پاسخ : led چشمک زن در کنار برنامه اصلی
این همون برنامه است
منتها کارکتراش رو فارسی کردم
همراه با ارور ها...
این همون برنامه است
همراه با ارور ها...
$regfile = "M8def.dat"
$crystal = 8000000
Config Lcdpin = Pin , Db4 = Portb.2 , Db5 = Portb.3 , Db6 = Portb.4 , Db7 = _
Portb.5 , E = Portd.2 , Rs = Portd.3
Config Lcd = 16 * 2
Config Keyboard = Pinb.1 , Data = Pinb.0 , Keydata = Keydata
Config Portd = Output
Config Timer1 = Timer , Prescale = 1
Enable Interrupts
Enable Timer1
Start Timer1
Enable Ovf1
On Ovf1 Led
Dim A As Byte
Waitms 500
Cls
Deflcdchar 7 , 32 , 1 , 1 , 1 , 29 , 21 , 29 , 1 ' replace ? with number (0-7)
Deflcdchar 6 , 32 , 32 , 32 , 4 , 31 , 32 , 24 , 32 ' replace ? with number (0-7)
Deflcdchar 5 , 32 , 32 , 32 , 2 , 1 , 5 , 5 , 7 ' replace ? with number (0-7)
Deflcdchar 4 , 32 , 32 , 32 , 32 , 28 , 20 , 28 , 32 ' replace ? with number (0-7)
Deflcdchar 3 , 4 , 8 , 18 , 18 , 31 , 32 , 32 , 32 ' replace ? with number (0-7)
Deflcdchar 2 , 32 , 32 , 32 , 32 , 3 , 4 , 18 , 30 ' replace ? with number (0-7)
Cls
Locate 1 , 5
Lcd Chr(2) ; Chr(3) ; Chr(4) ; Chr(5) ; Chr(6) ; Chr(7)
Main:
A = Getatkbd()
Select Case A:
Case 81:
Gosub Q
Case 87:
Gosub W
Case 69:
Gosub E
Case 82:
Gosub R
Case 84:
Gosub T
Case 89:
Gosub Y
Case 85:
Gosub U
Case 73:
Gosub I
Case 79:
Gosub O
Case 80:
Gosub P
Case 219:
Gosub Je
Case 221:
Gosub Che
Case 65:
Gosub Ae
Case 83:
Gosub S
Case 68:
Gosub D
Case 70:
Gosub F
Case 71:
Gosub G
Case 72:
Gosub H
Case 74:
Gosub J
Case 75:
Gosub K
Case 76:
Gosub L
Case 186:
Gosub Ke
Case 222:
Gosub Ge
Case 90:
Gosub Z
Case 88:
Gosub X
Case 67:
Gosub C
Case 86:
Gosub V
Case 66:
Gosub B
Case 78:
Gosub N
Case 77:
Gosub M
Case 192:
Gosub Pe
Case 220:
Gosub Jhe
Case 50:
Lowerline
Case 56:
Home
Case 44:
Cls
Home
Case 52:
Shiftcursor Left
Case 54:
Shiftcursor Right
Case 13:
Lowerline
Case 9:
Shiftcursor Right , 4
Case 8:
Shiftcursor Left
Lcd " ";
Shiftcursor Left
Case Else Lcd String(1 , A)
End Select
jmp main
End 'end program
Keydata:
'normal keys lower case
Data 0 , 0 , 0 , 0 , 0 , 0 , 0 , 27 , 0 , 0 , 0 , 0 , 9 , 9 , &H5E , 0
Data 0 , 0 , 0 , 0 , 0 , 113 , 49 , 0 , 0 , 0 , 122 , 115 , 97 , 119 , 50 , 0
Data 0 , 99 , 120 , 100 , 101 , 52 , 51 , 0 , 0 , 32 , 118 , 102 , 116 , 114 , 53 , 0
Data 0 , 110 , 98 , 104 , 103 , 121 , 54 , 7 , 8 , 44 , 109 , 106 , 117 , 55 , 56 , 0
Data 0 , 44 , 107 , 105 , 111 , 48 , 57 , 0 , 0 , 46 , 45 , 108 , 48 , 112 , 43 , 0
Data 0 , 0 , 0 , 0 , 0 , 92 , 0 , 0 , 0 , 0 , 13 , 0 , 0 , 92 , 0 , 0
Data 0 , 60 , 0 , 0 , 0 , 0 , 8 , 0 , 0 , 49 , 0 , 52 , 55 , 0 , 0 , 0
Data 48 , 44 , 50 , 53 , 54 , 56 , 0 , 0 , 0 , 43 , 51 , 45 , 42 , 57 , 0 , 0
'shifted keys UPPER case
Data 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0 , 0
Data 0 , 0 , 0 , 0 , 0 , 81 , 33 , 0 , 0 , 0 , 90 , 83 , 65 , 87 , 34 , 0
Data 0 , 67 , 88 , 68 , 69 , 0 , 35 , 0 , 0 , 32 , 86 , 70 , 84 , 82 , 37 , 0
Data 0 , 78 , 66 , 72 , 71 , 89 , 38 , 0 , 0 , 76 , 77 , 74 , 85 , 47 , 40 , 0
Data 0 , 59 , 75 , 73 , 79 , 61 , 41 , 0 , 0 , 58 , 95 , 76 , 48 , 80 , 63 , 0
Data 0 , 0 , 0 , 0 , 0 , 96 , 0 , 0 , 0 , 0 , 13 , 94 , 0 , 42 , 0 , 0
Data 0 , 62 , 0 , 0 , 0 , 8 , 0 , 0 , 49 , 0 , 52 , 55 , 0 , 0 , 0 , 0
Led:
Incr L
If L=< 100 Then
Portd.4 = 0
elseIf L> 100 Then
Portd.4 = 1
End If
if l=200 then l=0
Return
Q:
Deflcdchar 0 , 2 , 32 , 2 , 5 , 7 , 20 , 20 , 28 ' replace 0 with number (0-7)
Cls
Lcd Chr(0)
Return
W:
Deflcdchar 0 , 32 , 32 , 2 , 5 , 7 , 20 , 20 , 28 ' replace 0 with number (0-7)
Cls
Lcd Chr(0)
Return
E:
Deflcdchar 0 , 32 , 4 , 10 , 32 , 17 , 31 , 32 , 32 ' replace 0 with number (0-7)
Cls
Lcd Chr(0)
Return
R:
Deflcdchar 0 , 3 , 32 , 7 , 5 , 7 , 17 , 17 , 31 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
T:
Deflcdchar 0 , 32 , 1 , 32 , 3 , 19 , 31 , 32 , 32 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
Y:
Deflcdchar 0 , 2 , 32 , 7 , 4 , 15 , 8 , 8 , 15 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
U:
Deflcdchar 0 , 32 , 32 , 7 , 4 , 15 , 8 , 8 , 15 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
I:
Deflcdchar 0 , 32 , 2 , 5 , 5 , 31 , 5 , 5 , 2 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
O:
Deflcdchar 0 , 4 , 32 , 4 , 10 , 1 , 6 , 8 , 7 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
P:
Deflcdchar 0 , 32 , 32 , 4 , 10 , 1 , 6 , 8 , 7 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
Je:
Deflcdchar 0 , 4 , 10 , 1 , 6 , 8 , 10 , 8 , 7 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
Che:
Deflcdchar 0 , 4 , 10 , 2 , 12 , 17 , 18 , 17 , 12 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
Ae:
Deflcdchar 0 , 21 , 32 , 21 , 31 , 8 , 4 , 18 , 30 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
S:
Deflcdchar 0 , 32 , 32 , 21 , 31 , 8 , 4 , 18 , 30 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
D:
Deflcdchar 0 , 32 , 32 , 32 , 3 , 2 , 17 , 17 , 14 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
F:
Deflcdchar 0 , 32 , 32 , 32 , 32 , 17 , 31 , 32 , 4 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
G:
Deflcdchar 0 , 32 , 1 , 1 , 1 , 1 , 1 , 17 , 14 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
H:
Deflcdchar 0 , 1 , 31 , 16 , 4 , 4 , 4 , 4 , 4 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
J:
Deflcdchar 0 , 32 , 32 , 10 , 32 , 17 , 31 , 32 , 32 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
K:
Deflcdchar 0 , 32 , 32 , 4 , 32 , 17 , 17 , 17 , 31 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
L:
Deflcdchar 0 , 32 , 2 , 5 , 5 , 31 , 16 , 16 , 16 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
Ke:
Deflcdchar 0 , 32 , 1 , 2 , 4 , 6 , 3 , 17 , 31 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
Ge:
Deflcdchar 0 , 2 , 5 , 10 , 4 , 6 , 3 , 17 , 31 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
Z:
Deflcdchar 0 , 8 , 8 , 10 , 8 , 10 , 13 , 9 , 31 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
X:
Deflcdchar 0 , 8 , 8 , 8 , 8 , 10 , 13 , 9 , 31 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
C:
Deflcdchar 0 , 32 , 1 , 32 , 1 , 1 , 3 , 6 , 28 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
V:
Deflcdchar 0 , 32 , 32 , 32 , 1 , 1 , 3 , 6 , 28 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
B:
Deflcdchar 0 , 4 , 32 , 4 , 6 , 3 , 1 , 3 , 6 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
N:
Deflcdchar 0 , 32 , 32 , 4 , 6 , 3 , 1 , 3 , 6 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
M:
Pe:
Deflcdchar 0 , 32 , 32 , 32 , 17 , 31 , 32 , 10 , 4 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
Jhe:
Deflcdchar 0 , 2 , 5 , 32 , 1 , 1 , 1 , 2 , 12 ' replace ? with number (0-7)
Cls
Lcd Chr(0)
Return
