پروژه های حرفه ای و ساده میکرو
    ادامه کد ساعت بالا
    Ss1:
       Waitms T1
            Debounce Pind.3 , 1 , D7 , Sub
            Debounce Pind.0 , 1 , Ssal
            Debounce Pind.1 , 1 , Ss8
            Debounce Pind.2 , 1 , Ss9
                                       ' DESINGED BY A.N.T
    Ss9:
       Timer2 = 0: Stimer = 0: Ss = 0: Locate 1, 7: Lcd "00": GoTo Ss1
    Ss8:
          If Ss > 29 Then Mm = Mm + 1
       If Mm > 59 Then
           Mm = 0: Cc = Cc + 1: Ecc = Cc
           If Cc > 23 Then
             Cc = 0: Roz = Roz + 1: Hafteh = Hafteh + 1
             If Hafteh > 7 Then Hafteh = 1
             If Mah > 6 Then
                 If Roz > 30 Then
                    Roz = 1: Mah = Mah + 1
                    If Mah > 12 Then
                       Mah = 1: Sal = Sal + 1
                       If Sal > 99 Then Sal = 0
                       If Sal < 10 Then : Home L : Lcd " " ; Sal ; "/"
                       Else: Home L: Lcd Sal
                       End If
                       Esal = Sal
                    End If
                    If Mah < 10 Then : Locate 2 , 4 : Lcd "0" ; Mah ; "/"
                    Else: Locate 2, 4: Lcd Mah
                    End If
                    Emah = Mah
                 End If
              ElseIf 7 > Mah Then:
                 If Roz > 31 Then
                    If Mah > 12 Then
                       Else : Home L : Lcd Sal ; "/"
                       End If
                       Esal = Sal
                    End If
                    End If
                    Emah = Mah
                End If
                 Eroz = Roz: Ehafteh = Hafteh
              End If
              Locate 2, 9
              Select Case Hafteh
                 Case 1: Lcd " SAT"
                 Case 2: Lcd " SUN"
                 Case 3: Lcd " MON"
                 Case 4: Lcd " TUE"
                 Case 5: Lcd " WED"
                 Case 6: Lcd " THU"
                 Case 7: Lcd " FRI"
              End Select
              Locate 2, 7
              If Roz < 10 Then : Lcd "0" ; Roz
              Else: Lcd Roz
              End If
          End If
            If Cc < 10 Then : Home : Lcd " " ; Cc ; ":"
            Else : Home : Lcd Cc ; ":"
            End If
            Ecc = Cc
       End If
          Locate 1, 4
         If Mm < 10 Then : Lcd "0" ; Mm ; "/00"
         Else : Lcd Mm ; "/00"
         End If
       Ss = 0: GoTo Ss1
    Return
                    ' BARAT TANZIM SA@ TIMER
    Ct:
       F = 4
       For W = 0 To 40000
          If Pind.0 = 0 Then : Goto Ct1 : End If
          Waitus 60
       Next
       GoTo Cc
    Ct1:
        Waitms T1 : Z = 10 : Reset Portb.3
            Debounce Pind.0 , 1 , Mt
            Debounce Pind.1 , 1 , Ct8
            Debounce Pind.2 , 1 , Ct9
    Ct8:
          Ct = Ct + 1: If Ct > 23 Then Ct = 0: GoTo Ct1
    Ct9:
          Ct = Ct - 1: If Ct > 200 Then Ct = 23: GoTo Ct1
    Return
                    ' BARAT TANZIM DAGHIGHEH TIMER
    Mt:
       Ect = Ct: F = 5: Locate 1, 12: Z = 10
       If Ct < 10 Then : Lcd " " ; Ct ; ":"
       Else : Lcd Ct ; ":"
       End If
    Mt1:
       Waitms T1
            Debounce Pind.0 , 1 , Mt2
            Debounce Pind.1 , 1 , Mt8
            Debounce Pind.2 , 1 , Mt9
    Mt8:
         Mt = Mt + 1: If Mt > 59 Then Mt = 0: GoTo Mt1
    Mt9:
         Mt = Mt - 1: If Mt > 200 Then Mt = 59: GoTo Mt1
    Mt2:
       Emt = Mt: Locate 1, 15
       If Mt < 10 Then : Lcd "0" ; Mt
       Else: Lcd Mt
       End If
       Z = 0 : If B = 1 Then Set Portb.3 : Goto Star
    Return
                     ' BARAY FAAL VA GHER FAAL KARDAN TIMER
    D7:
       Locate 1, 10
          If B = 0 Then : B = 1 : Lcd Chr(1) : Set Portb.3
          Elseif B = 1 Then : B = 0 : Lcd " " : Reset Portb.3
          Else : B = 1 : Lcd Chr(1) : Set Portb.3
          End If
       Eb = B : Locate 2 , 20 : Reset Portd.7 : Z = 0
       Reset Portd.5 : Reset Portd.6 : If Kk = 1 Then Goto Star
       Waitms T1
    Return
    Return
                     ' BARAY TANZIM TARIKH SAL
    Ssal:
       F = 6: Locate 1, 7
       If Ss < 10 Then : Lcd "0" ; Ss
       Else: Lcd Ss
       End If
    Ssal1:
        Waitms T1
            Debounce Pind.0 , 1 , Mmah
            Debounce Pind.1 , 1 , Ssal8
            Debounce Pind.2 , 1 , Ssal9
    Ssal8:
         Sal = Sal + 1: If Sal > 99 Then Sal = 0: GoTo Ssal1
    Ssal9:
         Sal = Sal - 1: If Sal > 200 Then Sal = 99: GoTo Ssal1
    Return
                     ' BARAY TANZIM TARIKH MAH
    Mmah:
       F = 7: Esal = Sal: Home L
       If 10 > Sal Then : Lcd " " ; Sal ; "/"
       Else : Lcd Sal ; "/"
       End If
    Mmah1:
       Waitms T1
            Debounce Pind.0 , 1 , Rroz
            Debounce Pind.1 , 1 , Mmah8:
            Debounce Pind.2 , 1 , Mmah9
    Mmah8:
         Mah = Mah + 1: If Mah > 12 Then Mah = 1: GoTo Mmah1
    Mmah9:
         Mah = Mah - 1: If Mah = 0 Then Mah = 12: GoTo Mmah1
    Return
                     ' BARAY TANZIM TARIKH ROZ
    Rroz:
         F = 8: Emah = Mah: Locate 2, 4
       If 10 > Mah Then : Lcd "0" ; Mah ; "/"
       Else : Lcd Mah ; "/"
       End If
    Rroz1:
         Waitms T1
         Select Case Mah:
            Case Is > 6:
              If Roz > 30 Then: Roz = 1
              ElseIf Roz = 0 Then: Roz = 30
              End If
            Case Is < 7:
               If Roz > 31 Then: Roz = 1
               ElseIf Roz = 0 Then: Roz = 31
               End If
         End Select
            Debounce Pind.0 , 1 , Hhafteh
            Debounce Pind.1 , 1 , Rroz8
            Debounce Pind.2 , 1 , Rroz9
    Rroz8:
        Roz = Roz + 1: GoTo Rroz1
    Rroz9:
        Roz = Roz - 1: GoTo Rroz1
    Return
                     ' BARAY TANZIM ROOZ HAFTEH
    Hhafteh:
       F = 9: Eroz = Roz: Locate 2, 7
       Else: Lcd Roz
       End If
    Hhafteh1:
       Waitms T1
            Debounce Pind.0 , 1 , Hhafteh2
            Debounce Pind.1 , 1 , Hhafteh8
            Debounce Pind.2 , 1 , Hhafteh9
    Hhafteh8:
         Hafteh = Hafteh + 1: If Hafteh > 7 Then Hafteh = 1: GoTo Hhafteh1
    Hhafteh9:
         Hafteh = Hafteh - 1: If Hafteh = 0 Then Hafteh = 7: GoTo Hhafteh1
    Hhafteh2:
         Ehafteh = Hafteh: Locate 2, 9
         Select Case Hafteh:
            Case 1: Lcd " SAT"
            Case 2: Lcd " SUN"
            Case 3: Lcd " MON"
            Case 4: Lcd " TUE"
            Case 5: Lcd " WED"
