پاسخ : فرستادن یه کد مثل 03H به یه ای سی یا ...
باز هم فرار کردید :mrgreen:
این جدول زمان بندی چه طوریه ؟
/* * definitions.h * * Created: 11/5/2011 9:49:18 PM * Author: Mostafa */ #ifndef DEFINITIONS_H_ #define DEFINITIONS_H_ #define MSD_CMD_GET_IC_VER 0x01 //Obtain chip and firmware version number #define MSD_CMD_SET_BAUDRATE 0x02 //Set serial communication baud rate #define MSD_CMD_ENTER_SLEEP 0x03 //Go to low-power and suspending #define MSD_CMD_RESET_ALL 0x05 //Execute hardware reset #define MSD_CMD_CHECK_EXIST 0x06 //Test communication interface and working status #define MSD_CMD_SET_SD0_INT 0x0B //Set interrupt Mode of SD0 in SPI #define MSD_CMD_GET_FILE_SIZE 0x0C //Get the current file length #define MSD_CMD_SET_USB_MODE 0x15 //Configure the work mode of USB #define MSD_CMD_GET_STATUS 0x22 //Get interruption status and cancel requirement #define MSD_CMD_RD_USB_DATA0 0x27 //Read data from current interrupt port buffer of USB or receive buffer of host port #define MSD_CMD_WR_USB_DATA 0x2C //Write data to transfer buffer of USB host #define MSD_CMD_WR_REQ_DATA 0x2D //Write requested data block to internal appointed buffer #define MSD_CMD_WR_OFS_DATA 0x2E //Write data block to internal buffer with appointed excursion address #define MSD_CMD_SET_FILE_NAME 0x2F //Set the file name which will be operated #define MSD_CMD_DISK_CONNECT 0x30 //Check the disk connection status #define MSD_CMD_DISK_MOUNT 0x31 //Initialize disk and test disk ready #define MSD_CMD_FILE_OPEN 0x32 //Open file or catalog, enumerate file and catalog #define MSD_CMD_FILE_ENUM_GO 0x33 //Go on to enumerate file and catalog #define MSD_CMD_FILE_CREATE 0x34 //Create file #define MSD_CMD_FILE_ERASE 0x35 //Delete file #define MSD_CMD_FILE_CLOSE 0x36 //Close the open file or catalog #define MSD_CMD_DIR_INF0_READ 0x37 //Read the catalog information of file #define MSD_CMD_DIR_INF0_SAVE 0x38 //Save catalog information of file #define MSD_CMD_BYTE_LOCATE 0x39 //Move the file pointer take byte as unit #define MSD_CMD_BYTE_READ 0x3A //Read data block from current location take byte as unit #define MSD_CMD_BYTE_RD_GO 0x3B //Continue byte read #define MSD_CMD_BYTE_WRITE 0x3C //Write data block from current location take unit as unit #define MSD_CMD_BYTE_WR_GO 0x3D //Continue byte write #define MSD_CMD_DISK_CAPACITY 0x3E //Check disk physical capacity #define MSD_CMD_DISK_QUERY 0x3F //Check disk space #define MSD_CMD_DIR_CREATE 0x40 //Create catalog and open or open the existed catalog #define MSD_CMD_SEG_LOCATE 0x4A //Move file pointer from current location take fan as unit #define MSD_CMD_SEC_READ 0x4B //Read data block from current location take fan as unit #define MSD_CMD_SEC_WRITE 0x4C //Write data block from current location take fan as unit #define MSD_CMD_DISK_BOC_CMD 0x50 //Execute B0 transfer protocol command to USB Storage #define MSD_CMD_DISK_READ 0x54 //Read physical fan from USB storage device #define MSD_CMD_DISK_RD_GO 0x55 //Go on reading operation of USB storage device #define MSD_CMD_DISK_WRITE 0x56 //Write physical fan to USB storage device #define MSD_CMD_DISK_WR_GO 0x57 //Go on writing operation of USB storage device // --------------------------------------------------------------------------------------------------- #define MSD_RET_SUCCESS 0x51 //Operation successful #define MSD_RET_ABORT 0x5F //Operation failure #define MSD_USB_INT_SUCCESS 0x14 //Success of SD card or USB transaction or transfer operation #define MSD_USB_INT_CONNECT 0x15 //Detection of USB device attachment #define MSD_USB_INT_DISCONNECT 0x16 //Detection of USB device detachment #define MSD_USB_INT_BUF_OVER 0x17 //Data error or Buffer overflow #define MSD_USB_INT_USB_READY 0x18 //USB device has initialized (appointed USB address) #define