پاسخ : [آموزش] نحوه استفاده از کتابخانه pff.h
سلام دوستان از کدوم توابع کتابخانه pff باید برای بدست اوردن حجم فایل استفاده کرد؟؟
RESULT disk_readp
unsigned char *buff, /* Pointer to the read buffer (NULL:Read bytes are forwarded to the stream) */
unsigned long lba, /* Sector number (LBA) */
unsigned short ofs, /* Byte offset to read from (0..511) */
unsigned short cnt /* Number of bytes to read (ofs + cnt mus be <= 512) */
RESULT res;
unsigned char rc;
unsigned short bc;
if (!(CardType & CT_BLOCK)) lba *= 512; /* Convert to byte address if needed */
res = RES_ERROR;
if (send_cmd(CMD17, lba) == 0) /* READ_SINGLE_BLOCK */
bc = 30000;
do /* Wait for data packet in timeout of 100ms */
rc = rcv_spi();
} while (rc == 0xFF && --bc);
if (rc == 0xFE) /* A data packet arrived */
bc = 514 - ofs - cnt;
/* Skip leading bytes */
if (ofs)
do rcv_spi(); while (--ofs);
/* Receive a part of the sector */
if (buff) /* Store data to the memory */
do
*buff++ = rcv_spi();
while (--cnt);
do rcv_spi(); while (--bc);
res = RES_OK;
release_spi();
return res;
[FONT=Yekan]RESULT pf_read ([/FONT] void *buff, /* Pointer to the read buffer (NULL:Forward data to the stream)*/
unsigned short btr, /* Number of bytes to read */
unsigned short* br /* Pointer to number of bytes read */
RESULT dr;
CLUST clst;
unsigned long sect, remain;
unsigned char *rbuff = buff;
unsigned short rcnt;
FATFS *fs = FatFs;
*br = 0;
if (!fs) return FR_NOT_ENABLED; /* Check file system */
if (!(fs->flag & FA_OPENED)) /* Check if opened */
return FR_NOT_OPENED;
remain = fs->fsize - fs->fptr;
if (btr > remain) btr = (unsigned short)remain; /* Truncate btr by remaining bytes */
while (btr) { /* Repeat until all data transferred */
if ((fs->fptr % 512) == 0) { /* On the sector boundary? */
if ((fs->fptr / 512 % fs->csize) == 0) { /* On the cluster boundary? */
clst = (fs->fptr == 0) ? /* On the top of the file? */
fs->org_clust : get_fat(fs->curr_clust);
if (clst <= 1) goto fr_abort;
fs->curr_clust = clst; /* Update current cluster */
fs->csect = 0; /* Reset sector offset in the cluster */
sect = clust2sect(fs->curr_clust); /* Get current sector */
if (!sect) goto fr_abort;
fs->dsect = sect + fs->csect++;
rcnt = 512 - ((unsigned short)fs->fptr % 512); /* Get partial sector data from sector buffer */
if (rcnt > btr) rcnt = btr;
dr = disk_readp(!buff ? 0 : rbuff, fs->dsect, (unsigned short)(fs->fptr % 512), rcnt);
if (dr) goto fr_abort;
fs->fptr += rcnt; rbuff += rcnt; /* Update pointers and counters */
btr -= rcnt; *br += rcnt;
return FR_OK;
fr_abort:
fs->flag = 0;
return FR_DISK_ERR;
RESULT pf_open (
const char *path /* Pointer to the file name */
RESULT res;
DIR dj;
unsigned char sp[12], dir[32];
FATFS *fs = FatFs;
if (!fs) /* Check file system */
fs->flag = 0;
fs->buf = dir;
dj.fn = sp;
res = follow_path(&dj, path); /* Follow the file path */
if (res != FR_OK) return res; /* Follow failed */
if (!dir[0] || (dir[DIR_Attr] & AM_DIR)) /* It is a directory */
return FR_NO_FILE;
fs->org_clust = /* File start cluster */
#if _FS_FAT32
((unsigned long)LD_WORD(dir+DIR_FstClusHI) << 16) |
#endif
LD_WORD(dir+DIR_FstClusLO);
fs->fsize = LD_DWORD(dir+DIR_FileSize); /* File size */
fs->fptr = 0; /* File pointer */
fs->flag = FA_OPENED;
return FR_OK;