            Case 6: Lcd " THU"
            Case 7: Lcd " FRI"
         End Select
    GoTo Star
    Return
                     ' BARAY TANZIM DAMAY BALA
    Dama1:
         F = 11
            Debounce Pind.0 , 1 , Dama2
            If Pind.1 = 0 Then :
               If Pind.2 = 0 Then Exit Do
            End If
    Dama15:
          Waitms T1
            Debounce Pind.1 , 1 , Dama18
            Debounce Pind.2 , 1 , Dama19
    Dama18:
         Cup = Cup + 1: If Cup > 99 Then Cup = 0: GoTo Dama15
    Dama19:
         Cup = Cup - 1: If Cup > 200 Then Cup = 99: GoTo Dama15
    Return
                     ' BARAY TANZIM DAMAY PAEEN
    Dama2:
         F = 12: Waitms T1
            Debounce Pind.0 , 1 , Dama22
            Debounce Pind.1 , 1 , Dama28
            Debounce Pind.2 , 1 , Dama29
    Dama28:
         Cdown = Cdown + 1: If Cdown > 99 Then Cdown = 0: GoTo Dama2
    Dama29:
         Cdown = Cdown - 1: If Cdown > 200 Then Cdown = 99: GoTo Dama2
    Dama22:
         Ecdown = Cdown: Ecup = Cup: Locate 2, 13
                If A0 < 10 Then : Lcd " " ; A0 ; Chr(0)
                ElseIf A0 > 99 Then: Lcd " ERR"
                Else : Lcd " " ; A0 ; Chr(0)
                End If
          GoTo Star
    Return
                     ' BARAY TANZIM ZAMAN T1
    Tt1:
         F = 21: Waitms T1: Kk = 0
            Debounce Pind.0 , 1 , Tt13
            Debounce Pind.1 , 1 , Tt11
            Debounce Pind.2 , 1 , Tt12
    Tt11:
         Tt1 = Tt1 + 1: If Tt1 > 15 Then Tt1 = 0: GoTo Tt1
    Tt12:
         Tt1 = Tt1 - 1: If Tt1 = 255 Then Tt1 = 15: GoTo Tt1
    Tt13:
         Ett1 = Tt1: GoTo Tt2
    Return
                     ' BARAY TANZIM ZAMAN T2
    Tt2:
         F = 22: Waitms T1
            Debounce Pind.0 , 1 , Tt23
            Debounce Pind.1 , 1 , Tt21
            Debounce Pind.2 , 1 , Tt22
    Tt21:
         Tt2 = Tt2 + 1: If Tt2 > 15 Then Tt2 = 0: GoTo Tt2
    Tt22:
         Tt2 = Tt2 - 1: If Tt2 = 255 Then Tt2 = 15: GoTo Tt2
    Tt23:
         Ett2 = Tt2: GoTo Tt3
    Return
                     ' BARAY TANZIM ZAMAN T3
    Tt3:
         F = 23: Waitms T1
            Debounce Pind.0 , 1 , Tt33
            Debounce Pind.1 , 1 , Tt31
            Debounce Pind.2 , 1 , Tt32
    Tt31:
         Tt3 = Tt3 + 1: If Tt3 > 15 Then Tt3 = 0: GoTo Tt3
    Tt32:
         Tt3 = Tt3 - 1: If Tt3 = 255 Then Tt3 = 15: GoTo Tt3
    Tt33:
         Ett3 = Tt3: GoTo Tt4
    Return
                     ' BARAY TANZIM ZAMAN T4
    Tt4:
         F = 24: Waitms T1
            Debounce Pind.0 , 1 , Tt43
            Debounce Pind.1 , 1 , Tt41
            Debounce Pind.2 , 1 , Tt42
    Tt41:
         Tt4 = Tt4 + 1: If Tt4 > 15 Then Tt4 = 0: GoTo Tt4
    Tt42:
         Tt4 = Tt4 - 1: If Tt4 = 255 Then Tt4 = 15: GoTo Tt4
    Tt43:
         Ett4 = Tt4: GoTo Tt5
    Return
                     ' BARAY TANZIM ZAMAN T5
    Tt5:
         F = 25: Waitms T1
            Debounce Pind.0 , 1 , Tt53
            Debounce Pind.1 , 1 , Tt51
            Debounce Pind.2 , 1 , Tt52
    Tt51:
         Tt5 = Tt5 + 1: If Tt5 > 15 Then Tt5 = 0: GoTo Tt5
    Tt52:
         Tt5 = Tt5 - 1: If Tt5 = 255 Then Tt5 = 15: GoTo Tt5
    Tt53:
         F = 0: Ett5 = Tt5: Locate 1, 12:
          Else: Lcd Ct