MSD_USB_INT_DISK_READ 0x1D //Read operation of storage device #define MSD_USB_INT_DISK_WRITE 0x1E //Write operation of storage device #define MSD_USB_INT_DISK_ERR 0x1F //Failure of USB storage device #define MSD_ERR_OPEN_DIR 0x41 //Open directory address is appointed #define MSD_ERR_MISS_FILE 0x42 //File doesn’t be found which address is appointed, maybe the name is error #define MSD_ERR_FOUND_NAME 0x43 //Search suited file name, or open directory according the request, open file in actual #define MSD_ERR_DISK_DISCON 0x82 //Disk doesn’t connect, maybe the disk has cut down #define MSD_ERR_LARGE_SECTOR 0x84 //Fan is too big, only support 512 bytes #define MSD_ERR_TYPE_ERROR 0x92 //Disk partition doesn’t support, re-prartition by tool #define MSD_ERR_BPB_ERROR 0xA1 //Disk doesn’t format, or parameter is errot, re-formate by WINDOWS with default parameter #define MSD_ERR_DISK_FULL 0xB1 //File in disk is full, spare space is too small #define MSD_ERR_FDT_OVER 0xB2 //Many file in directory, no spare directory, clean up the disk, less than 512 in FAT12/FAT16 root directory #define MSD_ERR_FILE_CLOSE 0xB4 //File is closed, re-open file if need #endif /* DEFINITIONS_H_ */
* MSDlib.h
* Created: 11/5/2011 10:19:59 PM
* Author: Mostafa
#ifndef MSDLIB_H_
#define MSDLIB_H_
#include "definitions.h"
void msd_init();
void msd_command(char cmd);
char msd_isconnect();
char msd_mount();
void msd_dismount();
char msd_updateDiskCapacity();
volatile char msd_timeout;
struct diskSpaces
unsigned long msd_diskSize; // in 512 sectors
unsigned long msd_diskFree; // in 512 sectors
}diskSpaces;
#endif /* MSDLIB_H_ */
* MSDlib.c
* Created: 11/14/2011 1:05:36 PM
* Author: Mostafa
#include "MSDlib.h"
#include "MSDmacro.h"
#include "msd_uart.h"
void msd_init()
MSD_UART_INIT();
void msd_flushBuffer()
while(MSD_UART_RECIVED())
MSD_UARTGET();
msd_flushBuffer();
MSD_UARTPUT(0x57);
MSD_UARTPUT(0xAB);
MSD_UARTPUT(cmd);
//1000ms resolation
char msd_waitonebyte(char t)
unsigned int i;
msd_timeout = 0;
t = 26 - t;
for(i = 0; i < 50000; i+=t)
if(MSD_UART_RECIVED())
return MSD_UARTGET();
MSD_Delay_us(50);
msd_timeout = 1;
return 0xff;
char msd_getversion()
char t;
msd_command(MSD_CMD_GET_IC_VER);
t = msd_waitonebyte(3);
if( t == 0xff )
return MSD_RET_ABORT;
return t;
char mds_setmode(char mode)
char ret;
msd_command(MSD_CMD_SET_USB_MODE);
MSD_UARTPUT(mode);
ret = msd_waitonebyte(5);
msd_waitonebyte(1);
return ret;
msd_command(MSD_CMD_DISK_CONNECT);
return msd_waitonebyte(3);
char msd_mount()
char ret , trys;
for(trys = 0; trys < 3 ; trys++)
// check version
ret = msd_getversion();
if(ret == MSD_RET_ABORT)
continue;
// set mode of operation
ret = mds_setmode(6);
if(ret != MSD_RET_SUCCESS)
continue;
// mount mass storage
msd_command(MSD_CMD_DISK_MOUNT);
ret = msd_waitonebyte(20);
if(ret == MSD_USB_INT_SUCCESS)
return MSD_USB_INT_SUCCESS;
return ret;
char ret , trys;
unsigned char i;
char *temp = &diskSpaces;
msd_command(MSD_CMD_DISK_QUERY);
if(ret != MSD_USB_INT_SUCCESS)
continue;
//09 E8 3F 77 00 68 61 55 00 03 14
msd_command(MSD_CMD_RD_USB_DATA0);
ret = msd_waitonebyte(3);
if(ret != 0x09)
continue;
for(i = 0; i < 8; i++)
*temp = msd_waitonebyte(1);
temp++;
if(msd_timeout)
continue;
diskSpaces.msd_diskSize /= 2; // convert to kilobyte
diskSpaces.msd_diskFree /= 2; // convert to kilobyte
* CH375_Test1.c
* Created: 11/5/2011 9:41:27 PM
* Author: Mostafa
#include <avr/io.h>
#include "MSD Lib/MSDlib.h"
#include "lcd_lib.h"
#include <stdio.h>
#include <avr/interrupt.h>
int main(void)
LCDinit();
LCDGotoXY(0,0);
sei();
msd_init();
if( msd_mount() == MSD_USB_INT_SUCCESS)
printf_P((char*)PSTR("T:%ld") ,diskSpaces.msd_diskSize);
LCDGotoXY(0,1);
printf_P((char*)PSTR("T:%ld") ,diskSpaces.msd_diskFree);
while(1)
//TODO:: Please write your application code
