من یه برنامه ی ماشین حساب می خوام با bascame
فقط چهار عمل اصلی انجام بده
1+2*3-4
123*+4-
$regfile = "m32def.dat"
$crystal = 8000000
$sim
Config Lcdpin = Pin , Db4 = Portc.0 , Db5 = Portc.1 , Db6 = Portc.2 , Db7 = Portc.3 , E = Portc.4 , Rs = Portc.5
Config Lcd = 16 * 2
Config Kbd = Portb , Debounce = 50 , Delay = 255
Dim A As Byte , B As Word , C As Word
Dim S As Word , P As Word , T As Word , K As Word
Dim O As String * 1
S = 0 : K = 0 : P = 1 : T = 1
Cls
Home
Main:
B = 0
A = Getkbd()
A = Lookup(a , Read_key)
If A > 15 Then Goto Main
Select Case A
Case Is < 10:
B = B * 10
B = B + A
Lcd B
Wait 1
Case 15:
B = B / 10
Shiftcursor Left
Lcd " "
Shiftcursor Left
If B = 0 Then Goto Main
Case Is > 9:
If A = 10 Then O = "/"
If A = 11 Then O = "*"
If A = 12 Then O = "+"
If A = 13 Then O = "-"
Goto 2
End Select
2:
A = Getkbd()
Select Case A
Case Is < 10:
C = C * 10
C = C + A
Lcd C
Wait 1
Case 15:
C = C / 10
Shiftcursor Left
Lcd " "
Shiftcursor Left
If C = 0 Then Goto Main
Case Is > 9:
If O = "*" Then
S = A * C
End If
If O = "/" Then
S = A / C
End If
If O = "+" Then
S = A + C
End If
If O = "-" Then
S = A - C
end if
Cls
Lcd S
Wait 1
A = 0
C = 0
S = 0
Goto Main
End Select
End 'end program
Read_key:
Data 1 , 2 , 3 , 10 , 4 , 5 , 6 , 11 , 7 , 8 , 9 , 12 , 13 , 0 , 14 , 15
