پاسخ : کوچ کردن از کدویژن به AtmelStudio
کسی جواب مارو نداد
دوستانی که با اتمل کار میکنید. چطور برنامتون رو دیباگ میکنین ؟؟؟
کسی جواب مارو نداد
[left]
typedef struct
unsigned in0:1;
unsigned in1:1;
unsigned in2:1;
unsigned in3:1;
unsigned in4:1;
unsigned in5:1;
unsigned in6:1;
unsigned in7:1;
unsigned dir0:1;
unsigned dir1:1;
unsigned dir2:1;
unsigned dir3:1;
unsigned dir4:1;
unsigned dir5:1;
unsigned dir6:1;
unsigned dir7:1;
unsigned out0:1;
unsigned out1:1;
unsigned out2:1;
unsigned out3:1;
unsigned out4:1;
unsigned out5:1;
unsigned out6:1;
unsigned out7:1;
} PORT_STRUCT;
#ifdef PORTA
#define PortA (*((volatile PORT_STRUCT*)(&PINA)))
#endif
#ifdef PORTB
#define PortB (*((volatile PORT_STRUCT*)(&PINB)))
#endif
#ifdef PORTC
#define PortC (*((volatile PORT_STRUCT*)(&PINC)))
#endif
#ifdef PORTD
#define PortD (*((volatile PORT_STRUCT*)(&PIND)))
#endif
#ifdef PORTE
#define PortE (*((volatile PORT_STRUCT*)(&PINE)))
#endif
#ifdef PORTF
#define PortF (*((volatile PORT_STRUCT*)(&PINF)))
#endif
#ifdef PORTG
#define PortG (*((volatile PORT_STRUCT*)(&PING)))
#endif
#ifdef PORTH
#define PortH (*((volatile PORT_STRUCT*)(&PINH)))
#endif
#ifdef PORTI
#define PortI (*((volatile PORT_STRUCT*)(&PINI)))
#endif
#ifdef PORTJ
#define PortJ (*((volatile PORT_STRUCT*)(&PINJ)))
#endif
#ifdef PORTK
#define PortK (*((volatile PORT_STRUCT*)(&PINK)))
#endif[/left]
int main(void)
PortA.dir1=1;
while(1)
_delay_ms(250);
PortA.out1=1;
_delay_ms(250);
PortA.out1=0;
