بنده مدار رو که در فایل ضمیمه قرار دادم رو درست کردم که ارتباط enc28j60 با atmega8 هست ولی وقتی مدارو وصل میکنم به کامپیوتر با کابل شبکه localarea connection فعال میشه ولی زیرش مینویسه unidentified network و تنظیمات ipv4 رو هم انجام دادم و ping که میکنم لحظه ای که کابل وصل میشه پیغام زیرو میده ولی بعدش time out mide کسی میدونه مشکل کجاست کمک کنه
Reply from 10.0.0.25: Destination host unreachable.
اینم کدش
اینم کدش
#include <avr/io.h>
#include <string.h>
#include "ip_arp_udp_tcp.h"
#include "enc28j60.h"
#include "timeout.h"
#include "avr_compat.h"
#include "net.h"
// please modify the following two lines. mac and ip have to be unique
// in your local area network. You can not have the same numbers in
// two devices:
static uint8_t mymac[6] = {0x54,0x55,0x58,0x10,0x00,0x24};
// how did I get the mac addr? Translate the first 3 numbers into ascii is: TUX
static uint8_t myip[4] = {10,0,0,24};
// listen port for www
#define MYWWWPORT 80
//// listen port for udp
#define MYUDPPORT 1200
#define BUFFER_SIZE 450
static uint8_t buf[BUFFER_SIZE+1];
int main(void){
uint16_t plen;
uint16_t dat_p;
uint8_t i=0;
uint8_t payloadlen=0;
// set the clock speed to 8MHz
// set the clock prescaler. First write CLKPCE to enable setting of clock the
// next four instructions.
CLKPR=(1<<CLKPCE);
CLKPR=0; // 8 MHZ
_delay_loop_1(50); // 12ms
// LED
/* enable PB1, LED as output */
DDRB|= (1<<DDB1);
/* set output to Vcc, LED off */
PORTB|= (1<<PORTB1);
/*initialize enc28j60*/
enc28j60Init(mymac);
enc28j60clkout(2); // change clkout from 6.25MHz to 12.5MHz
/* Magjack leds configuration, see enc28j60 datasheet, page 11 */
// LEDB=yellow LEDA=green
// 0x476 is PHLCON LEDA=links status, LEDB=receive/transmit
// enc28j60PhyWrite(PHLCON,0b0000 0100 0111 01 10);
enc28j60PhyWrite(PHLCON,0x476);
/* set output to GND, red LED on */
PORTB &= ~(1<<PORTB1);
i=1;
//init the ethernet/ip layer:
init_ip_arp_udp_tcp(mymac,myip,MYWWWPORT);
while(1){
// get the next new packet:
plen = enc28j60PacketReceive(BUFFER_SIZE, buf);
/*plen will ne unequal to zero if there is a valid
* packet (without crc error) */
if(plen==0){
continue;
// arp is broadcast if unknown but a host may also
// verify the mac address by sending it to
// a unicast address.
if(eth_type_is_arp_and_my_ip(buf,plen)){
make_arp_answer_from_request(buf);
continue;
// check if ip packets (icmp or udp) are for us:
if(eth_type_is_ip_and_my_ip(buf,plen)==0){
continue;
if (i){
i=0;
}else{
/* set output to GND, LED on */
i=1;
if(buf[IP_PROTO_P]==IP_PROTO_ICMP_V && buf[ICMP_TYPE_P]==ICMP_TYPE_ECHOREQUEST_V){
// a ping packet, let's send pong
make_echo_reply_from_request(buf,plen);
continue;
// tcp port www start, compare only the lower byte
if (buf[IP_PROTO_P]==IP_PROTO_TCP_V&&buf[TCP_DST_PORT_H_P]==0&&buf[TCP_DST_PORT_L_P]==MYWWWPORT){
if (buf[TCP_FLAGS_P] & TCP_FLAGS_SYN_V){
make_tcp_synack_from_syn(buf);
// make_tcp_synack_from_syn does already send the syn,ack
continue;
if (buf[TCP_FLAGS_P] & TCP_FLAGS_ACK_V){
init_len_info(buf); // init some data structures
// we can possibly have no data, just ack:
dat_p=get_tcp_data_pointer();
if (dat_p==0){
if (buf[TCP_FLAGS_P] & TCP_FLAGS_FIN_V){
// finack, answer with ack
make_tcp_ack_from_any(buf);
// just an ack with no data, wait for next packet
continue;
if (strncmp("GET ",(char *)&(buf[dat_p]),4)!=0){
// head, post and other methods:
// for possible status codes see:
// http://www.w3.org/Protocols/rfc2616/rfc2616-sec10.html
plen=fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n<h1>200 OK</h1>"
}else{
// the "get" method
plen=fill_tcp_data_p(buf,0,PSTR("HTTP/1.0 200 OK\r\nContent-Type: text/html\r\n\r\n<p>OK, it works</p>"
make_tcp_ack_from_any(buf); // send ack for http get
make_tcp_ack_with_data(buf,plen); // send data
continue;
// udp interface:
if (buf[IP_PROTO_P]==IP_PROTO_UDP_V){
payloadlen=buf[UDP_LEN_L_P]-UDP_HEADER_LEN;
// the received command has to start with t and be 4 char long
// e.g "test\0"
if (buf[UDP_DATA_P]=='t' && payloadlen==5){
make_udp_reply_from_request(buf,"hello", 6,MYUDPPORT);
return (0);
#include <string.h>
#include "net.h"
// two devices:
int main(void){
uint16_t plen;
uint16_t dat_p;
uint8_t i=0;
CLKPR=(1<<CLKPCE);
CLKPR=0; // 8 MHZ
// LED
DDRB|= (1<<DDB1);
i=1;
while(1){
if(plen==0){
continue;
continue;
continue;
if (i){
i=0;
}else{
i=1;
continue;
continue;
if (dat_p==0){
continue;
);}else{
// the "get" method
continue;
// udp interface:
// e.g "test\0"
return (0);
