سلام بر اساتید محترم انجمن
من دوتا کد به زبان کد ویژن دارم اگه از اساتید محترم لطف کرده واونوبه بسکام ترجمه کنن ممنون میشم
کد بعدی:
CodeWizardAVR V2.05.3 Standard
Automatic Program Generator
© Copyright 1998-2011 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 07/04/2012
Author : Mahbod
Company :
Comments:
Chip type : ATmega8
Program type : Application
Memory model : Small
External RAM size : 0
Data Stack size : 256
#include <mega8.h>
// Alphanumeric LCD functions
#include <alcd.h>
#ifndef RXB8
#define RXB8 1
#endif
#ifndef TXB8
#define TXB8 0
#endif
#ifndef UPE
#define UPE 2
#endif
#ifndef DOR
#define DOR 3
#endif
#ifndef FE
#define FE 4
#endif
#ifndef UDRE
#define UDRE 5
#endif
#ifndef RXC
#define RXC 7
#endif
#define FRAMING_ERROR (1<<FE)
#define PARITY_ERROR (1<<UPE)
#define DATA_OVERRUN (1<<DOR)
#define RX_COMPLETE (1<<RXC)
// USART Receiver buffer
#define RX_BUFFER_SIZE 8
#if RX_BUFFER_SIZE <= 256
unsigned char rx_wr_index,rx_rd_index,rx_counter;
#else
unsigned int rx_wr_index,rx_rd_index,rx_counter;
#endif
// This flag is set on USART Receiver buffer overflow
bit rx_buffer_overflow;
char status,data;
status=UCSRA;
data=UDR;
//data processing
if(data == '$'
lcd_clear();
if(data != '@' && data != '$'
lcd_putchar(data);
rx_buffer[rx_wr_index++]=data;
#if RX_BUFFER_SIZE == 256
if (++rx_counter == 0) rx_buffer_overflow=1;
#else
if (rx_wr_index == RX_BUFFER_SIZE) rx_wr_index=0;
rx_counter=0;
#endif
#ifndef _DEBUG_TERMINAL_IO_
// Get a character from the USART Receiver buffer
#define _ALTERNATE_GETCHAR_
#pragma used+
char getchar(void)
char data;
while (rx_counter==0);
data=rx_buffer[rx_rd_index++];
#if RX_BUFFER_SIZE != 256
if (rx_rd_index == RX_BUFFER_SIZE) rx_rd_index=0;
#endif
#asm("cli"
--rx_counter;
#asm("sei"
return data;
#pragma used-
#endif
// Standard Input/Output functions
#include <stdio.h>
void main(void)
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
// Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Clock source: System Clock
TCCR0=0x00;
TCNT0=0x00;
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
MCUCR=0x00;
TIMSK=0x00;
// USART initialization
// USART Receiver: On
// USART Transmitter: Off
// USART Mode: Asynchronous
// USART Baud Rate: 4800
UCSRA=0x00;
UCSRB=0x90;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=0x67;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC disabled
ADCSRA=0x00;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
// Alphanumeric LCD initialization
// Connections are specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTB Bit 0
// RD - PORTB Bit 1
// EN - PORTB Bit 2
// D4 - PORTB Bit 4
// D5 - PORTB Bit 5
// D6 - PORTB Bit 6
// D7 - PORTB Bit 7
// Characters/line: 16
lcd_init(16);
// Global enable interrupts
#asm("sei"
while (1)
// Place your code here
Project :
Version :
Date : 07/04/2012
Author : Mahbod
Company :
Comments:
Chip type : ATmega8
#include <mega8.h>
#include <alcd.h>
#ifndef RXB8
#define RXB8 1
#endif
#ifndef TXB8
#define TXB8 0
#endif
#ifndef UPE
#define UPE 2
#endif
#ifndef DOR
#define DOR 3
#endif
#ifndef FE
#define FE 4
#endif
#ifndef UDRE
#define UDRE 5
#endif
#ifndef RXC
#define RXC 7
#endif
#else
#endif
char status,data;
status=UCSRA;
data=UDR;
//data processing
if(data == '$'
lcd_clear();if(data != '@' && data != '$'
lcd_putchar(data);
#else
rx_counter=0;
#endif
#pragma used+
char getchar(void)
char data;
#endif
#asm("cli"
--rx_counter;
#asm("sei"
return data;
#pragma used-
#endif
#include <stdio.h>
void main(void)
PORTB=0x00;
DDRB=0x00;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0x00;
TCCR0=0x00;
TCNT0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
MCUCR=0x00;
TIMSK=0x00;
UCSRA=0x00;
UCSRB=0x90;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=0x67;
ACSR=0x80;
SFIOR=0x00;
// ADC disabled
ADCSRA=0x00;
// SPI disabled
SPCR=0x00;
// TWI disabled
TWCR=0x00;
// RS - PORTB Bit 0
// RD - PORTB Bit 1
// EN - PORTB Bit 2
// D4 - PORTB Bit 4
// D5 - PORTB Bit 5
