سلام بچه ها
یه کد داشتم که می خواستم یکی برام تحلیلش کنه که بدونم این چطوریه. این کد:
اینم فایل sin.h :
یه درخواست هم دارم. این کد واسه کامپایلر کدویژن نوشته نشده. همین کد توی کد ویژن چطوری میشه؟
DESCRIPTION: A Simple program to genarate some random
musical tone.
MCU: Atmel AVR ATmega32
CPU SPEED: 16Mhz
LOW FUSE: 0XFF
HIGH FUSE: 0XC9
NOTE: Connect a 8ohm speaker between GND and PB3.
AUTHOR: Avinash Gupta
DATE: Mar 18, 2010
WEB: www.eXtremeElectronics.co.in
*** THIS PROJECT IS PROVIDED FOR EDUCATION/HOBBY USE ONLY ***
*** NO PROTION OF THIS WORK CAN BE USED IN COMMERIAL ***
*** APPLICATION WITHOUT WRITTEN PERMISSION FROM THE AUTHOR ***
EVERYONE IS FREE TO POST/PUBLISH THIS ARTICLE IN
PRINTED OR ELECTRONIC FORM IN FREE/PAID WEBSITES/MAGAZINES/BOOKS
IF PROPER CREDIT TO ORIGINAL AUTHOR IS MENTIONED WITH LINKS TO
ORIGINAL ARTICLE
COPYRIGHT (C) 2008-2010 EXTREME ELECTRONICS INDIA.
#include <avr/io.h>
#include <util/delay.h>
#include <avr/pgmspace.h>
#include "sin.h"
Function To Initialize TIMER0 In Fast
PWWM Mode.
void InitPWM()
TCCR0 - Timer Counter Control Register (TIMER0)
BITS DESCRIPTION
NO: NAME DESCRIPTION
BIT 7 : FOC0 Force Output Compare [Not used in this example]
BIT 6 : WGM00 Wave form generartion mode [SET to 1]
BIT 5 : COM01 Compare Output Mode [SET to 1]
BIT 4 : COM00 Compare Output Mode [SET to 0]
BIT 3 : WGM01 Wave form generartion mode [SET to 1]
BIT 2 : CS02 Clock Select [SET to 0]
BIT 1 : CS01 Clock Select [SET to 0]
BIT 0 : CS00 Clock Select [SET to 1]
The above settings are for
Timer Clock = CPU Clock (No Prescalling)
Mode = Fast PWM
PWM Output = Non Inverted
TCCR0|=(1<<WGM00)|(1<<WGM01)|(1<<COM01)|(1<<CS00);
//Set OC0 PIN as output. It is PB3 on ATmega16 ATmega32
DDRB|=(1<<PB3);
void main()
uint8_t i;
InitPWM();
while(1)
uint8_t delay,n;
for(delay=1;delay<=50;delay++)
for(n=0;n<(51-delay);n++)
for(i=0;i<=254;i++)
OCR0=pgm_read_byte_near(sine+i);
_delay_loop_2(delay);
for(delay=50;delay>=2;delay--)
for(i=0;i<=254;i++)
اینم فایل sin.h :
prog_uint8_t sine[256]={
127,
130,
133,
136,
139,
143,
146,
149,
152,
155,
158,
161,
164,
167,
170,
173,
176,
178,
181,
184,
187,
189,
192,
195,
197,
200,
203,
205,
207,
210,
212,
214,
217,
219,
221,
223,
225,
227,
229,
231,
232,
234,
236,
237,
239,
240,
242,
243,
244,
245,
246,
248,
248,
249,
250,
251,
251,
252,
253,
253,
253,
254,
254,
254,
254,
254,
254,
254,
253,
253,
253,
252,
252,
251,
250,
250,
249,
248,
247,
246,
245,
243,
242,
241,
239,
238,
236,
235,
233,
231,
229,
227,
225,
224,
221,
219,
217,
215,
213,
210,
208,
206,
203,
201,
198,
195,
193,
190,
187,
185,
182,
179,
176,
173,
170,
167,
164,
161,
158,
155,
152,
149,
146,
143,
140,
137,
134,
131,
128,
125,
121,
118,
115,
112,
109,
106,
103,
100,
97,
94,
91,
88,
85,
82,
79,
76,
73,
71,
68,
65,
62,
60,
57,
55,
52,
50,
47,
45,
42,
40,
38,
36,
34,
31,
29,
27,
26,
24,
22,
20,
19,
17,
15,
14,
13,
11,
10,
9,
8,
7,
6,
5,
4,
3,
3,
2,
2,
1,
1,
0,
0,
0,
0,
0,
0,
0,
1,
1,
1,
2,
2,
3,
4,
4,
5,
6,
7,
8,
9,
10,
12,
13,
14,
16,
17,
19,
21,
22,
24,
26,
28,
30,
32,
34,
36,
39,
41,
43,
45,
48,
50,
53,
55,
58,
61,
63,
66,
69,
72,
74,
77,
80,
83,
86,
89,
92,
95,
98,
101,
104,
107,
110,
113,
116,
119,
122,
