salam.....
projeye fareghotahsilim sakhte ye CALLER ID ke ye seri emkanate dige be joz namayeshe shomare telephon bayad dashte bashe ke yekish namayeshe zamane...
ba inke madaram to proteus kamelan dorost javab mide,nemidoonam ke chera sakhtafzaram javab nemide....
kasayee ke az in madar javab gereftan,khahesh mikonam rahnamayeem konan....
TNX...
TNX...
Chip type : ATmega16
Program type : Application
Clock frequency : 8.000000 MHz
Memory model : Small
External SRAM size : 0
Data Stack size : 256
#include <mega16.h>
#include <delay.h>
#include<stdio.h>
// I2C Bus functions
#asm
.equ __i2c_port=0x1B ;PORTA
.equ __sda_bit=0
.equ __scl_bit=1
#endasm
#include <i2c.h>
// DS1307 Real Time Clock functions
#include <ds1307.h>
// Alphanumeric LCD Module functions
#asm
.equ __lcd_port=0x18 ;PORTB
#endasm
#include <lcd.h>
unsigned char hour,minute,second;
char lcd1[16],lcd2[16];
unsigned char year,month,day;
unsigned char key,keystate;
struct days{ char d[4];} daysofweek[7]={{"Sun"},{"Mon"},{"Tue"},{"Wed"},{"Thu"},{"Fri"},{"Sat"}};
flash unsigned char Table[13]={0,0,3,3,6,1,4,6,2,5,0,3,5};
flash unsigned char miltable[6][12]={
{20,19,19,19,20,20,21,21,21,21,20,20},
{10,11,10,12,11,11,10,10,10,9,10,10},
{19,18,20,20,21,21,22,22,22,22,21,21},
{11,12,10,11,10,10,9,9,9,8,9,9},
{20,19,20,20,21,21,22,22,22,22,21,21},
{10,11,9,11,10,10,9,9,9,8,9,9}};
struct date{
unsigned char day;
unsigned char month;
unsigned char year;
struct date shmdate,mildate ;
void miltoshmcv(unsigned char ym,unsigned char mm,unsigned char dm)
unsigned char k,t1,t2;
k=ym%4;
if(k==3)
k=2;
k*=2;
t1=miltable[k][mm-1];
t2=miltable[k+1][mm-1];
if(mm<3 || (mm==3 && dm<=miltable[k][mm-1]))
shmdate.year = ym + 78;
else
shmdate.year = ym + 79;
if(dm<=t1)
shmdate.day=dm+t2;
shmdate.month=(mm+8)%12+1;
else
shmdate.day=dm-t1;
shmdate.month=(mm+9)%12+1;
char IsLeapYear(int Year)
Year=Year&0x0003;
if(Year==0)
return 1;
else
return 0;
char GetDayofWeek(unsigned char CurrentYear,unsigned char Month,unsigned char Day)
unsigned int TempYear;
unsigned char AccValue;
TempYear = 1990;/*Comparation start with year 1990*/
AccValue = 0;/*Init AccValue to 0*/
/* If TempYear is a leap year AccValue +2, else AccValue+1 */
while(TempYear != (CurrentYear+2000))
AccValue++;
if(IsLeapYear(TempYear))
AccValue++;
TempYear++;
if(Month > 2)
if(IsLeapYear(TempYear)==1)
AccValue++;
AccValue += Table[Month];
AccValue += Day;
AccValue= AccValue%7;
return (AccValue);
void main(void)
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0xFF;
DDRD=0x00;
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Clock value: Timer 1 Stopped
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Clock value: Timer 2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
TIMSK=0x00;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
// I2C Bus initialization
i2c_init();
// DS1307 Real Time Clock initialization
// Square wave output on pin SQW/OUT: Off
// SQW/OUT pin state: 0
rtc_init(0,0,0);
// LCD module initialization
lcd_init(16);
while (1)
rtc_get_time(&hour,&minute,&second);
rtc_get_date(&day,&month,&year);
miltoshmcv(year,month,day);
key=PIND & 0b11111100;
if (key!=keystate)
if (key!=0b11111100)
if (key==0xF8) //if key 1 pressed set the year
year++;
if (year==100)
year=0;
if (key==0xF4) //if key 2 pressed set the month
month++;
if (month==13)
month=1;
if (key==0xEC) //if key 3 pressed set the day
day++;
if (day==32)
day=1;
if (key==0xDC) //if key 4 pressed set the hour
hour++;
if (hour==24)
hour=0;
if (key==0xBC) //if key 5 pressed set the minute
minute++;
if (minute==60)
minute=0;
if (key==0x7C) //if key 6 pressed set the second
second++;
if (second==60)
second=0;
rtc_set_time(hour,minute,second);
rtc_set_date(day,month,year);
keystate=key;
}else
keystate=0b11111100;
//sprintf(lcd1,"%02u:%02u:%02u",hour,minute,second,);
//sprintf(lcd2,"%02u/%02u/%02u",shmdate.year,shmdate.month,shmdate.day);
sprintf(lcd1,"%02u/%02u/%02u ",shmdate.year,shmdate.month,shmdate.day);
sprintf(lcd2,"%s %02u:%02u:%02u",daysofweek[GetDayofWeek(year,month,day)].d,hour,minute,second);
lcd_clear();
lcd_gotoxy(0,0);
lcd_puts(lcd1);
lcd_gotoxy(0,1);
lcd_puts(lcd2);
delay_ms(100);
[img][/img]
