این ورژن هم رسید :wow:
فرقش با 1.11.9.9
1.12.0.0
- Xmega caused a bug in non-xmega timer handeling : non xmega have a normal abd absolute address for IO regs which differ by 32. (normal
registers space).
This offset was determinted too late, resulting in a wrong address for internal variables like timer0.
These special byte variables are now placed in the dat file.
This error was not visible when you compiled your code more then once! Only a fresh start and first compilation would reveal this bug.
- swap supports swap of double too. Also, swap with a single parameter can swap a nibble or 2 bytes:
swap b where b = &B11110000 will result in 00001111
for word/integer, it will swap the bytes : w=&B11110000_1100_0000 -> 1100_0000_1111_0000 or &HABCD becomes CDAB.
- bccard port parameter changed into full port name. See help.
- config twislave has a new option : userack=ON|OFF. When on, you can set ack/nack from your code. Also fixed a bug where the default
setting did not save all registers.
- m32U4 : getadc() did not used ADC_MUX value from the dat file.
- myAVR programmer, changed error messages to info msg.
settings : 19200 baud.
- internal assembler allowed a backwards jump of 1 too many. in glcdeadogm128x6 this caused a wrong jump for chips>64KB.
- using $noramclear in combination with $initmicro could give an memory access error(invalid pointer).
- m32U4.dat file had missing mux5 bit, also corrected interrupt section.
- Windows 7-64 bit support added for LIBUSB.
- crc16 change for word sized arrays did not work for words but only bytes.
- internal loadbit routine which was rewritten in 11199 to check for boundery errors, had a bug for arrays with a constant index. The offset was 1
off.
this means that sombit=ar(3).8 would load the wrong bit location.
- RTF export will place the content in the clipboard too.
- power mode bug fixed: SE was not set when none of the SM bits were 1.
- usbasp (and other atmel programmers) gave a division by zero error for AT90XXXX chips (chips that do not use page programming)
- replaceChars string, oldchar,newchar will replace all characters in string.
- added tiny4313 support(programming untested)
- added button to insert $regfile, and $stack to the editor
فرقش با 1.11.9.9
1.12.0.0
registers space).
off.
