مشکل در آپلود برنامه روی آردوینو
    من قراره با کیپد،LCD و ماژول رله،یه همچین قفلی درست کنم
    مشکل اینه که در زمان آپلود،خطا میده و آپلود نمیشه
    حالا از شما درخواست دارم تا نگاهی به این بندازید و مشکل رو رفع کنید
    #include <Password.h>#include <LiquidCrystal_I2C.h>
    #include <Keypad.h>
    //Most common adresses PCF8574 = 0x20, PCF8574A = 0x38,PCF8574AT = 0x3F
    //PCF8574T = 0x27
    #define I2C_ADDR 0x27
    #define BACKLIGHT_PIN 3
    #define En_pin 2
    #define Rw_pin 1
    #define Rs_pin 0
    #define D4_pin 4
    #define D5_pin 5
    #define D6_pin 6
    #define D7_pin 7
    int buzzer = 3;
    int relay = 9;
    const int buttonPin = 5;
    int buttonState = 0;
    Password password = Password( "1654" );
    const byte ROWS = 4; // Four rows
    const byte COLS = 4; // Four columns
    // Define the Keymap
    char keys[ROWS][COLS] = {
    {'1','2','3','A',},
    {'4','5','6','B',},
    {'7','8','9','C',},
    {'*','0','#','D',}
    // Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
    byte rowPins[ROWS] = {
    12, 13, A5, A4}; //connect to the row pinouts of the keypad
    byte colPins[COLS] = {
    A3, A2, A1, A0};
    // Create the Keypad
    Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
    void setup(){
    pinMode(buttonPin, INPUT);
    pinMode(relay, OUTPUT);
    pinMode(buzzer, OUTPUT);
    lcd.begin (16,2);
    digitalWrite(relay, HIGH);
    lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
    lcd.setBacklight(HIGH);
    lcd.print(" BlueCore Tech ");
    lcd.setCursor(0,1);
    lcd.print(" Acces Control ");
    delay(5000);
    lcd.clear();
    lcd.print("Acces Code: ");
    Serial.begin(9600);
    keypad.addEventListener(keypadEvent);
    keypad.setDebounceTime(100);
    void loop(){
    keypad.getKey();
    buttonState = digitalRead(buttonPin);
    if (buttonState == HIGH) {
    lcd.clear();
    void keypadEvent(KeypadEvent eKey){
    switch (keypad.getState()){
    case PRESSED:
    digitalWrite(buzzer, HIGH);
    delay(100);
    digitalWrite(buzzer, LOW);
    switch (eKey){
    case 'A': guessPassword(); break;
    lcd.print("*");
    default:
    password.append(eKey);
    void guessPassword(){
    LiquidCrystal_I2C
    lcd(I2C_ADDR, En_pin,Rw_pin,Rs_pin,D4_pin,D5_pin,D6_pin,D7_pin);
    if (password.evaluate()){
    digitalWrite(relay, LOW);
    lcd.setCursor(0,0);
    lcd.print("##CORRECT CODE##");
    lcd.setCursor(4,1);
    lcd.print("WELCOME!");
    delay(10000);
    password.reset();
    lcd.clear();
    else{
    lcd.setCursor(0,0);
    lcd.print("###WRONG CODE###");
    password.reset();
    lcd.setCursor(2,1);
    lcd.print("ACCES DENIED");
    delay(3000);
    lcd.clear();
    خطا:
    Arduino: 1.8.15 (Windows 8.1), Board: "Arduino Uno"
    D:\Electronic\Arduino\Project\LCD_kepad_reley\FMDF75LIOKBSZ60\FMDF75LIOKBSZ60.ino: In function 'void setup()':
    FMDF75LIOKBSZ60:52:5: error: 'lcd' was not declared in this scope
    lcd.begin (16,2);
    FMDF75LIOKBSZ60:54:39: error: 'POSITIVE' was not declared in this scope
