با عرض سلام
دوستان میشه کمک کنید تا مشکل کد رو پیدا کنم؟
وقتی implement design رو می زدم، میگفت که متغییر ها مقدار اولیه ندارن، بعد ار اصلاح ، این warning ها رو میده(ise 11)
WARNING:Xst:1293 - FF/Latch <is_end_FSM_FFd1> has a constant value of 0 in block <main>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:2677 - Node <temp_addr_SRAM_10> of sequential type is unconnected in block <main>.
WARNING:Xst:2677 - Node <temp_addr_SRAM_9> of sequential type is unconnected in block <main>.
WARNING:Xst:2677 - Node <temp_addr_SRAM_8> of sequential type is unconnected in block <main>.
WARNING:Xst:2677 - Node <temp_addr_SRAM_7> of sequential type is unconnected in block <main>.
WARNING:Xst:2677 - Node <temp_addr_SRAM_6> of sequential type is unconnected in block <main>.
WARNING:Xst:2677 - Node <temp_addr_SRAM_5> of sequential type is unconnected in block <main>.
WARNING:Xst:2677 - Node <temp_addr_SRAM_4> of sequential type is unconnected in block <main>.
WARNING:Xst:2677 - Node <temp_addr_SRAM_3> of sequential type is unconnected in block <main>.
WARNING:Xst:2677 - Node <temp_addr_SRAM_2> of sequential type is unconnected in block <main>.
WARNING:Xst:2677 - Node <temp_addr_SRAM_1> of sequential type is unconnected in block <main>.
WARNING:Xst:2677 - Node <temp_addr_SRAM_0> of sequential type is unconnected in block <main>.
WARNING:Xst:1293 - FF/Latch <is_end_FSM_FFd2> has a constant value of 0 in block <main>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <A_0> (without init value) has a constant value of 0 in block <main>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <A_1> (without init value) has a constant value of 0 in block <main>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <A_2> (without init value) has a constant value of 0 in block <main>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <A_3> (without init value) has a constant value of 0 in block <main>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <A_4> (without init value) has a constant value of 0 in block <main>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <A_5> (without init value) has a constant value of 0 in block <main>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <A_6> (without init value) has a constant value of 0 in block <main>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <A_7> (without init value) has a constant value of 0 in block <main>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <A_8> (without init value) has a constant value of 0 in block <main>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <A_9> (without init value) has a constant value of 0 in block <main>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <A_10> (without init value) has a constant value of 0 in block <main>. This FF/Latch will be trimmed during the optimization process.
WARNING:Xst:1710 - FF/Latch <LED> (without init value) has a constant value of 0 in block <main>. This FF/Latch will be trimmed during the optimization process.
در حالی که هیج error ای نمیاد.
این هم کد های من: ( http://uppp.ir/new_v/do.php?filename=13432200371.zip )
:rolleyes:
-- Company:
-- Engineer:
-- Create Date: 00:00:48 07/24/2012
-- Design Name:
-- Module Name: main - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
---- Uncomment the following library declaration if instantiating
---- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity main is
Port (
A : out STD_LOGIC_VECTOR (10 downto 0);
D : inout STD_LOGIC_VECTOR (3 downto 0);
clk : in STD_LOGIC;
RAS : out STD_LOGIC;
CAS : out STD_LOGIC;
W : out STD_LOGIC;
OE : out STD_LOGIC;
LED : out STD_LOGIC;
reset : in STD_LOGIC);
end main;
architecture Behavioral of main is
signal count : std_logic_vector(10 downto 0);
signal clk_SRAM: std_logic;
begin
process(clk)
begin
if clk'event and clk='1' then
count<=count+'1';
end if;
end process;
clk_SRAM<=count(10);
process(clk_SRAM, reset)
variable temp_addr_SRAM: std_logic_vector(10 downto 0):="00000000000"; -- µطض·±نء؟
variable data_in: std_logic_vector(3 downto 0):="0000"; -- ت¾ف±نء؟
variable state: integer range 0 to 6 :=0; -- ×´ج¬±نء؟
variable is_end: integer range 0 to 2 :=0; -- ذ´ت¾ف½لتّ±êض¾
begin
if clk_SRAM'event and clk_SRAM='1' then
if reset='1' then -- ¸´خ»
is_end:=0; -- ذ´½لتّ±êذ¾³ُت¼»¯
temp_addr_SRAM:=(others=>'0');
a<= (others=>'0');
LED<='0';
w<='1';
oe<='1';
ras<='1';
cas<='1';
is_end :=0;
state:=0; -- ×´ج¬±نء؟³ُت¼»¯
else
if is_end=0 then -- ذ´ت¾فأ»سذ½لتّ
case state is
when 0 =>
temp_addr_SRAM:=(others=>'0'); -- µطض·³ُت¼»¯
when 1 =>
cas<='1';
ras <='1';
a<=temp_addr_SRAM;
state:=2;
when 2 =>
ras<='0';
oe <='1';
w <='0';
state:=3; -- بôFIFO؟ص£¬بشخھ×´ج¬0£¬µب´
when 3 =>
a<="00000000000";
d<="1001";
cas<='0';
state:=4;
when 4 =>
cas<='1';
ras<='1';
state:=5; -- ×ھµ½×´ج¬3
when 5 =>
ras<='0';
state:=6; -- ×ھµ½×´ج¬4
when 6 =>
temp_addr_SRAM:=temp_addr_SRAM+1; -- µطض·±نء؟¼س1
state:=1; -- ×ھµ½×´ج¬0
if temp_addr_SRAM="00000000100" then -- زرذ´آْ
is_end:=1; -- ذ´½لتّ±êض¾ضأخ»
led<='0'; -- LED °µ
state:=0;
end if;
end case;
elsif is_end = 1 then
case state is
when 0 =>
when 1 =>
cas<='1';
ras <='1';
a<=temp_addr_SRAM;
state:=2;
when 2 =>
ras<='0';
oe <='0';
w <='1';
when 3 =>
a<="00000000000";
cas<='0';
state:=4;
when 4 =>
cas<='1';
ras<='1';
data_in:= d;
when 5 =>
ras<='0';
when 6 =>
is_end:=2; -- ذ´½لتّ±êض¾ضأخ»
led<='1'; -- LED °µ
end if;
end case;
end if;
end if;
end if;
end process;
end Behavioral;
:rolleyes:
