علت error برنامه آردوینو
  • mohsen74
    • 2018/06/25
    • 163
    #1
    سلام خدمت دوستان و اساتید
    برنامه زیر رو خط :
    TCCR2B | = (1<<CS21); // Prescaler at 8.
    error می ده دلیلش چی می تونه باشه؟ سپاس از پاسخ شما
    int f_signal=50; // Hz. Frequency desired for the output sine.
    int f_pwm=62500; // Hz. PWM frequency.
    // int TOP (int) (16000000/f_pwm)-1; // Top value for the resolution selected.
    int TOP= 255;
    //int n= (TOP * 2); // Length of the array.
    int n= 510;
    //int fs = n / 0.02; // Hz. Sampling frequency.
    int i=0; // Cursor 1
    int j= n/2. +1; // Cursor 2. The voltages must be 180 degrees shifted.
    int dutycycle [510]; // Array that contains the values for the dutycycle.
    // int dutycycle [n]; // It only works if the value is defined manually.
    void setup () {
    // PIN DEFINITION.
    pinMode (9, OUTPUT);
    pinMode (10, OUTPUT);
    for (i=0; i<=n; i++)
    dutycycle[i] = (int) ( (1 + sin (2.* PI *i/n ))* (TOP/2) + 0.5);
    cli ( ); // Deactivating global interruptions
    TCNT1= 0; // Initialize counter value to zero.
    TCCR1A = (1<<COM1A1) | (1<<COM1B1) | (1<<WGM11);
    // Non-inverting, fast PWM MODE. Clear OC1A/OC1B on Compare match. Mode 14.
    TCCR1B= (1<<WGM13) | (1<<WGM12) | (1<<CS10);
    // Counts from the bottom to the top and then decreases. No prescaling.
    // ICR1= (int) (16000000 / f_pwm)-1;
    // Overflow value. It sets the resolution of the PWM.
    ICR1=TOP;
    // In case another PWM frequency is desired, this value must be changed.
    OCR1A= dutycycle[i]; // Dutycycle for pin 9
    OCR1B= dutycycle[j]; // Dutycycle for pin 10
    TCCR2A=0; // Setting the entire registers to zero.
    TCCR2B=0;
    TCCR2A | = (1<<WGM21); // Turn on Comparing Output Mode, non PWM.
    // In case it is changed, the formula below must be changed to the new prescaler.
    //OCR2A = (byte) ((16000000 / (fs * 8) ) - 1);
    // Number of pulses it counts until the interruption is activated.
    OCR2A= 78;
    TIMSK2 |= (1 << OCIE2A); // Timer 2 Output Compare Match A Interrupt Enable
    sei ( ); // Global interruption activation
    } //setup
    void loop ( ) {
    ISR (TIMER2_COMPA_vect) {
    if (i<= n-1)
    OCR1A= dutycycle [i];
    i++;
    else { i=0; } ;
    if ( j<= n-1)
    j++;
    else { j=0;}
  • S.A.T
    • 2017/07/07
    • 222
    پاسخ : علت error برنامه آردوینو
    نوشته اصلی توسط mohsen74
    برنامه زیر رو خط :
    خط 34 و 35
    سلام در دو جا اشتباهی به جای |= از | = استفاده کردید بین این دو تا علامت نباید فاصله باشه!!!!
    ارادت داریم!