// D6 - PORTB Bit 6
// D7 - PORTB Bit 7
lcd_init(16);
#asm("sei"
while (1)
Project :
Version :
Date : 07/04/2012
Author : Mahbod
Company :
Comments:
Chip type : ATmega8
#include <mega8.h>
#include <alcd.h>
#include <stdio.h>
#include <delay.h>
#define CHAR_UP PIND.2
#define NUM_UP PIND.3
#define PUN_UP PIND.4
#define ENTER PIND.5
#define BCK_SPC PIND.6
#define SEND PIND.7
#define CHAR_COUNT 26
#define NUM_COUNT 10
#define PUN_COUNT 4
char characters[] = {'a', 'b', 'c', 'd', 'e', 'f', 'g', 'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o', 'p', 'q', 'r', 's', 't', 'u', 'v', 'w', 'x', 'y', 'z'};
char numbers[] = {'0', '1', '2', '3', '4', '5', '6', '7', '8', '9'};
char puncts[] = {'.', ',', ' ', '-'};
char count_char=-1, count_num=-1, count_pun=-1;
char code='@';
char lcd_buffer[16], data_buffer[17];
char buffer_pointer=0;
interrupt [TIM1_OVF] void timer1_ovf_isr(void){
TCNT1 = 0xFD8F;
putchar(code);
void back_space(void){
lcd_buffer[buffer_pointer] = '';
if(buffer_pointer != 0)
buffer_pointer--;
void add_char(char c){
lcd_buffer[buffer_pointer] = c;
if(buffer_pointer == 16)
buffer_pointer = 0;
void main(void)
PORTB=0x00;
DDRB=0x00;
PORTC=0x00;
DDRC=0x00;
// State7=T State6=T State5=P State4=P State3=P State2=P State1=P State0=p
PORTD=0xfc;
DDRD=0x00;
TCCR0=0x00;
TCNT0=0x00;
TCCR1A = 0x00;
TCCR1B = 0x04;
TCNT1 = 0xFD8F;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
MCUCR=0x00;
TIMSK=0x04;
// USART Receiver: Off
// USART Transmitter: On
UCSRA=0x00;
UCSRB=0x08;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=0x67;
ACSR=0x80;
SFIOR=0x00;
// ADC disabled
ADCSRA=0x00;
// SPI disabled
SPCR=0x00;
// TWI disabled
TWCR=0x00;
#asm("sei"
// RS - PORTB Bit 0
// RD - PORTB Bit 1
// EN - PORTB Bit 2
// D4 - PORTB Bit 4
// D5 - PORTB Bit 5
// D6 - PORTB Bit 6
// D7 - PORTB Bit 7
lcd_init(16);
delay_ms(250);
lcd_clear();
lcd_putsf("TEST"
delay_ms(1000);
lcd_clear();
_lcd_write_data(0x0f);
while (1)
if(CHAR_UP==0){
count_char++;
if(count_char == CHAR_COUNT)
count_char = 0;
add_char(characters[count_char]);
lcd_clear();
lcd_puts(lcd_buffer);
while(CHAR_UP==0);
if(NUM_UP==0){
count_num++;
if(count_num == NUM_COUNT)
count_num = 0;
add_char(numbers[count_num]);
lcd_clear();
while(NUM_UP==0);
if(PUN_UP==0){
count_pun++;
if(count_pun == PUN_COUNT)
count_pun = 0;
add_char(puncts[count_pun]);
lcd_clear();
while(PUN_UP==0);
if(ENTER==0){
count_char = count_num = count_pun = -1;
buffer_pointer++;
lcd_clear();
while(ENTER==0);
if(BCK_SPC == 0){
back_space();
lcd_clear();
while(BCK_SPC==0);
if(SEND==0){
sprintf(data_buffer, "$%s", lcd_buffer);
puts(data_buffer);
while(SEND==0);
Project :
Version :
Date : 07/04/2012
Author : Mahbod
Company :
Comments:
Chip type : ATmega8
#include <mega8.h>
#include <alcd.h>
#include <stdio.h>
#include <delay.h>
#define SEND PIND.7
#define PUN_COUNT 4
char code='@';
TCNT1 = 0xFD8F;
putchar(code);
buffer_pointer--;
buffer_pointer = 0;
void main(void)
PORTB=0x00;
DDRB=0x00;
PORTC=0x00;
DDRC=0x00;
PORTD=0xfc;
DDRD=0x00;
TCCR0=0x00;
TCNT0=0x00;
TCCR1A = 0x00;
TCCR1B = 0x04;
TCNT1 = 0xFD8F;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
MCUCR=0x00;
TIMSK=0x04;
UCSRA=0x00;
UCSRB=0x08;
UCSRC=0x86;
UBRRH=0x00;
UBRRL=0x67;
ACSR=0x80;
SFIOR=0x00;
// ADC disabled
ADCSRA=0x00;
// SPI disabled
SPCR=0x00;
// TWI disabled
TWCR=0x00;
#asm("sei"
// RS - PORTB Bit 0
// RD - PORTB Bit 1
// EN - PORTB Bit 2
// D4 - PORTB Bit 4
// D5 - PORTB Bit 5
// D6 - PORTB Bit 6
// D7 - PORTB Bit 7
lcd_init(16);
delay_ms(250);
lcd_clear();
lcd_putsf("TEST"
;delay_ms(1000);
lcd_clear();
while (1)
if(CHAR_UP==0){
count_char++;
count_char = 0;
lcd_clear();
while(CHAR_UP==0);
if(NUM_UP==0){
count_num++;
count_num = 0;
lcd_clear();
while(NUM_UP==0);
if(PUN_UP==0){
count_pun++;
count_pun = 0;
lcd_clear();
while(PUN_UP==0);
if(ENTER==0){
buffer_pointer++;
lcd_clear();
while(ENTER==0);
if(BCK_SPC == 0){
back_space();
lcd_clear();
while(BCK_SPC==0);
if(SEND==0){
puts(data_buffer);
while(SEND==0);
