Learn how to wire the Graphic LCD 84x48 to Arduino Pro Mini 5V in a few simple steps. The primary components for this circuit are: Arduino Pro Mini 328 - 5V/16MHz and Nokia 5110. Drag and drop these components onto the canvas, and instantly get a list of secondary parts, wiring instructions and a test code for your circuit. Try it for free.
با احترام
98/4/16
من این لینکی که گذاشتید برنامشو امتحان کردم ولی lcd هیچ واکنشی نشون نداده و خاموش باقی موند ممنکنه lcd سوخته باشه؟
I have just started to try using the Nokia 5110 LCD. The version I have is the red pCB which came from here: http://www.ebay.com.au/itm/170817974147?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649 The pin arrangement is slightly different from most but I don’t think the problems lie there. The code comes from a blog and can be downloaded from I don’t think the code is really the problem. The sketch does work. It is an hours/minutes elapsed timer display with a neat little bar graph be...