    D:\Electronic\Arduino\Project\LCD_kepad_reley\FMDF75LIOKBSZ60\FMDF75LIOKBSZ60.ino: In function 'void loop()':
    FMDF75LIOKBSZ60:73:5: error: 'lcd' was not declared in this scope
    lcd.clear();
    D:\Electronic\Arduino\Project\LCD_kepad_reley\FMDF75LIOKBSZ60\FMDF75LIOKBSZ60.ino: In function 'void keypadEvent(KeypadEvent)':
    FMDF75LIOKBSZ60:86:5: error: 'lcd' was not declared in this scope
    lcd.print("*");
    D:\Electronic\Arduino\Project\LCD_kepad_reley\FMDF75LIOKBSZ60\FMDF75LIOKBSZ60.ino: In function 'void guessPassword()':
    FMDF75LIOKBSZ60:95:65: error: no matching function for call to 'LiquidCrystal_I2C::LiquidCrystal_I2C(int, int, int, int, int, int, int, int)'
    In file included from D:\Electronic\Arduino\Project\LCD_kepad_reley\FMDF75LIOKBSZ60\FMDF75LIOKBSZ60.ino:9:0:
    F:\Arduino\libraries\LiquidCrystal_I2C-master/LiquidCrystal_I2C.h:57:3: note: candidate: LiquidCrystal_I2C::LiquidCrystal_I2C(uint8_t, uint8_t, uint8_t)
    LiquidCrystal_I2C(uint8_t lcd_Addr,uint8_t lcd_cols,uint8_t lcd_rows);
    F:\Arduino\libraries\LiquidCrystal_I2C-master/LiquidCrystal_I2C.h:57:3: note: candidate expects 3 arguments, 8 provided
    F:\Arduino\libraries\LiquidCrystal_I2C-master/LiquidCrystal_I2C.h:55:7: note: candidate: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(const LiquidCrystal_I2C&)
    class LiquidCrystal_I2C : public Print {
    F:\Arduino\libraries\LiquidCrystal_I2C-master/LiquidCrystal_I2C.h:55:7: note: candidate expects 1 argument, 8 provided
    F:\Arduino\libraries\LiquidCrystal_I2C-master/LiquidCrystal_I2C.h:55:7: note: candidate: constexpr LiquidCrystal_I2C::LiquidCrystal_I2C(LiquidCrystal_I2C&&)
    exit status 1
    This report would have more information with
    "Show verbose output during compilation"
    option enabled in File -> Preferences.
    پاسخ : مشکل در آپلود برنامه روی آردوینو
    نوشته اصلی توسط S.Malaki نمایش پست ها
    #include <Keypad.h>
    //PCF8574T = 0x27
    #define En_pin 2
    #define Rw_pin 1
    #define Rs_pin 0
    #define D4_pin 4
    #define D5_pin 5
    #define D6_pin 6
    #define D7_pin 7
    int buzzer = 3;
    int relay = 9;
    {'1','2','3','A',},
    {'4','5','6','B',},
    {'7','8','9','C',},
    {'*','0','#','D',}
    A3, A2, A1, A0};
    void setup(){
    lcd.begin (16,2);
    lcd.setCursor(0,1);
    delay(5000);
    lcd.clear();
    Serial.begin(9600);
    void loop(){
    keypad.getKey();
    lcd.clear();
    case PRESSED:
    delay(100);
    switch (eKey){
    lcd.print("*");
    default:
    LiquidCrystal_I2C
    lcd.setCursor(0,0);
    lcd.setCursor(4,1);
    delay(10000);
    password.reset();
    lcd.clear();
    else{
    lcd.setCursor(0,0);
    password.reset();
    lcd.setCursor(2,1);
    delay(3000);
    lcd.clear();
    خطا:
    lcd.begin (16,2);
    lcd.clear();
    lcd.print("*");
    exit status 1
    شما از آبجکت lcd توی نقاط مختلف برنامه استفاده کردید ولی این آبجکت رو در تابع guessPassword تعریفش کردید که در دسترس بقیه برنامه نیست. برای درست شدنش باید تعریفشو منتقل کنید یه جایی که توی همه نقاط در دسترس باشه؛ مثلا منتقلش کنید به خط ۴۱ این کدی که بالا گذاشتید.