          End If
         Lcd ":": Locate 1, 15:
          Else: Lcd Mt
          End If
         GoTo Star
    Return
                     ' BARAY KHAMOSH KARDAN ETELAAT LCD DAR ZAMAN CHESHMAK ZADAN HENGAM ENTEKHAB GOZINEH MARBOTEH
    Offlcd:
    If F <> 0 Then:
       If F = 1 Then: Home: Lcd " "
       ElseIf F = 2 Then: Locate 1, 4: Lcd " "
       Else:
            If F = 3 Then: Locate 1, 7: Lcd " "
            ElseIf F = 4 Then: Locate 1, 12: Lcd " "
            End If
       End If
       If F = 5 Then: Locate 1, 15: Lcd " "
       ElseIf F = 6 Then: Locate 2, 1: Lcd " "
       Else:
            If F = 7 Then: Locate 2, 4: Lcd " "
            ElseIf F = 8 Then: Locate 2, 7: Lcd " "
            End If
       End If
       If F = 9 Then: Locate 2, 9: Lcd "  "
       ElseIf F = 25 Then: Locate 1, 15: Lcd "  "
       Else:
            If F = 11 Then : Locate 2 , 13 : Lcd "  " ; Chr(2)
            Elseif F = 12 Then : Locate 2 , 13 : Lcd "  " ; Chr(3)
            End If
       End If
                                       ' DESINGED BY A.N.T
       If F = 21 Then: Locate 1, 15: Lcd "  "
       ElseIf F = 22 Then: Locate 1, 15: Lcd "  "
       Else:
            If F = 23 Then: Locate 1, 15: Lcd "  "
            ElseIf F = 24 Then: Locate 1, 15: Lcd "  "
            End If
       End If
    End If
    Return
                     ' BARAY NAMAYESH ETELAAT MORED NIYAZ DAR ZAMAN MONASEB BAR ROY LCD
    Onlcd:
    If F <> 0 Then:
          Home
          If Cc < 10 Then : Lcd " " ; Cc
          Else: Lcd Cc
          End If
          Locate 1, 4
          Else: Lcd Mm
          End If
          Locate 1, 7
          Else: Lcd Ss
          End If
          Home L
          If Sal < 10 Then : Lcd " " ; Sal
          End If
       If F = 5 Then
          Locate 1, 15:
          Else: Lcd Mt
          End If
       ElseIf F = 4 Then
          Locate 1, 12:
          Else: Lcd Ct
          End If
       End If
          Locate 2, 4
          If Mah < 10 Then : Lcd "0" ; Mah
          Else: Lcd Mah
          End If
          Locate 2, 7
          Else: Lcd Roz
          End If
          Locate 2, 9
          Select Case Hafteh
             Case 1: Lcd " SAT"
             Case 2: Lcd " SUN"
             Case 3: Lcd " MON"
             Case 4: Lcd " TUE"
             Case 5: Lcd " WED"
             Case 6: Lcd " THU"
             Case 7: Lcd " FRI"
          End Select
       If F = 25 Then
          Locate 1, 12:: Lcd "T5="
          If Tt5 < 10 Then : Lcd "0" ; Tt5
          Else: Lcd Tt5
          End If
       End If
       If F = 11 Then
          Locate 2, 14
          If Cup < 10 Then : Lcd "0" ; Cup
          Else: Lcd Cup
          End If
       ElseIf F = 12 Then:
          Locate 2, 14
          If Cdown < 10 Then : Lcd "0" ; Cdown
          Else: Lcd Cdown
          End If
       End If
       If F = 21 Then
          Locate 1, 12: Lcd "T1="
          If Tt1 < 10 Then : Lcd "0" ; Tt1
          Else: Lcd Tt1
          End If
       ElseIf F = 22 Then
          Locate 1, 12:: Lcd "T2="
          If Tt2 < 10 Then : Lcd "0" ; Tt2
          Else: Lcd Tt2
          End If
       End If
       If F = 23 Then
          Locate 1, 12: Lcd "T3="
