پاسخ : مشکل در modelsim
دوست عزیز ویندوز شما چی هست 7 یا xp?
در xp مشکلی نیست
ولی در 7 باید در حالت administrator باشید دقت فرمایید
در xp مشکلی نیست
C: \ flexlm \ license.txt -MentorKG.exe and patch_dll.bat of G: \ modeltech_10.1c \ win32 can be removed , may need to run additional Licensing Wizard, click "Install a new license" and point tothe c: \ flexlm \ license.txt2) If you use the license as a service, the : -open in a text editor license.src in-line SERVER HostName XXXXXXXXXXXX 27001 instead of HostName enter the name of the company, and instead of XXX ... MAC address (NOTE: sometimes when 2 network adapters MAC address, vydavyemy by ipconfig, does notcoincide with the desired, specified in the tab "System Settings" utility G: \ modeltech_10.1c \ win32 \ lmtools.exe as Ethernet Address) - VENDOR line in the right way to specify mgcld G: \ modeltech_10.1c \ win32 -run run_me.bat, and the resulting mentor.dat move, for example, C: \ flexlm \ -enter the value of a system environment variable LM_LICENSE_FILE = 27001 @HostName (where HostName is the name of the company) run-G: \ modeltech_10.1c \ win32 \ lmtools.exe (and cocoa can be something else that isalready installed LMTools) -tab "Config Services" set the Service Name (for example, ModelSim 10.1c), set Path tothe lmgrd.exe file as G: \ modeltech_10.1c \ win32 \ lmgrd.exe, set the Path to the license file as c: \ flexlm \ mentor.dat, set the Path to the debug log file as c: \ flexlm \ mentor.log (having created an empty textmentor.log), put a check mark in the Start Server at Power Up and Use Services. Press the "SaveService" -clicking on the tab Start / Stop / Reread and start the service button "Start Server"(rebooting the computer it should start automatically) -tab "Server Diags" press "Perform Diagnostics". In the results for each features shouldappear in the string "This license can be checked out" (can not cannot!) -tab "Server Status" click "Perform Status Enquiry". In the results for each features shouldappear in the string (Total of 999 licenses issued; Total of 0 licenses in use). If you go wrong, youcan specify HostName @ 27001 (NOT c: \ flexlm \ mentor.dat!!!) in the Licensing Wizard and reboot.WARNING: When configured in several LMTools services, in tabs "Server Diags" and"Server Status" the bottom should
