راستش من می خوام چندتا میکرو را از طریق rs485 شبکه کنم یکم برنامه نوشتم اما درست کار نمیکنه
لطفا کمک کنید
این برنامه اسلیو
This program was produced by the
CodeWizardAVR V1.24.4 Standard
Automatic Program Generator
© Copyright 1998-2004 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
e-mail
ffice@hpinfotech.com
Project :
Version :
Date : 6/23/2009
Author : R.G
Company : R.G
Comments:
Chip type : ATmega16
Program type : Application
Clock frequency : 8.000000 MHz
Memory model : Small
External SRAM size : 0
Data Stack size : 256
#include <mega16.h>
#include <delay.h>
// Alphanumeric LCD Module functions
#include <lcd.h>
#asm
.equ __lcd_port=0x1B ;PORTA
#endasm
//slave address
#define sa 1
//protocol max lenght
#define prtocol_max_lenght 32
// send recieve port
#define src PORTB.0
// number of sync byte
#define n_sync 2
unsigned char a[prtocol_max_lenght];
unsigned char text[32]={'a','r','m',' a','n',' ','k','o','n' ;};
//declare function
unsigned char slave_recieve(unsigned char data[prtocol_max_lenght]);
void slave_send(unsigned char data[prtocol_max_lenght],unsigned char tedad);
#define RXB8 1
#define TXB8 0
#define UPE 2
#define OVR 3
#define FE 4
#define UDRE 5
#define RXC 7
#define FRAMING_ERROR (1<<FE)
#define PARITY_ERROR (1<<UPE)
#define DATA_OVERRUN (1<<OVR)
#define DATA_REGISTER_EMPTY (1<<UDRE)
#define RX_COMPLETE (1<<RXC)
// USART Receiver buffer
#define RX_BUFFER_SIZE 8
char rx_buffer[RX_BUFFER_SIZE];
#if RX_BUFFER_SIZE<256
unsigned char rx_wr_index,rx_rd_index,rx_counter;
#else
unsigned int rx_wr_index,rx_rd_index,rx_counter;
#endif
// This flag is set on USART Receiver buffer overflow
bit rx_buffer_overflow;
// USART Receiver interrupt service routine
interrupt [USART_RXC] void usart_rx_isr(void)
char status;
status=UCSRA;
if ((status & (FRAMING_ERROR | PARITY_ERROR | DATA_OVERRUN))==0)
slave_recieve(a);
#ifndef _DEBUG_TERMINAL_IO_
// Get a character from the USART Receiver buffer
#define _ALTERNATE_GETCHAR_
#pragma used+
char getchar(void)
char data;
while (rx_counter==0);
data=rx_buffer[rx_rd_index];
if (++rx_rd_index == RX_BUFFER_SIZE) rx_rd_index=0;
#asm("cli"
--rx_counter;
#asm("sei"
return data;
#pragma used-
#endif
// USART Transmitter buffer
#define TX_BUFFER_SIZE 8
char tx_buffer[TX_BUFFER_SIZE];
#if TX_BUFFER_SIZE<256
unsigned char tx_wr_index,tx_rd_index,tx_counter;
#else
unsigned int tx_wr_index,tx_rd_index,tx_counter;
#endif
// USART Transmitter interrupt service routine
interrupt [USART_TXC] void usart_tx_isr(void)
if (tx_counter)
--tx_counter;
UDR=tx_buffer[tx_rd_index];
if (++tx_rd_index == TX_BUFFER_SIZE) tx_rd_index=0;
// Write a character to the USART Transmitter buffer
#define _ALTERNATE_PUTCHAR_
#pragma used+
void putchar(char c)
while (tx_counter == TX_BUFFER_SIZE);
#asm("cli"
if (tx_counter || ((UCSRA & DATA_REGISTER_EMPTY)==0))
tx_buffer[tx_wr_index]=c;
if (++tx_wr_index == TX_BUFFER_SIZE) tx_wr_index=0;
++tx_counter;
else
UDR=c;
#asm("sei"
#pragma used-
#endif
// Standard Input/Output functions
#include <stdio.h>
void main(void)
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
//initial value of src=PORTB.0=0
PORTB=0x00;
DDRB=0xFF;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
TIMSK=0x00;
// USART initialization
// Communication Parameters: 9 Data, 1 Stop, Odd Parity
// USART Receiver: On
// USART Transmitter: On
// USART Mode: Asynchronous
// USART Baud rate: 500k
// U2X=1
// MPCM=1
UCSRA=0x03;
UCSRB=0xDC;
UCSRC=0xB6;
UBRRH=0x00;
UBRRL=0x33;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
// LCD module initialization
lcd_init(16);
// Global enable interrupts
#asm("sei"
src=0;
while (1)
// Place your code here
unsigned char i, tedad,con;
if(UDR==sa)
UCSRA&=0xfe;
while(!(UCSRA&0B10000000));
con=UDR;
if(con==0x02)
lcd_putsf("command"
//delay_us(100);
//slave_send(text,9);
UCSRA|=0x01;
return 1;
if (con == 0x01)
tedad=UDR;
for(i=0;i<tedad;i++)
data[i]=UDR;
lcd_puts(a);
UCSRA|=0x01;
return 1;
unsigned char i=0;
src=1; // sender
// sync
for(i=0;i<n_sync;++i)
UCSRB &=0xfe;
UDR=0xff;
while( !(UCSRA & 0b00100000)); //waite until transmition complete
UCSRB &=0xfe;
UDR=tedad;
for (i=0;i<tedad;i++)
UCSRB &=0xfe;
UDR=data[i];
src=0; //receiver
لطفا کمک کنید
این برنامه اسلیو
ffice@hpinfotech.comProject :
Version :
Date : 6/23/2009
Author : R.G
Company : R.G
Comments:
#include <mega16.h>
#include <delay.h>
#include <lcd.h>
#asm
#endasm
//slave address
#define sa 1
#define src PORTB.0
#define n_sync 2
//declare function
#define RXB8 1
#define TXB8 0
#define UPE 2
#define OVR 3
#define FE 4
#define UDRE 5
#define RXC 7
#else
#endif
char status;
status=UCSRA;
slave_recieve(a);
#pragma used+
char getchar(void)
char data;
#asm("cli"
--rx_counter;
#asm("sei"
return data;
#pragma used-
#endif
#else
#endif
if (tx_counter)
--tx_counter;
#pragma used+
#asm("cli"
++tx_counter;
else
UDR=c;
#asm("sei"
#pragma used-
#endif
#include <stdio.h>
void main(void)
PORTA=0x00;
DDRA=0x00;
PORTB=0x00;
DDRB=0xFF;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0x00;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
TIMSK=0x00;
// U2X=1
// MPCM=1
UCSRA=0x03;
UCSRB=0xDC;
UCSRC=0xB6;
UBRRH=0x00;
UBRRL=0x33;
ACSR=0x80;
SFIOR=0x00;
lcd_init(16);
#asm("sei"
src=0;
while (1)
if(UDR==sa)
UCSRA&=0xfe;
con=UDR;
if(con==0x02)
lcd_putsf("command"
;//delay_us(100);
UCSRA|=0x01;
return 1;
if (con == 0x01)
tedad=UDR;
data[i]=UDR;
lcd_puts(a);
UCSRA|=0x01;
return 1;
unsigned char i=0;
src=1; // sender
// sync
UCSRB &=0xfe;
UDR=0xff;
UCSRB &=0xfe;
UDR=tedad;
UCSRB &=0xfe;
UDR=data[i];
src=0; //receiver
