ماژول قطب نما zcc210n-I2C
    سلام به همه مهندسین کسی روال راه اندازی بلده بزاره وسط.....
    پاسخ : ماژول قطب نما zcc210n-I2C
    Declare Function Cmps() As Word
    $regfile = "m16def.dat"
    $framesize = 42
    $swstack = 32
    $hwstack = 32
    $crystal = 8000000
    $baud = 9600
    Config I2cdelay = 10
    Config Sda = Portc.1
    Config Scl = Portc.0
    Config Lcdpin = Pin , Db7 = Porta.0 , Db6 = Porta.1 , Db5 = Porta.2 , Db4 = Porta.3 , E = Porta.5 , Rs = Porta.4
    Config Lcd = 20 * 4
    Config Portd.5 = Output
    Config Pind.6 = Output
    Config Portb.0 = Input
    Dim Compass As Word , F As Word , R As Word
    Dim V As Byte , D As Word , S As Word
    F = &H01FF
    Ddrb.0 = 0 : Portb.0 = 1
    Declare Sub Calib
    Cls
    Wait 3
    Set Portd.5
    I2cinit
    Print "Compass Test Program"
    I2cstart
    I2cwbyte &H42 'adrese ghotbnama
    I2cwbyte &H76 'adrese ersale pey dar peye etlaat
    I2cstop
    Waitms 20
    V = 1
    Do
    If Pinb.0 = 0 Then Goto Calib
    Compass = Cmps()
    R = F And Compass ' eight to zero
    D = &H0E00 And Compass 'eleventh/tenth/ninth
    S = &HC000 And Compass
    Cls
    If D = &H0000 Then '0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    Lcd "N"
    Elseif D = &H0200 Then '0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    Lcd "NE" ' ------- ------- ------- -------
    Elseif D = &H0400 Then ' 1
    Lcd "E"
    Elseif D = &H0600 Then
    Lcd "SE"
    Elseif D = &H0800 Then
    Lcd "S"
    Elseif D = &H0A00 Then
    Lcd "SW"
    Elseif D = &H0C00 Then
    Lcd "W"
    Elseif D = &H0E00 Then
    Lcd "NW"
    End If
    Print Hex(compass)
    Locate 2 , 1
    Lcd Compass
    Print Hex(r)
    Locate 3 , 1
    Lcd R
    V = V + 3
    Waitms 500
    Cls
    Loop
    End
    Local Lsb As Byte
    Local Msb As Byte
    Local Cmps_id As Byte
    Local Cmps_rd As Byte
    Cmps_id = &H42
    Cmps_rd = &H43
    Reset Portd.7
    I2cstart
    I2cwbyte Cmps_id
    I2cwbyte &H77
    I2cstop
    Waitms 20
    I2cstart
    I2cwbyte Cmps_rd
    I2crbyte Msb , Ack
    I2crbyte Lsb , Nack
    I2cstop
    Waitms 20
    Cmps = Makeint(lsb , Msb)
    End Function
    Calib:
    Dim Cmps_id As Byte
    Dim Cmps_rd As Byte
    Cmps_id = &H42
    Cmps_rd = &H43
    Cls
    Locate 1 , 1
    Lcd "calibrate"
    Wait 10
    Set Portd.6
    I2cstart
    I2cwbyte Cmps_id
    I2cwbyte &H70
    I2cstop
    Waitms 20
    Print "Start"
    Locate 2 , 1
    Lcd "START"
    Wait 80
    I2cstart
    I2cwbyte Cmps_id
    I2cwbyte &H72
    I2cstop
    Portd.6 = 0
    Cls
    Waitms 20
    Print "Quit"
    Locate 1 , 5
    Lcd "end calibrate"
    Waitms 200
    Locate 2 , 8
    Waitms 200
    Return
    End
      [glow=red,2,300]دوست عزیز ali_elect62 مرسی اکه میشه الگوریتمشم یه توضیحی بدی ممنون میشم[/glow]
        من جواب گرفتم خوب کار کرد مرسی
          سلام خوب این تاپیک قدیمیه ولی تنها تاپیکی هست که از ZCC210N-I2C
          حرف زدن
          کسی از برنامه موجود خبری داره که ایا ؟ این برنامه اطلا عاتشو چه طوری میگیره فقط فرمت عدد گرفته شدرو میخوام
          من خریدم این ماژولو و میخوام راه اندازی کنم
          بسم الاه
          با i2c کار کردم
          فقط نمیدونم این ینی چی ؟
          Lcd "N"
          Lcd "E"
          Lcd "SE"
          Lcd "S"
          Lcd "SW"
          Lcd "W"
          Lcd "NW"
          End If
          ینی این ماژول فقط دقت 45 درجه داره ؟ oo: oo:
          :surprised: تو دیتاشیت 1 درجه نوشته
            این چیه ؟ :sad:
              با این همه هم کاری ما رو شرمنده کردین :eek: دستتتون درد نکنه :angry: :angry:
                دیگه زحمت نکشین زدم ترکوندم 35 تومن پرید اه زدم رو vcc 12 ولت ترکید :cry2: :angry: :angry: :eek:
                  این ماژولو کجا میفروشند؟
                  الهم عجل لولیک الفرج
                  فقط 313 نفر...
                    http://iran-micro.com
                    roboeg.com
