موقع کامپایل برنامه اخطار میده مشکل از کجاست
$regfile = "m8def.dat"
$crystal = 8000000
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = Portc.2 , Db5 = Portc.3 , Db6 = Portc.4 , Db7 = Portc.5 , E = Portc.1 , Rs = Portc.0
Cls : Home : Cursor Off
Config Clock = Soft , Gosub = Sectic
Disable Interrupts
Config Portd = &B11111000
Dim Flag As Bit
Dim S As Byte
Dim M As Byte
Dim H As Byte
Dim Y As Word
Dim Mo As Byte
Dim D As Byte
Dim Slc As Byte
Dim Bg As Byte
Slc = 0
Y = 1385
Mo = 1
D = 1
Bg = 1
H = 12
Flag = 0
Dim Ge As Byte
For Ge = 1 To 23
Locate 1 , 1
Lcd "by:m-zarei m-zarei"
Waitms 700
Locate 2 , 1
Lcd "!!**email:m_zarei@ir-micro.com**!!"
Shiftlcd Left
Next Ge
Scan:
If Pind.0 = 0 Then Slc = Slc + 1
If Slc = 5 Then Slc = 0
If Pind.2 = 0 Then
Flag = 0
Goto Wait1s
End If
On Slc Goto Hour , Minute , Year , Month , Day
Goto Scan
Wait1s:
Enable Interrupts
Ge = 10
If Pind.0 = 0 Then
Waitms 400
Cls : Home
Goto Scan
Year:
If Pind.1 = 0 Then Y = Y + 1
If Y = 1400 Then Y = 1385
Lcd "year=" ; Y
Waitms 400
Cls : Home
Goto Scan
Month:
If Pind.1 = 0 Then Mo = Mo + 1
If Mo = 13 Then Mo = 1
Lcd "month=" ; Mo
Waitms 400
Cls : Home
Goto Scan
Day:
If Pind.1 = 0 Then D = D + 1
If D = 32 Then D = 1
Lcd "day=" ; D
Waitms 400
Cls : Home
Goto Scan
$crystal = 8000000
Config Lcd = 16 * 2
Disable Interrupts
Dim Flag As Bit
Dim S As Byte
Dim M As Byte
Dim H As Byte
Dim Y As Word
Dim Mo As Byte
Dim D As Byte
Dim Slc As Byte
Dim Bg As Byte
Slc = 0
Y = 1385
Mo = 1
D = 1
Bg = 1
H = 12
Flag = 0
Dim Ge As Byte
For Ge = 1 To 23
Locate 1 , 1
Waitms 700
Locate 2 , 1
Shiftlcd Left
Next Ge
Scan:
If Pind.2 = 0 Then
Flag = 0
Goto Wait1s
End If
Goto Scan
Wait1s:
Enable Interrupts
Ge = 10
If Pind.0 = 0 Then
Waitms 400
Cls : Home
Goto Scan
Year:
Lcd "year=" ; Y
Waitms 400
Cls : Home
Goto Scan
Month:
Lcd "month=" ; Mo
Waitms 400
Cls : Home
Goto Scan
Day:
Lcd "day=" ; D
Waitms 400
Cls : Home
Goto Scan
