buf بیشتر نشه . %5.2f هم به این معنیه که عددی که میخوای چاپ بشه به صورت 5 کاراکتر با احتساب نقطه اعشار و دورقم بعد از اعشار چاپ میشه و arg1 , arg2 اعدادی هستن که باید چاپ بشن .....حتما هم نباید 2 تا باشن میتونی تعداد بیشتری بنویسی ولی باید توی رشته فرمتشون رو مشخص کنی .
          بعد بایدآخر رشته رو ببندی برای اینکار لازمه اگه اگر مثلا طول رشته 16کاراکتر شد توی بدنه اصلی برنامه ' lcd_buf[16]= '\0 . البته توی بعضینسخه ها همون تابع sprintf اینکارو میکنه و لی توی بعضیها هم نه . شما دفعه اول احتیاطا اینکارو بکنن.
          بعدش دیگه راحته ، کافیه رشته رو روی lcd نمایش بدی .
          جدیدترین ویرایش توسط hossein_10; 2018/11/16, 13:23.
            من متوجه مشکل نمیشم ، مگه آردو عدد دما و رطوبت بدست آمده از سنسور dht رو روی lcd نشون نمیده ؟ لزوم تبدیل به کاراکتر چیه ؟ چه نوع lcd ?
