مشکل در راه اندازی ماژول RC522 با برد نانو
    سلام من این برنامه رو از اینترنت گرفتم تو فیلمی که سازنده اش گذاشته بود کاملا کار میکرد ، اما من تگ ها رو که نزدیک میکنم نمیشناسه ! تو برنامه نوشته که PRESS BUTTON TO ADD NEW CARD اما نمی فهمم کدوم کلید ؟!
    #include <SPI.h>
    #include <RFID.h>
    #include <Servo.h>
    #include "pitches.h"
    #include <Wire.h>
    // definition of the RFID
    RFID rfid(10,5);
    byte rfidmipo[5] = {0xCD,0x71,0xE1,0x6F,0x32};
    byte rfidnum2[5] = {0x44,0xCB,0x94,0x5B,0x40};
    // put your other cards allowed here
    byte serNum[5];
    byte data[5];
    // definition of melodies access / welcome and rejection / error
    int access_melody[] = {NOTE_A4,0,NOTE_A4,0};
    int access_noteDurations[] = {8,8,8,8,8,4,8,8,8,8,8,4};
    int fail_melody[] = {NOTE_G2,0,NOTE_D2,0};
    int fail_noteDurations[] = {8,8,8,8,8,4};
    // define pins of the LED, Buzzer and Servo-motor
    int LED_access = 2;
    int LED_denied = 3;
    int speaker_pin = 8;
    int servoPin = 9;
    // define servo-motor
    Servo doorLock;
    void setup(){
    doorLock.attach(servoPin); // link servo motor to pin
    Serial.begin(9600); // initialize serial communication
    SPI.begin(); // initialize SPI communication for RFID
    rfid.init(); // initialize the RFID
    Serial.println("++++++++++++++++++++++++++++++++++ +++++++++++++++++++++++++++");
    Serial.println("+ RFID Doorlock (v1) +");
    Serial.println("+ Please choose from the following: +");
    Serial.println("+ - Scan your card +");
    Serial.println("+ - Press the button to add new RFID tag# +");
    delay(1000);
    pinMode(LED_access,OUTPUT);
    pinMode(LED_denied,OUTPUT);
    pinMode(speaker_pin,OUTPUT);
    pinMode(servoPin,OUTPUT);
    void loop(){
    // Create a variable for each user
    boolean rfidmipo_card = true; // my card
    if (rfid.isCard()){ // found valid card
    if (rfid.readCardSerial()){ // reads the card
    delay(1000);
    data[0] = rfid.serNum[0]; // stores the serial number
    data[1] = rfid.serNum[1];
    data[2] = rfid.serNum[2];
    data[3] = rfid.serNum[3];
    data[4] = rfid.serNum[4];
    //rfid.halt(); // RFID to standby
    if(data[0] < 16){
    Serial.print("0");
    Serial.print(data[0],HEX);
    if(data[1] < 16){
    Serial.print("0");
    Serial.print(data[1],HEX);
    if(data[2] < 16){
    Serial.print("0");
    Serial.print(data[2],HEX);
    if(data[3] < 16){
    Serial.print("0");
    Serial.print(data[3],HEX);
    if(data[4] < 16){
    Serial.print("0");
    Serial.print(data[4],HEX);
    for(int i=0; i<5; i++){
    if(data[i] != rfidmipo[i]) rfidmipo_card = false; // if not my card, poses as fake. Here you can check the other cards allowed
    Serial.println();
    if (rfidmipo_card){ // A card found
    Serial.print("Hello Michael."); //Serial.println("Hello Michael!"); // print message
    else{ // if an unknown card is scanned
    Serial.print("Card not recognized. Access denied."); // Prints message
    digitalWrite(LED_denied, HIGH); //Red LED lights up
    delay(1000); // waiting
    digitalWrite(LED_denied, LOW); // red LED goes out
    if (rfidmipo_card){// add other users with a logical or Welcome message and access permission
    Serial.print(" Access Granted.");
    digitalWrite(LED_access,HIGH); // green LED lights up
    doorLock.write(180); // door releases
    delay(5000); // waiting
    doorLock.write(0); // gate Latch
    digitalWrite(LED_access,LOW); // green LED goes out
    Serial.println();
    delay(500);
    rfid.halt();
    جدیدترین ویرایش توسط golabi2; 2016/11/01, 10:57.
    پاسخ : مشکل در راه اندازی ماژول RC522 با برد نانو
    یه نمونه کد در اینجا هست. اینم تست کنید بد نیست.
    چرا ناراحتی پاتریک!
    - از دیدنش ناراحت شدی؟
    + نه
    پس چی ناراحتت کرده
    محصولات
      ممنونم ولی اون کد هم مشکل داشت
      اشکال این برنامه به نظرم تو این قسمت هست :
      اطلاعات تگ مورد قبول باید اینجا قرار بگیره که نمیدونم چه اطلاعاتی میخواد
        منظورتون از اینکه ایراد داشت چیه؟
        یعنی هیچ خروجی نمیده؟
        چرا ناراحتی پاتریک!
        + نه
        پس چی ناراحتت کرده
        محصولات
          موقع verify کردن error داد که متاسفانه الان یادم نمیاد چی بود .
          بالاخره موفق شدم سریال یک کارت رو به برنامه معرفی کنم ، ولی نمی دونم باقی کارت ها رو چجوری معرفی کنم!
