یکی میتونه این برنامه رو توضیح بده
Dim Ctr As Byte
Dim Dataword As Word
Dim Command As Byte
Dim Dis As String * 20
Dim Calc As Single
Dim Calc2 As Single
Dim Rhlinear As Single
Dim Rhlintemp As Single
Dim Tempc As Single
Dim Tempf As Single
Const C1 = -4
Const C2 = 0.0405
Const C3 = -0.0000028
Const T1c = .01
Const T2 = .00008
Const T1f = .018
Sck Alias Portb.0
Dataout Alias Portb.1
Datain Alias Pinb.1
Redled Alias Portb.2
Declare Sub Getit()
Ddrb = &B11111111 'all port b are output
Config Pinb.0 = Output 'sck
Config Pinb.1 = Output 'datain
'reset the serial communications first, it is easily confused!
Set Dataout
For Ctr = 1 To 12
Set Sck
Waitus 2
Reset Sck
Waitus 2
Next Ctr
Do 'continually read the tempfature and humidity
Command = &B00000011
Call Getit 'Get the temperature, puts result in "dataword" for us
Tempf = T1f * Dataword
Tempf = Tempf - 40
Tempc = T1c * Dataword 'get celcius for later calculations and for "the rest of the world"
Tempc = Tempc - 40
Dis = Fusing(tempf , "###.##"
Print "Temperature = " ; Dis ; " (F)"
Command = &B00000101
Call Getit 'get the humidity
Calc = C2 * Dataword
Calc2 = Dataword * Dataword 'that "2" in the datasheet sure looked like a footnote for a couple days, nope it means "squared"!
Calc2 = C3 * Calc2
Calc = Calc + C1
Rhlinear = Calc + Calc2
'Dis = Fusing(rhlinear , "##.##"
'Print "Humidity adjusted for linear = " ; Dis
Calc = T2 * Dataword
Calc = Calc + T1c
Calc2 = Tempc - 25
Calc = Calc2 * Calc
Rhlintemp = Calc + Rhlinear
Dis = Fusing(rhlintemp , "##.##"
Print "Humidity adjusted for temperature = " ; Dis
Print
Wait 1
Loop
Sub Getit()
Local Datavalue As Word
Local Databyte As Byte
'start with "transmission start"
Set Sck
Reset Dataout
Reset Sck
Set Sck
Set Dataout
Reset Sck
'now send the command
Shiftout Dataout , Sck , Command , 1
Ddrb = &B11111101 'datain is now input
Config Pinb.1 = Input 'datain
Set Sck 'click one more off
Reset Sck
Waitus 10 'no idea why, but it doesn't work without it!
Bitwait Pinb.1 , Reset 'wait for the chip to have data ready
Shiftin Datain , Sck , Databyte , 1 'get the MSB
Datavalue = Databyte
Ddrb = &B11111111
Reset Dataout 'this is the tricky part- Lot's of hair pulling- have to tick the ack!
Set Sck
Reset Sck
Shiftin Datain , Sck , Databyte , 1 'get the LSB
Shift Datavalue , Left , 8
Datavalue = Datavalue Or Databyte
'don't tick the clock or ack since we don't need the CRC value, leave it hanging!
Dataword = Datavalue
Ddrb = &B11111111
Reset Dataout
Set Sck
Reset Sck
Shiftin Datain , Sck , Databyte , 1 'not using the CRC value for now- can't figure it out! Anybody know how to impliment?
'Print "CRC value was - " ; Databyte
Ddrb = &B11111111
Set Dataout
Set Sck
Reset Sck
End Sub
End
Dim Ctr As Byte
Dim Command As Byte
Dim Calc As Single
Dim Calc2 As Single
Dim Tempc As Single
Dim Tempf As Single
Const C1 = -4
Const C2 = 0.0405
Const T1c = .01
Const T2 = .00008
Const T1f = .018
Sck Alias Portb.0
Datain Alias Pinb.1
Declare Sub Getit()
Set Dataout
For Ctr = 1 To 12
Set Sck
Waitus 2
Reset Sck
Waitus 2
Next Ctr
Tempf = Tempf - 40
Tempc = Tempc - 40
Calc2 = C3 * Calc2
Calc = Calc + C1
Calc = Calc + T1c
Calc2 = Tempc - 25
Calc = Calc2 * Calc
Wait 1
Loop
Sub Getit()
Set Sck
Reset Dataout
Reset Sck
Set Sck
Set Dataout
Reset Sck
Reset Sck
Ddrb = &B11111111
Set Sck
Reset Sck
Ddrb = &B11111111
Reset Dataout
Set Sck
Reset Sck
Ddrb = &B11111111
Set Dataout
Set Sck
Reset Sck
End Sub
End