          If Tt3 < 10 Then : Lcd "0" ; Tt3
          Else: Lcd Tt3
          End If
       ElseIf F = 24 Then
          Locate 1, 12:: Lcd "T4="
          If Tt4 < 10 Then : Lcd "0" ; Tt4
          Else: Lcd Tt4
          End If
       End If
    End If
    Return
                                       ' DESINGED BY A.N.T
    End
    وقتی یه نفر تشکر میکنه آدم خستگیش در میره دمتون گرم هرچی خواستید بگید من میزارم ولی خیلی سخت نباشه چون نمیتونم چیزی رو ازنو بنویسم ولی اگه قبلا انجامش داده باشم میزارم رو تخم چشام oo:
    دودمانم بر باد رفت
      کنترول کامپیوتر با کنترول تلوزیون
      این عکسش هست
      از مدیران می خوام این یه مورد رو منتقل نکنن میدونم مال میکرو نیست
      اینم لینک برنامه
      http://folder.persiangig.com/SOFTWARE/IR Control.zip
      دودمانم بر باد رفت
        دانلود پروژه دزدگیر با PIR و میکرو AVR
        این دزدگیر با PIR هست من تستش نکردم اما دوستم که طراحیش کرده گفته درسته
        این پروژه با توجه به استفاده از سنسور PIR وحساسیت نسبتا خوب آن میتواند با تشخیص حرکت یک انسان مقابل خود به شماره تلفن مشخص شده زنگ بزند .
        سورس کامل برنامه با بسکام + شماتیک + توضیحات لازمه برای این پروژه + دیتاشیت سنسور PIR + مدار راه انداز و درایور سنسور PIR
        حجم: 374 کیلوبایت
        http://dl.bargh20.com/hamid/1/dozdgi...rgh20.com).rar
        منبع: www.lachini.com
        پسورد فایل: www.bargh20.com
        باز چیزی بسازم یا گیرم بیاد میزارم :bye
        دودمانم بر باد رفت
          #19
          قفل دیجیتالی
          هرکی مدار قفل الکترونیکی داره بزاره دریق نکنه :nice: :nerd:
          دودمانم بر باد رفت
            #20
            مدار دیمر دیجیتالی
            کد مدار
            'ECA
            GT700
            MOHAMMAD_GT700@YAHOO.COM
            DIMER
            $regfile = "m8def.dat"
            $crystal = 4000000
            Config Pinb.1 = Output    ' Gate Triac
            Config Pind.7 = Input     ' Key Up
            Config Pinb.0 = Input     ' Key Dn
            Config Int0 = Rising
            On Int0 Int0_int
            Enable Interrupts
            Enable Int0
            Dim E As Eram Byte
            Dim B As Byte
            Dim D As Byte
            If E > 9 Then E = 9
            B = E
            D = 0
            Set Portb.1
              If Pind.7 = 0 Then
                If B > 1 Then Decr B
                Waitms 10
                E = B
              End If
              If Pinb.0 = 0 Then
                If B < 9 Then Incr B
                Waitms 10
                E = B
              End If
            End 'end program
            Int0_int:
            Set Portb.1
            For D = 0 To B
              Waitus 200
            Next D
            Reset Portb.1
            Return
            اینم عکسش
            دودمانم بر باد رفت
              #21
              پاسخ : پروژه های حرفه ای و ساده میکرو
              آقا من دیگه نمیدونم چی بزارم شما یه چیز بگین من بزارم oo:
              مغزم پخت :nice: oo: :nerd:
              تا پروژه نگین من همین روندو دارم :angry:
              دودمانم بر باد رفت
                #22
                دزد گیر لرزشی اگه داری که خیلی به درد میخوره :job:
                هنگامی که چیزی مینویسی، کاری نکن تنها کسی که از مغزش استفاده کرده باشد ،مدادت باشد .