      خیلی ممنون از جوابتون
      واقعیتش من اصلا برنامه نویسی نمی دونم و از برنامه رو هم از اینجا برداشتم
      اگه ممکنه لطف کنید و تغییرات رو انجام بدبد
      جدیدترین ویرایش توسط S.Malaki; 2022/01/10, 13:31.
        خط ۹۵ و ۹۶ رو به ۴۱ منتقل کنید.
          چنین خطایی داد
          expected constructor, destructor, or type conversion before '(' token
            چنین خطایی داد
            این خطا رو به چه خطی میده؟
            این کد رو تست کنید:
            #include <Keypad.h>
            // Most common adresses PCF8574 = 0x20, PCF8574A = 0x38,PCF8574AT = 0x3F
            // PCF8574T = 0x27
            #define En_pin 2
            #define Rw_pin 1
            #define Rs_pin 0
            #define D4_pin 4
            #define D5_pin 5
            #define D6_pin 6
            #define D7_pin 7
            int buzzer = 3;
            int relay = 9;
            Password password = Password("1654");
            {'1','2','3','A',},
            {'4','5','6','B',},
            {'7','8','9','C',},
            {'*','0','#','D',}
            byte rowPins[ROWS] = {12, 13, A5, A4}; // connect to the row pinouts of the keypad
            byte colPins[COLS] = {A3, A2, A1, A0};
            Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS);
            // LCD
            LiquidCrystal_I2C lcd = LiquidCrystal_I2C(I2C_ADDR, En_pin, Rw_pin, Rs_pin, D4_pin, D5_pin, D6_pin, D7_pin);
            void setup()
            lcd.begin(16, 2);
            lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
            lcd.setCursor(0, 1);
            delay(5000);
            lcd.clear();
            Serial.begin(9600);
            void loop()
            keypad.getKey();
            lcd.clear();
            case PRESSED:
            delay(100);
            switch (eKey)
            case 'A':
            guessPassword();
            break;
            lcd.print("*");
            default:
            lcd.setCursor(0, 0);
            lcd.setCursor(4, 1);
            delay(10000);
            password.reset();
            lcd.clear();
            else
            password.reset();
            lcd.setCursor(2, 1);
            delay(3000);
            lcd.clear();
            جدیدترین ویرایش توسط hossein.m98; 2022/01/10, 15:05.
              خیلی ازتون ممنونم که وقت گذاشتید
              حالا با برنامه شما تست کردم و این خطا رو میده
              FMDF75LIOKBSZ60:44:107: error: no matching function for call to 'LiquidCrystal_I2C::LiquidCrystal_I2C(int, int, int, int, int, int, int, int)'
              In file included from D:\Electronic\Arduino\Project\LCD_kepad_reley\FMDF75LIOKBSZ60\FMDF75LIOKBSZ60.ino:2:0:
              FMDF75LIOKBSZ60:54:7: error: 'class LiquidCrystal_I2C' has no member named 'setBacklightPin'; did you mean 'setBacklight'?
              setBacklight
              FMDF75LIOKBSZ60:54:38: error: 'POSITIVE' was not declared in this scope
              exit status 1
              Invalid library found in F:\Arduino\libraries\arduino: no headers files (.h) found in F:\Arduino\libraries\arduino
              Invalid library found in F:\Arduino\libraries\emonTxFirmware: no headers files (.h) found in F:\Arduino\libraries\emonTxFirmware
              Invalid library found in F:\Arduino\libraries\OneWire: no headers files (.h) found in F:\Arduino\libraries\OneWire
              Invalid library found in F:\Arduino\libraries\RFM12B_Simple: no headers files (.h) found in F:\Arduino\libraries\RFM12B_Simple
              جدیدترین ویرایش توسط S.Malaki; 2022/01/10, 15:33.
                setBacklight
                exit status 1
                دوست عزیز از اینجا به بعدش دیگه مشکل از قواعد زبان CPP نیست که من بتونم کمکتون کنم. کد رو از هر کجا که برداشتید، احتمالا غلطه، یا شاید از ورژن*های خاصی از کتابخونه ها استفاده میکنه که شما استفاده نمیکنید. مثلا توی ارور اول داره میگه فراخوانی LiquidCrystal_I2C به اون شکل که باید نیست؛ یعنی مشکلی توی تعداد و نوع آرگومان ها وجود داره.
