با سلام من میخوام یه فلاشر درست کنم و سرعت چشمک زدن led ها رو با دوتا شاستی کم و زیاد کنم
لطفا با bascom راهنمایی کنید
$regfile = "m8def.dat" $crystal = 1000000 Config Portb = Output Config Portc = Output Config Int0 = Falling Config Int1 = Falling Enable Interrupts Enable Int0 Enable Int1 On Int0 Updelay On Int1 Downdelay Dim W As Word W = 500 Do Portb = 0 Portc = 0 Waitms 1 Portb = &B00000001 Waitms W Portb = &B00000011 Waitms W Portb = &B00000111 Waitms W Portb = &B00001111 Waitms W Portb = &B00011111 Waitms W Portb = &B00111111 Waitms W Portb = &B01111111 Portc = &B11111111 Waitms W Portc = &B01111111 Waitms W Portc = &B00111111 Waitms W Portc = &B00011111 Waitms W Portc = &B00001111 Waitms W Portc = &B00000111 Waitms W Portc = &B00000011 Waitms W Portc = &B00000001 Waitms W Loop End Updelay: If W < 1501 Then W = W + 100 Return Downdelay: If W > 0 Then W = W - 100 Return