                \|/_\/_
                  #23
                  دوست عزیز اگر پروژه ای در باره راه اندازی دوربین با avr داری ممنون میشم یه توضیحی در بارش بدی.
                  موفقیت بدست آوردن چیزیست که دوست داری و خوشبختی دوست داشتن چیزیست که بدست آوردهآ‌ای.
                    #24
                    نوشته اصلی توسط mahziyar
                    چنو دوربینی معمولی .آیپی کمرا
                    مودلش چیه
                    ازینا که رو ربات میزارن :question:
                    دودمانم بر باد رفت
                      #25
                      نوشته اصلی توسط MEGAMAN
                      این مدلی که گفتی باید چه جوری باشه شما مودل کاری رو بگو ینی چجوری باید فعال بشه
                      ینوش هست در که باز میشه می لرزه اون خبر میکنه نیاز به میکرو هم نداره یه آی سی تو مدلای cd یا lm بود فکذ کنم حالا باید ببینم
                      دودمانم بر باد رفت
                        #26
                        نوشته اصلی توسط gt700
                        مثل سنسوره لرزشی دزدگیر ماشین.
                        اون لرزشی نیست .بهش میگن مگنت آهنربایی
                        حالا اگه شماتیک دزدگیر لرزشی حتما بزار
                        mer30
                        \|/_\/_
                          #27
                          پاسخ : کنترول کامپیوتر با کنترول تلوزیون
                          این عکسش هست
                          از مدران می خوام این یه مورد رو منتقل نکنن میدونم مال میکرو نیست
                          اینم لینک برنامه
                          PCB این مدار را طراحی کردم و به همراه چند عکس کمکی در پوشه ای قرار دادم.
                          PCB در پروتئوس باز میشود.میتوانید آن را دانلود کنید.
                          البته اگه کسی مشگلی داشت مطرح کنه تا کمکش کنم
                          فایل های پیوست شده
                          \|/_\/_
                            #28
                            مرسی از این همه انرژی که می ذارین
                            احیانا :rolleyes: فرستنده ir با uart نداری که 100% کار بکنه؟
                            چنتا ساختم ولی کار نکردن :cry2:
                            می خوام با infrared دیتا بفرستم به گوشی! با boud 9600
                            درست می کنی؟ -O<
                            پشت به کنکور ، رو به سربازی...
                              #29
                              نوشته اصلی توسط black-8
                              درست می کنی؟ -O<
                              این پروژه خیلی وقت میبره
                              می خوای با پرت سریال باشه ؟
                              ینی میکرو سر راه نباشه؟
                              این جزء برنامه نویسی ویبی میشه برو تو قسمت کامپیوتر درخواست کن مثل مدار بالایی هست ولی برکسش فرستنده.
