با سلام به دوستان
من در ارتباط زیر به این مشکل برخوردم که همش عدد 987 برایم از at24c08b برگشت داده می شود!
کسی میتونه مشکل اون رو بهم بگه؟؟؟
کدوم پایه at284 رو باید زمین کنم؟(الان پایه a1 رو زمین کردم) ؟؟
کسی نقشه عملی از مدارش داره؟؟؟
CodeWizardAVR V2.05.3 Standard
Automatic Program Generator
© Copyright 1998-2011 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 2014/03/16
Author : A
Company : A
Comments:
Chip type : ATmega32
Program type : Application
Memory model : Small
External RAM size : 0
Data Stack size : 512
#include <mega32.h>
// I2C Bus functions
#include <i2c.h>
// Alphanumeric LCD functions
#include <alcd.h>
#include <stdlib.h>
#include <stdio.h>
#include <twi.h>
#include <delay.h>
int a,i,j;
int h3,h1,h2,l1,l2,l3;
int a1,a2;
char str[100];
//int parameter[]={1,2,3,4,6,7,15,9,16,3};
/* write a byte to the EEPROM */
void eeprom_write(int address,int d) {
h1=address/100;
l1=(address)-(h1*100);
h2=d/100;
l2=d-(h2*100);
i2c_start();
i2c_write(0xa0);
i2c_write(h1);
i2c_write(l1);
i2c_write(h2);
i2c_write(l2);
i2c_stop();
/* read a byte from the EEPROM */
int eeprom_read(int address) {
int data;
h3=address/100;
l3=address-(h3*100);
i2c_start();
i2c_write(0xa0);
i2c_write(h3);
i2c_write(l3);
i2c_start();
i2c_write(0xa1);
a1=i2c_read(0);
delay_ms(50);
i2c_start();
i2c_write(0xa1);
a2=i2c_read(0);
i2c_stop();
data=(a1*100)+a2;
return data;
void main(void)
// Port A initialization
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
PORTC=0x00;
DDRC=0x0F;
// Port D initialization
PORTD=0xf0;
DDRD=0x00;
// Clock source: System Clock
// Mode: Normal top=0xFF
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
TIMSK=0x00;
// USART initialization
// USART disabled
UCSRB=0x00;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC disabled
ADCSRA=0x00;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
// I2C Bus initialization
// I2C Port: PORTC
// I2C SDA bit: 1
// I2C SCL bit: 0
// Bit Rate: 100 kHz
// Note: I2C settings are specified in the
// Project|Configure|C Compiler|Libraries|I2C menu.
i2c_init();
// Alphanumeric LCD initialization
// Connections are specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTA Bit 0
// RD - PORTA Bit 1
// EN - PORTA Bit 2
// D4 - PORTA Bit 4
// D5 - PORTA Bit 5
// D6 - PORTA Bit 6
// D7 - PORTA Bit 7
// Characters/line: 16
lcd_init(16);
eeprom_write(1,123);
delay_ms(5);
eeprom_write(2,456);
delay_ms(5);
eeprom_write(3,987);
delay_ms(5);
while (1)
a=eeprom_read(1);
delay_ms(50);
lcd_clear();
lcd_gotoxy(0,0);
sprintf(str,"%u",a);
lcd_puts(str);
delay_ms(1000);
lcd_clear();
a=eeprom_read(2);
delay_ms(50);
lcd_clear();
lcd_gotoxy(0,0);
lcd_puts(str);
delay_ms(1000);
lcd_clear();
a=eeprom_read(3);
delay_ms(50);
lcd_clear();
lcd_gotoxy(0,0);
lcd_puts(str);
delay_ms(1000);
lcd_clear();
Project :
Version :
Date : 2014/03/16
Author : A
Company : A
Comments:
#include <mega32.h>
#include <i2c.h>
#include <alcd.h>
#include <stdlib.h>
#include <stdio.h>
#include <twi.h>
#include <delay.h>
int a,i,j;
int a1,a2;
char str[100];
h1=address/100;
h2=d/100;
l2=d-(h2*100);
i2c_start();
i2c_write(0xa0);
i2c_write(h1);
i2c_write(l1);
i2c_write(h2);
i2c_write(l2);
i2c_stop();
int data;
h3=address/100;
i2c_start();
i2c_write(0xa0);
i2c_write(h3);
i2c_write(l3);
i2c_start();
i2c_write(0xa1);
a1=i2c_read(0);
delay_ms(50);
i2c_start();
i2c_write(0xa1);
a2=i2c_read(0);
i2c_stop();
data=(a1*100)+a2;
return data;
void main(void)
PORTA=0x00;
DDRA=0x00;
PORTB=0x00;
DDRB=0x00;
PORTC=0x00;
DDRC=0x0F;
PORTD=0xf0;
DDRD=0x00;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
TIMSK=0x00;
// USART disabled
UCSRB=0x00;
ACSR=0x80;
SFIOR=0x00;
// ADC disabled
ADCSRA=0x00;
// SPI disabled
SPCR=0x00;
// TWI disabled
TWCR=0x00;
// I2C Port: PORTC
// I2C SDA bit: 1
// I2C SCL bit: 0
i2c_init();
// RS - PORTA Bit 0
// RD - PORTA Bit 1
// EN - PORTA Bit 2
// D4 - PORTA Bit 4
// D5 - PORTA Bit 5
// D6 - PORTA Bit 6
// D7 - PORTA Bit 7
lcd_init(16);
delay_ms(5);
delay_ms(5);
delay_ms(5);
while (1)
a=eeprom_read(1);
delay_ms(50);
lcd_clear();
lcd_gotoxy(0,0);
lcd_puts(str);
delay_ms(1000);
lcd_clear();
a=eeprom_read(2);
delay_ms(50);
lcd_clear();
lcd_gotoxy(0,0);
lcd_puts(str);
delay_ms(1000);
lcd_clear();
a=eeprom_read(3);
delay_ms(50);
lcd_clear();
lcd_gotoxy(0,0);
lcd_puts(str);
delay_ms(1000);
lcd_clear();