    • mohsen74
      • 2018/06/25
      • 163
      سپاس مهندس برنامه کامپایل می شه ولی اون قسمت
      [COLOR=#008200][FONT=Consolas]//int n= (TOP * 2);[/FONT][/COLOR]
      تو خط پنج رو باید بصورت بدون دابل بک اسلش بذارم تا برنامه خروجی درستی بده اما تو این حالت خط 6 error می ده دلیلش چی می تونه باشه؟
      برنامه:
      [COLOR=#28282B][FONT=Consolas]int f_signal=50; // Hz. Frequency desired for the output sine.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] int f_pwm=62500; // Hz. PWM frequency.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] // int TOP (int) (16000000/f_pwm)-1; // Top value for the resolution selected.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] int TOP= 255;[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas][COLOR=#008200]int n= (TOP * 2); // Length of the array.[/COLOR][/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] int n= 510;[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] //int fs = n / 0.02; // Hz. Sampling frequency.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] int i=0; // Cursor 1[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] int j= n/2. +1; // Cursor 2. The voltages must be 180 degrees shifted.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] int dutycycle [510]; // Array that contains the values for the dutycycle.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] // int dutycycle [n]; // It only works if the value is defined manually.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] void setup () {[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] // PIN DEFINITION.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] pinMode (9, OUTPUT);[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] pinMode (10, OUTPUT);[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] for (i=0; i<=n; i++)[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] {[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] dutycycle[i] = (int) ( (1 + sin (2.* PI *i/n ))* (TOP/2) + 0.5);[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] }[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] cli ( ); // Deactivating global interruptions[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] TCNT1= 0; // Initialize counter value to zero.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] TCCR1A = (1<<COM1A1) | (1<<COM1B1) | (1<<WGM11);[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] // Non-inverting, fast PWM MODE. Clear OC1A/OC1B on Compare match. Mode 14.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] TCCR1B= (1<<WGM13) | (1<<WGM12) | (1<<CS10);[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] // Counts from the bottom to the top and then decreases. No prescaling.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] // ICR1= (int) (16000000 / f_pwm)-1;[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] // Overflow value. It sets the resolution of the PWM.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] ICR1=TOP;[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] // In case another PWM frequency is desired, this value must be changed.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] OCR1A= dutycycle[i]; // Dutycycle for pin 9[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] OCR1B= dutycycle[j]; // Dutycycle for pin 10[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] TCCR2A=0; // Setting the entire registers to zero.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] TCCR2B=0;[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] TCCR2A | = (1<<WGM21); // Turn on Comparing Output Mode, non PWM.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] TCCR2B | = (1<<CS21); // Prescaler at 8.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] // In case it is changed, the formula below must be changed to the new prescaler.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] //OCR2A = (byte) ((16000000 / (fs * 8) ) - 1);[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] // Number of pulses it counts until the interruption is activated.[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] OCR2A= 78;[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] TIMSK2 |= (1 << OCIE2A); // Timer 2 Output Compare Match A Interrupt Enable[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] sei ( ); // Global interruption activation[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] } //setup[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] void loop ( ) {[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] ISR (TIMER2_COMPA_vect) { [/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] if (i<= n-1)[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] OCR1A= dutycycle [i];[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] i++;[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] else { i=0; } ;[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] if ( j<= n-1)[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] OCR1B= dutycycle[j];[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] j++;[/FONT][/COLOR]
      [COLOR=#28282B][FONT=Consolas] else { j=0;}[/FONT][/COLOR]
      • S.A.T
        • 2017/07/07
        • 222
        سلامی دوباره!
        ما کوچیک شماییم...
        خب ببین داداش من... شما اومدی دوبار متغییری به اسم n رو تعریف کردی؟!؟!؟ خب به خاطر اینه که داره خطا می گیره!
        ارادت داریم!
        • mohsen74
          • 2018/06/25
          • 163
          برنامه زیر رو خط :
          TCCR1 = 0 << PWM1A | 0 << COM1A0 | 1 << CS10;
          [URL=https://www.eca.ir/forums/usertag.php?do=list&action=hash&hash=define]#define[/URL]  F_CPU 8000000
          int pwm = 1;
          int potinput = A2;
          int feedbackinput = A3;
          int potinputval;
          int feedbackinputval;
          int pwmval;
          void setup() {
            TCCR0A = 2 << COM0A0 | 2 << COM0B0 | 3 << WGM00;
            TCCR0B = 0 << WGM02 | 1 << CS00;
            GTCCR = 1 << PWM1B | 2 << COM1B0;
            pinMode(pwm, OUTPUT);
            pinMode(potinput, INPUT);
            pinMode(feedbackinput, INPUT);
            digitalWrite(pwm, LOW);
            pwmval = 0;
          void loop() {
            potinputval = analogRead(potinput);
            potinputval = map(potinputval, 1023, 0, 255, 0);
            feedbackinputval = analogRead(feedbackinput);
            feedbackinputval = map(feedbackinputval, 1023, 0, 255, 0);
            while (potinputval > feedbackinputval) {
              if (pwmval == 230) {
              else {
                pwmval = pwmval + 1;
                analogWrite(pwm, pwmval);
            while (potinputval < feedbackinputval) {
              if (pwmval == 0) {
              else {
                pwmval = pwmval - 1;
          [RIGHT][COLOR=#28282B][FONT=Yekan][/FONT][/COLOR][/RIGHT]
