با سلام و درود
امروز توی یکی از سایت ها دوتا کتاب دیدم که جالب بودن گفتم اینجا هم که تازه عضو شدم نشرش کنم
دانلود کتاب ها :
http://microdesigner.ir/%D8%AF%D8%A7%D9%86%D9%84%D9%88%D8%AF-%DA%A9%D8%AA%D8%A7%D8%A8-%D8%B0%D8%AE%DB%8C%D8%B1%D9%87-%DA%A9%D9%86%D9%86%D8%AF%D9%87-%D9%87%D8%A7%DB%8C-usb-%DA%A9%D8%AA%D8%A7%D8%A8-%D8%AA%D8%B4%D8%B1%DB%8C/
USB Mass Storage
Designing and Programming
Devices and Embedded Hosts
Interfaces, Protocols, and Technologies
Designing and programming a USB mass-storage device or embedded USB
host involves a variety of interfaces, protocols, and structures.
Every USB mass-storage device must support two interfaces:
• A USB device interface to enable the device to communicate with a PC
or other USB host.
• An interface between the device’s microcontroller or other CPU and the
storage media. Flash-memory cards typically use the Serial Peripheral
Interface (SPI), MultiMediaCard bus, SD-Card bus, or a bus derived
from the ATA interface or PC-Card bus. Hard drives typically use the
ATA parallel interface.
A USB mass-storage device must implement these protocols and structures:
• Generic USB protocol. Every USB device must respond to requests sent
by the USB host and other events on the bus.
• USB mass-storage protocol. Every USB mass-storage device must detect
and respond to requests that are specific to the USB mass-storage class.
• SCSI commands. USB hosts access mass-storage devices via commands
originally developed for devices that use the Small Computer Systems
Interface (SCSI).
• Media-specific protocol. The storage media’s controller typically supports
a command set for accessing the media’s contents. Many flash-memory
cards use the MultiMediaCard protocol or the SD Card protocol. Hard
drives use the ATA protocol.
Reading and writing data to a mass-storage device also involves understanding
logical structures in the media:
• Media structure. Program code accesses the storage area in drives as a
series of logical blocks, or sectors. Dedicated areas in the media store
information about the logical blocks and other logical structures in the
media.
• File system. If the device firmware reads or writes to files on its own,
rather than via a USB host, the device must implement a file system such
as FAT16 or FAT32.
This book shows how to put all of these interfaces, protocols, and structures
to work in a USB mass-storage device. The book assumes you have a basic
familiarity with microcontroller programming and interfacing. For more
about USB, I recommend my book, USB Complete: Everything You Need to
Develop Custom USB Peripherals.
About the Code
This book include code examples written for the Microchip PIC18F4550
microcontroller using Microchip’s MPLAB® C18 C compiler. On my website
(web site in book) you can find links to complete mass-storage firmware
for this chip and example mass-storage firmware for other microcontrollers.
فقط چون کپی برداری از سایت ناشر بدون لینک دادن ممنون بود من لینکش را گذاشتم تاخودتون از سایت دانلود کنید . Designing and Programming
or other USB host.
Interface (SCSI).
media.
as FAT16 or FAT32.
About the Code
دانلود کتاب ها :