                              با میکرو هم میشه ولی زمان می بره چون باید داستگه بهش شناسونده بشه ینو درایور بازی میشه :nerd: :nice: oo:
                              دودمانم بر باد رفت
                                #30
                                مدار سیگنال ژنراتور
                                این مدار سیگنال ژنراتور هستش با موج رمپ سینوسی و ای سی این مال یکی از دوستا هست که کاربر سایت هم میباشه ولی اسم شریفشان رو یادم رفته
                                #include <mega32.h>
                                #include <math.h>
                                #include <delay.h>
                                #include <stdio.h>
                                #asm
                                  .equ __lcd_port=0x18 ;PORTB
                                #endasm
                                #include <lcd.h>
                                char a[256],i=0,s[16],select=0,t;
                                void ramp(void){
                                    PORTD=i;
                                    i++;
                                    t++;
                                    if(t==255){
                                    t=0;
                                    lcd_gotoxy(0,0);
                                    lcd_putsf("Mode: Ramp ");
                                    lcd_gotoxy(0,1);
                                    lcd_puts(s);
                                void square(void){
                                    if(i<127) PORTD=255;
                                    else PORTD=0;
                                    i++;
                                    t++;
                                    if(t==255){
                                    t=0;
                                    lcd_gotoxy(0,0);
                                    lcd_putsf("Mode: Square");
                                    lcd_gotoxy(0,1);
                                    lcd_puts(s);
                                void sine(void){
                                    PORTD=a[i];
                                    i++;
                                    t++;
                                    if(t==255){
                                    t=0;
                                    lcd_gotoxy(0,0);
                                    lcd_putsf("Mode: Sin  ");
                                    lcd_gotoxy(0,1);
                                    lcd_puts(s);
                                interrupt [TIM0_COMP] void timer0_comp_isr(void){
                                switch (select){
                                    case 0:
                                     sine();
                                     break;
                                    case 1:
                                     square();
                                     break;
                                    case 2:
                                     ramp();
                                     break;
                                    if (PINC.1==0 |PINC.0==0 | PINC.2==0 )
                                      delay_ms(100);
                                      if (PINC.1==0){
                                         OCR0++;
                                         sprintf(s,"F: %d ",OCR0);
                                      if (PINC.0==0){
                                         OCR0--;
                                      if(PINC.2==0)
                                        if (select<2)
                                           select++;
                                        else
                                           select=0;
                                void main(void)
                                a[0]=131; a[1]=134; a[2]=137; a[3]=140; a[4]=144; a[5]=147; a[6]=150; a[7]=153;
                                a[8]=156; a[9]=159; a[10]= 162; a[11]= 165; a[12]=168;a[13] = 171;a[14]= 174;a[15] =177;a[16]=180;a[17]=183;a[18]=185;a[19]=188;a[20]=191;
