سلام.من یه پروژه دارم که تشخیص رنگ از روی فرکانس هستش اما هرکار می کنم فقط رنگ قرمز و زرد و بنفش رو تشخیص میده.برنامش رو میزارم کسی می تونه برام چک کنه و ایرادم رو بگه؟ممنون
#include <mega8.h>
// Alphanumeric LCD functions
#include <alcd.h>
#include <delay.h>
#include <stdio.h>
#define S0 PORTC.3
#define S1 PORTC.2
#define S3 PORTC.1
#define S2 PORTC.0
#define out_f1 S0=0; S1=1
#define out_f2 S0=1; S1=0
#define out_f3 S0=1; S1=1
#define filter_red S2=0; S3=0
#define filter_blue S2=0; S3=1
#define filter_clear S2=1; S3=0
#define filter_green S2=1; S3=1
unsigned int frqun;
unsigned int frq[3];
char lcd[16];
unsigned char rang[3][10]={
{"RED"},{"BLUE"},{"GRREN"},
void clac(void);
// Timer 0 overflow interrupt service routine
interrupt [TIM0_OVF] void timer0_ovf_isr(void)
// Place your code here
frqun=TCNT1;
TCNT1=0;
void main(void)
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
// Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTC=0x00;
DDRC=0xFF;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Clock source: System Clock
// Clock value: 7.813 kHz
TCCR0=0x05;
TCNT0=0x00;
// Clock source: T1 pin Falling Edge
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
TCCR1A=0x00;
TCCR1B=0x06;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
MCUCR=0x00;
TIMSK=0x01;
// USART initialization
// USART disabled
UCSRB=0x00;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC disabled
ADCSRA=0x00;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
// Alphanumeric LCD initialization
// Connections are specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTD Bit 7
// RD - PORTB Bit 0
// EN - PORTB Bit 1
// D4 - PORTB Bit 2
// D5 - PORTB Bit 3
// D6 - PORTB Bit 4
// D7 - PORTB Bit 5
// Characters/line: 8
lcd_init(16);
// Global enable interrupts
#asm("sei")
lcd_putsf("HI");
out_f2;
while (1)
filter_red;
delay_ms(200);
frq[0]=frqun;
filter_blue;
delay_ms(200);
frq[1]=frqun;
filter_green;
delay_ms(200);
frq[2]=frqun;
clac();
void clac(void){
unsigned int max;
char num[3];
char T,I;
int s1,s2;
num[0]=0;
max=frq[num[0]];
if(max<frq[1]){max=frq[1];num[0]=1;}
if(max<frq[2]){max=frq[2];num[0]=2;}
T=1;
for(I=0;I<3;I++){
if(I!=num[0]){num[T]=I;T++;}
if(frq[num[1]]<frq[num[2]]){
max=num[2];
num[2]=num[1];
num[1]=max;
lcd_clear();
s1=frq[num[0]]-frq[num[1]];
s2=frq[num[0]]-frq[num[2]];
if(s1>s2)max=s1-s2;else max=s2-s1;
lcd_gotoxy(0,0);
sprintf (lcd,"R=%d B=%d G=%d",frq[0]/10,frq[1]/10,frq[2]/10);
lcd_puts(lcd);
lcd_gotoxy(0,1);
if(max<50&s1>300&s2>300)lcd_puts(rang[num[0]]);
else
sprintf(lcd,"%s/%s ",rang[num[0]],rang[num[1]]);
lcd_puts(lcd);
if(num[0]==0 & num[1]==1)lcd_putsf("Violet");
if(num[0]==0 & num[1]==2)lcd_putsf("Yellow");
if(num[0]==1 & num[1]==0)lcd_putsf("Violet");
if(num[0]==1 & num[1]==2)lcd_putsf("Indigo");
if(num[0]==2 & num[1]==0)lcd_putsf("Yellow");
if(num[0]==2 & num[1]==1)lcd_putsf("Indigo");