                بهتره یا دنبال یک پروژه دیگه باشید، یا ببینید همین پروژه از چه ورژن هایی استفاده کرده و شما هم دقیقا از همونا استفاده کنید.
                  سلام مجدد
                  بازم اومدم با یه دردسر جدید
                  این کد:
                  #include <Wire.h> #include <LiquidCrystal_I2C.h>
                  #include <Keypad.h>
                  #define Password_Length 8
                  int signalPin = 12;
                  char Data[Password_Length];
                  char Master[Password_Length] = "123A456";
                  byte data_count = 0, master_count = 0;
                  bool Pass_is_good;
                  char customKey;
                  char hexaKeys[ROWS][COLS] = {
                  {'1', '2', '3', 'A'},
                  {'4', '5', '6', 'B'},
                  {'7', '8', '9', 'C'},
                  {'*', '0', '#', 'D'}
                  byte rowPins[ROWS] = {9, 8, 7, 6};
                  byte colPins[COLS] = {5, 4, 3, 2};
                  Keypad customKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
                  LiquidCrystal_I2C lcd(0x27, 16, 2);
                  void setup(){
                  lcd.init();
                  lcd.backlight();
                  pinMode(signalPin, OUTPUT);
                  void loop(){
                  lcd.setCursor(0,0);
                  lcd.print("Enter Password:");
                  customKey = customKeypad.getKey();
                  if (customKey){
                  Data[data_count] = customKey;
                  lcd.setCursor(data_count,1);
                  lcd.print(Data[data_count]);
                  data_count++;
                  if(data_count == Password_Length-1){
                  lcd.clear();
                  if(!strcmp(Data, Master)){
                  lcd.print("Correct");
                  digitalWrite(signalPin, HIGH);
                  delay(5000);
                  digitalWrite(signalPin, LOW);
                  else{
                  lcd.print("Incorrect");
                  delay(1000);
                  lcd.clear();
                  clearData();
                  void clearData(){
                  while(data_count !=0){
                  Data[data_count--] = 0;
                  return;
                  و این خطا رو میده:
                  F:\Arduino\libraries\Keypad\utility\Key.cpp: In constructor 'Key::Key(char)':
                  F:\Arduino\libraries\Keypad\utility\Key.cpp:43:2: error: 'kcode' was not declared in this scope
                  kcode = -1;
                  F:\Arduino\libraries\Keypad\utility\Key.cpp: At global scope:
                  F:\Arduino\libraries\Keypad\utility\Key.cpp:49:79: error: no 'void Key::key_update(char, KeyState, boolean)' member function declared in class 'Key'
                  void Key::key_update (char userKeyChar, KeyState userState, boolean userStatus) {
                  exit status 1
                  Error compiling for board Arduino Uno.
                  بی زحمت اگه بشه عیوب این کد رو هم بگید
                  جدیدترین ویرایش توسط S.Malaki; 2022/01/10, 18:28.
                    درود
                    این کد رو تست کنید :
                      متاسفانه چنین اروری میده
                        کد موجود در لینک https://electropedia.ir/code/61dc4fbfe849f رو روی آردوینو Uno تست گرفتم بدون مشکل اپلود شد
                          نوشته اصلی توسط electropedia نمایش پست ها
                          بله یه چند تا کد دیگه رو تست کردم اما همین ارور رو داد،حذفش کردم دوباره نصب کنم.
                            از آقای hossein.m98 و electropedia بابت وقتی که گذاشتن،ممنونم
                            برنامه آردوینو رو یه بار کامل حذف و نصبش کردم و درست شد.
