Features:
-super small – dimensions 44 x 39 x 5,5 mm
-super fast – write up to 12,5kB/s, read up to 14,5kB/s
-uses cheap storage medium – small MICRO SD cards
-supports FAT16 and FAT32 file systems
-can read, write, verify flash and eeprom memory
-can read, write, verify fusebits and lockbits
-write and read to BIN, HEX, and TXT files
-can set default values of fusebits, erase memories
-cheap, easy to obtain, LPH7779 graphic display
-shows funny animations after every operation
-standard programming header – Atmel 6-PIN ISP
-has a function of auto-update its own firmware (from SD)
-very simple to use, 4 buttons navigation
-user-setting menu
-programming speed auto-selection (up to 4MHz)
-Operates at 3V, programs chips supplied from 3V to 5V
-user-setting menu
آدرس:
http://diy.elektroda.eu/uprog-maly-s...-z-sd/?lang=en
