سلام ، یه برنامه خازن سنج دارم که به زبان C برای میکرو pic نوشته شده ، دوستان اگه بتونند این برنامه به زبان بیسیک برای میکروهای AVR مثلا ATMEGA 32 درست کنند خیلی خیلییییی ممنون میشم.
این هم خود برنامه :
Description : CapMeter based on RC time constant
MCU: PIC16F28A
Oscillator: HS, 4.0000 MHz external
// LCD module connections
sbit LCD_RS at RB2_bit;
sbit LCD_EN at RB3_bit;
sbit LCD_D4 at RB4_bit;
sbit LCD_D5 at RB5_bit;
sbit LCD_D6 at RB6_bit;
sbit LCD_D7 at RB7_bit;
sbit LCD_RS_Direction at TRISB2_bit;
sbit LCD_EN_Direction at TRISB3_bit;
sbit LCD_D4_Direction at TRISB4_bit;
sbit LCD_D5_Direction at TRISB5_bit;
sbit LCD_D6_Direction at TRISB6_bit;
sbit LCD_D7_Direction at TRISB7_bit;
sbit Va at RA0_bit;
sbit Switch at RB0_bit;
char message1[] = "Capacitance";
char message2[] = "Meter";
unsigned int T_Value, Num;
unsigned short i, j, TimerValue, OverRange = 0;
char Capacitance[] = "00.000 uF";
void interrupt(){
if(PIR1.TMR2IF){
TMR2 = TimerValue;
Num ++;
if(Num > 9999) OverRange = 1; // Range is 99.99 uF
PIR1.TMR2IF =0; // Clear TMR0 interrupt flag
void Display_Cap(unsigned int n){
Capacitance[0] = n/10000 + 48;
Capacitance[1] = (n/1000)%10 + 48;
Capacitance[3] = (n/100)%10 + 48;
Capacitance[4] = (n/10)%10 + 48;
Capacitance[5] = (T_Value*10)/153 + 48;
Lcd_Cmd(_Lcd_Clear);
Lcd_Out(1, 1, "C = "
Lcd_Out(1, 5, Capacitance);
void reset(){
TRISA = 0b00000100;
CMCON = 7;
RA1_bit = 0;
Delay_ms(2000);
TRISA = 0b00000110;
CMCON = 5;
void main(){
char cap_size;
TRISB = 0b00000001;
PORTB = 0;
TRISA = 0b00000110;
OPTION_REG.T0CS = 0;
INTCON.GIE = 1; //Enable global interrupt
INTCON.PEIE = 1; //Enable peripheral interrupt
// Configure Timer2 module
PIE1.TMR2IE = 1; // Enable Timer2 interrupt
T2CON = 0; // Prescaler 1:1, and Timer2 is off initially
PIR1.TMR2IF =0; // Clear int bit
// Configure Comparator module
CMCON = 5; // Independent comparator between RA1 (-) and RA2(+)
Lcd_Init();
Lcd_Cmd(_LCD_CURSOR_OFF);
Lcd_Out(1, 1, message1);
Lcd_Out(2, 1, message2);
delay_ms(2000);
Va = 0;
TimerValue = 108; // 104 + 4 additional clock cycles delay on branching to ISR
while(1){
if(!Switch) {
Num = 0;
OverRange =0;
Lcd_Out(1, 1, "Testing."
Lcd_Out(2, 1, "..."
TMR2 = TimerValue; // Initialize Timer2
Va = 1; //apply voltage
T2CON.TMR2ON = 1; // start timer
while(CMCON.C2OUT) {
if(OverRange) break;
T2CON.TMR2ON = 0; // stop timer
T_Value = TMR2 - TimerValue; // T_Value is used for improved resolution
Va = 0;
if(!OverRange){
Display_Cap(Num*10);
else{
OverRange = 0;
Lcd_Out(1, 1, "Out of Range!"
reset();
این هم خود برنامه :
MCU: PIC16F28A
sbit Va at RA0_bit;
void interrupt(){
if(PIR1.TMR2IF){
TMR2 = TimerValue;
Num ++;
;Lcd_Out(1, 5, Capacitance);
void reset(){
TRISA = 0b00000100;
CMCON = 7;
RA1_bit = 0;
Delay_ms(2000);
TRISA = 0b00000110;
CMCON = 5;
void main(){
char cap_size;
TRISB = 0b00000001;
PORTB = 0;
TRISA = 0b00000110;
Lcd_Init();
delay_ms(2000);
Va = 0;
while(1){
if(!Switch) {
Num = 0;
OverRange =0;
;Lcd_Out(2, 1, "..."
;TMR2 = TimerValue; // Initialize Timer2
Va = 0;
if(!OverRange){
else{
OverRange = 0;
reset();
