با سلام وخسته نباشید
من چند مدتی هست که کدویژنو دانلود کردم رو LCDگرافیکش کار می کنه یه مشکلی پیش اومده تابعی که برای عکس گذاشتن روی LCDهست ادرس عکسو بهش می دم اما روی LCDهیچی نمایش داده نمی شه
اینم برنامه (ممنون می شم که کمکم کنید)
#include <mega16.h>
#include <delay.h>
// Graphic LCD functions
#include <glcd.h>
// Font used for displaying text
// on the graphic LCD
#include <font5x7.h>
// Function used for reading image
// data from external memory
/*unsigned char read_ext_memory(GLCDMEMADDR_t addr)
unsigned char data;
// Place your code here
return data;
// Function used for writing image
// data to external memory
/*void write_ext_memory(GLCDMEMADDR_t addr, unsigned char data)
//flash unsigned char buffer[6]={0x7E, 0x11, 0x11, 0x11, 0x7E, 0x00};
flash unsigned char buffer[1024]={
0, 0, 0,192, 0, 0, 0, 0,192, 0, 0,128, 64, 64, 64, 64,
0, 0,128, 64, 64,128,128, 0, 0, 0, 0, 64,248, 68, 68, 4,
64, 64, 64,128, 0, 0, 0,192, 64, 64, 64, 64,128, 64, 64, 64,
64,128, 0,196, 0, 0,252, 0, 0,196, 0, 0, 0, 0, 64, 64,
64,128, 0, 0,128,128, 64, 0, 0, 0, 0, 0,128, 64, 64, 64,
64,192, 0, 0, 0,128, 64, 0,192, 64, 64, 64, 64,128, 64, 64,
64, 64,128, 0,252, 64, 64, 64,128, 0, 0, 0,128, 64, 64, 64,
128, 0, 0, 0,252, 0, 0,128, 64, 64, 64, 64, 0, 0, 0, 0,
0, 0, 0, 15, 16, 16, 16, 16, 31, 0, 0, 9, 18, 18, 12, 0,
0, 15, 18, 18, 18, 18, 11, 2, 0, 0, 0, 0, 31, 0, 0, 12,
18, 17, 17, 31, 0, 0, 0, 31, 0, 0, 0, 0, 31, 0, 0, 0,
0, 31, 0, 31, 0, 0, 31, 0, 0, 31, 0, 0, 0, 12, 18, 17,
17, 31, 0, 0, 31, 0, 0, 0, 0, 0, 0, 0, 9, 18, 18, 12,
0,129,198, 56, 6, 1, 0, 0, 31, 0, 0, 0, 0, 31, 0, 0,
0, 0, 31, 0, 31, 16, 16, 16, 8, 7, 0, 0, 15, 16, 16, 16,
8, 7, 0, 0, 31, 0, 0, 9, 18, 18, 12, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 64,224,
240,240, 96, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,240,248,248,240,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0,224,160, 32, 32, 32, 32, 32, 32, 32, 32, 32, 32, 32, 32, 32,
32, 32, 32, 32, 32,160,224, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0,192,224,112, 48, 56,248,252,252,254,254,252,
249,128, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,255,255,255,255,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 48,248,252,
252,252,248, 56, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0,255, 0, 1, 2, 4,136,208, 96, 64, 64, 64, 64, 64, 64, 96,
208,136, 4, 2, 1, 0,255, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 31, 31, 0, 0,252,255,255,255,255,199, 1,
3, 7, 6, 14, 12, 28, 24, 24, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0,128,192,192,224,240,240,248,248,252,255,255,255,255,
254,252,248,248,240,240,224,192,192,128, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,128, 0,255,255,
255,192,192,192,192,192,192,192,192, 0, 0, 0, 0, 0, 0, 0,
0, 31, 24, 28, 22, 19, 17, 16, 16, 16, 16, 16, 16, 16, 16, 16,
16, 17, 19, 22, 28, 24, 31, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0,192,248,255,127, 31, 7, 3, 7, 31,255,
254,248,192, 0, 0, 0, 0, 0, 0, 0, 0, 0,112,120,124, 62,
62, 63, 31, 31, 31, 15, 15, 15, 7, 7, 7, 3,255,255,255,255,
3, 3, 7, 7, 7, 15, 15, 15, 31, 31, 31, 63, 62, 62,124,120,
112, 0, 0, 0, 0, 0,128,240,252, 28, 6, 7, 3, 0, 31, 31,
31, 25, 25, 25, 25, 25, 25, 25, 25, 24, 24,248,248,240,128, 0,
0, 0, 0, 0, 16, 30, 31, 7, 1, 0, 0, 0, 0, 0, 0, 0,
7, 31, 31, 28, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0,128,128,192,224,255,255,127,255,
240,224,192,128,128, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 3, 31, 62,248,240,192,128,128, 0, 0,
0, 0, 0, 0, 0, 0, 0,128,192,224,240,112, 7, 63,255,252,
224, 96, 96,112, 48, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 3, 3, 1, 1, 0, 0, 0, 0,
0, 1, 1, 3, 3, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1, 1, 1, 3, 3, 3,
6, 6, 6, 6, 7, 7, 3, 3, 3, 1, 0, 0, 0, 0, 0, 0,
void main(void)
// Graphic LCD initialization data
GLCDINIT_t glcd_init_data;
// Port A initialization
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
//PORTC=0x00;
DDRC=0xff;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Clock source: System Clock
// Mode: Normal top=0xFF
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
TIMSK=0x00;
// USART initialization
// USART disabled
UCSRB=0x00;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC disabled
ADCSRA=0x00;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
// The KS0108 connections are specified in the
// Project|Configure|C Compiler|Libraries|Graphic LCD menu:
// DB0 - PORTB Bit 0
// DB1 - PORTB Bit 1
// DB2 - PORTB Bit 2
// DB3 - PORTB Bit 3
// DB4 - PORTB Bit 4
// DB5 - PORTB Bit 5
// DB6 - PORTB Bit 6
// DB7 - PORTB Bit 7
// E - PORTD Bit 0
// RD /WR - PORTD Bit 1
// RS - PORTD Bit 2
// /RST - PORTD Bit 3
// CS1 - PORTD Bit 4
// CS2 - PORTD Bit 5
// Specify the current font for displaying text
glcd_init_data.font=font5x7;
// No function is used for reading
// image data from external memory
glcd_init_data.readxmem=NULL;
// No function is used for writing
// image data to external memory
glcd_init_data.writexmem=NULL;
glcd_init(&glcd_init_data);
glcd_clear();
while (1)
glcd_putimagef(0,0,buffer,GLCD_PUTNOT);