                                a[21]=194;a[22]= 196;a[23]=199;a[24]= 201;a[25]= 204;a[26]=206;a[27]= 209;a[28] =211;a[29]= 214;a[30]=216;a[31]=218;a[32]=220;a[33]=222;
                                a[34]=225;a[35]= 227;a[36]=229;a[37]= 230;a[38]= 232;a[39]=234;a[40]= 236;a[41]=237;a[42]= 239;a[43]=240;a[44]= 242;a[45]= 243;a[46]=245;
                                a[47]=246;a[48]= 247;a[49] =248;a[50]=249;a[51] =250;a[52] =251;a[53] =252;a[54] =252;a[55] =253;a[56]=254;a[57]= 254;a[58]= 255;a[59]= 255;
                                a[60]=255;a[61]=255;a[62] =255;a[63]= 255;a[64] =255;a[65]= 255;a[66] =255;a[67]= 255;a[68]= 255;a[69] =254;a[70] =254;a[71] =253;a[72]= 252;
                                a[73]=252;a[74]= 251;a[75] =250;a[76]= 249;a[77] =248;a[78]= 247;a[79]= 246;a[80] =245;a[81]= 243;a[82] =242;a[83] =240;a[84] =239;a[85] =237;
                                a[86]=236;a[87]= 234;a[88] =232;a[89]= 230;a[90] =229;a[91]= 227;a[92]= 225;a[93] =222;a[94]= 220;a[95] =218;a[96] =216;a[97] =214;a[98] =211;
                                a[99]=209;a[100]= 206;a[101]= 204;a[102]= 201;a[103]= 199;a[104]= 196;a[105]= 194;a[106] =191;a[107] =188;a[108] =185;a[109] =183;a[110]= 180;a[111] =177;
                                a[112]=174;a[113]= 171;a[114] =168;a[115]= 165;a[116]= 162;a[117]= 159;a[118]= 156;a[119]= 153;a[120]= 150;a[121]= 147;a[122] =144;a[123]= 140;a[124] =137;
                                a[125]=134;a[126]= 131;a[127] =128;a[128]= 125;a[129]= 122;a[130]= 119;a[131] =116;a[132]= 112;a[133]= 109;a[134]= 106;a[135] =103;a[136]= 100;a[137] = 97;
                                a[138]=94;a[139] = 91;a[140] =88;a[141] = 85;a[142] = 82;a[143] = 79;a[144] = 76;a[145] = 73;a[146] = 71;a[147] = 68;a[148] =65;a[149]= 62;a[150] = 60;
                                a[151]=57;a[152] = 55;a[153] =52;a[154] = 50;a[155] = 47;a[156] = 45;a[157] = 42;a[158] = 40;a[159]= 38;a[160] = 36;a[161] = 34;a[162]= 31;a[163] = 29;
                                a[164]=27;a[165] = 26;a[166] =24;a[167] = 22;a[168] = 20;a[169] = 19;a[170] = 17;a[171] = 16;a[172] = 14;a[173] = 13;a[174] =11;a[175]= 10;a[176] = 9;
                                a[177]=8;a[178] = 7;a[179]  =6;a[180] = 5;a[181] = 4;a[182] = 4;a[183] = 3;a[184] = 2;a[185] = 2;a[186] = 1;a[187] = 1;a[188] = 1;a[189] = 1;
                                a[190]=1;a[191] = 1;a[192]  =1;a[193] = 1;a[194] = 1;a[195] = 1;a[196] = 1;a[197] = 2;a[198] = 2;a[199] = 3;a[200] = 4;a[201] = 4;a[202] = 5;
                                a[203]=6;a[204] = 7;a[205]  =8;a[206] = 9;a[207] =10;a[208] =11;a[209] = 13;a[210] =14;a[211] =16;a[212] =17;a[213] =19;a[214] = 20;a[215] = 22;
                                a[216]=24;a[217] = 26;a[218] =27;a[219] = 29;a[220] = 31;a[221] = 34;a[222] =36;a[223] = 38;a[224] =40;a[225] = 42;a[226] = 45;a[227]= 47;a[228]= 50;
                                a[229]=52;a[230] = 55;a[231] =57;a[232] = 60;a[233] = 62;a[234] = 65;a[235] =68;a[236] = 71;a[237] =73;a[238] = 76;a[239] = 79;a[240]= 82;a[241]= 85;
                                a[242]= 88;a[243]= 91;a[244]= 94;a[245]= 97;a[246]= 100;a[247]= 103;a[248] =106;a[249]= 109;a[250] =112;a[251]= 116;a[252]= 119;a[253]= 122;a[254]=125;a[255]=128;
                                DDRA=0xFF;
                                DDRB=0x00;
                                DDRC=0xFF;
                                DDRD=0xFF;
                                TCCR0=0x09;
                                TCNT0=0x00;
                                OCR0=255;
                                TIMSK=0x02;
                                ACSR=0x80;
                                SFIOR=0x00;
                                PORTC=255;
                                lcd_init(16);
                                #asm("sei")
                                while (1)
                                من می خوام تو اینجا یه ups بسازم بیاد کمک
                                http://www.eca.ir/forum2/index.php?topic=43792.0
                                کمک کمک کمک
                                دودمانم بر باد رفت
