پاسخ : تغییرات ناخواسته مقادیر eeprom
دیتا شیت هم به حساسیت زیاد به تغذیه اشاره کرده .تنها راه حل هم bod level گفته :
Keep the AVR RESET active (low) during periods of insufficient power supply voltage. This can be done by
enabling the internal Brown-out Detector (BOD). If the detection level of the internal BOD does not match the
needed detection level, an external low VCC reset Protection circuit can be used. If a reset occurs while a write
operation is in progress, the write operation will be completed provided that the power supply voltage is sufficient.
(درس و مشق فعالیتمو تو انجمن کم کرده)
