مشکل عجیب با ATMEL STUDIO (فورییییی)
    من این برنامه رو تو کدویژن نوشتم جواب گرفتم
    تو بسکام نوشتم جواب گرفتم
    ولی تو atmel studio جواب نمیگیرم
    طفا کمک کنید
    #define CRYSTAL 20UL//MHZ
    #define MHZ		1000000UL
    #define F_CPU	(CRYSTAL*MHZ)
    #include <avr/io.h>
    #include <stdio.h>			//for fprintf using!
    #include <compat/deprecated.h>
    #include <util/delay.h>
    #include <inttypes.h>
    #define bv(bit)								(1<<bit)
    #define sbi(byte,bit)						byte|=bv(bit)
    #define cbi(byte,bit)						byte&=~bv(bit)
    //Data Port////////////////////////////////////////////////////////////
    #define LCD_DATA_PORT				PORTA
    #define LCD_DATA_DDR				DDRA
    #define LCD_DATA_PIN				PINA
    //Control Port/////////////////////////////////////////////////////////
    #define LCD_CTRL_PORT				PORTC
    #define LCD_CTRL_DDR				DDRC
    #define LCD_CTRL_PIN				PINC
    //Control Pin//////////////////////////////////////////////////////////
    #define LCD_RD_BIT					0
    #define LCD_WR_BIT					1
    #define LCD_RS_BIT					2
    #define LCD_CS_BIT					3
    #define LCD_RST_BIT					4
    #define RDH()							sbi(LCD_CTRL_PORT,LCD_RD_BIT)
    #define RDL()							cbi(LCD_CTRL_PORT,LCD_RD_BIT)
    #define WRH()							sbi(LCD_CTRL_PORT,LCD_WR_BIT)
    #define WRL()							sbi(LCD_CTRL_PORT,LCD_WR_BIT)
    #define RSH()							sbi(LCD_CTRL_PORT,LCD_RS_BIT)
    #define RSL()							cbi(LCD_CTRL_PORT,LCD_RS_BIT)
    #define CSH()							sbi(LCD_CTRL_PORT,LCD_CS_BIT)
    #define CSL() 						cbi(LCD_CTRL_PORT,LCD_CS_BIT)
    #define RSTH()						sbi(LCD_CTRL_PORT,LCD_RST_BIT)
    #define RSTL()						cbi(LCD_CTRL_PORT,LCD_RST_BIT)
    void write_8bit(unsigned char _value);
    void write_data(unsigned int data);
    void write_command(unsigned int command);
    void lcd_writereg(unsigned int _cmd , unsigned int _data);
    void Lcd_init(void);
    void lcd_clear(int color);
    void lcd_reset(void);
    void lcd_init_port(void);
    #define Black		0x0000
    #define Blue		0x001F
    #define Red			0xF800
    #define Green		0x07E0
    #define Cyan		0x07FF
    #define Magenta		0xF81F
    #define Yellow		0xFFE0
    #define White		0xFFFF
    unsigned char HIGH	(unsigned int integer);
    unsigned char LOW	(unsigned int integer);
    int main(void)
    	lcd_init_port();
    	lcd_reset();
    	Lcd_init();
    	lcd_clear(Yellow);
    	DDRD|=bv(7);
    	while(1)
    		PORTD^=bv(7);
    		_delay_ms(1000);
    	LCD_DATA_DDR=0xff;
    	LCD_DATA_PORT=0x00;
    	LCD_CTRL_DDR|=	bv(LCD_RD_BIT)|
    	bv(LCD_WR_BIT)|
    	bv(LCD_RS_BIT)|
    	bv(LCD_CS_BIT)|
    	bv(LCD_RST_BIT);
    void Lcd_init(void)
    	lcd_reset();
    	_delay_ms(100);
    	lcd_writereg (0x0001 , 0x0100);
    	lcd_writereg (0x0002 , 0x0700);
    	lcd_writereg (0x0003 , 0x1030);
    	lcd_writereg (0x0008 , 0x0302);
    	lcd_writereg (0x0009 , 0x0000);
    	lcd_writereg (0x000a , 0x0008);
    	lcd_writereg (0x0010 , 0x0000);
    	lcd_writereg (0x0011 , 0x0005);
    	lcd_writereg (0x0012 , 0x0000);
    	lcd_writereg (0x0013 , 0x0000);
    	_delay_ms(200);
    	lcd_writereg (0x0010 , 0x12b0);
    	_delay_ms(100);
    	lcd_writereg (0x0011 , 0x0007);
    	_delay_ms(100);
    	lcd_writereg (0x0012 , 0x008C);
    	lcd_writereg (0x0013 , 0x1700);
    	lcd_writereg (0x0029 , 0x0020);
    	_delay_ms(100);
    	lcd_writereg (0x0030 , 0x0000);
    	lcd_writereg (0x0031 , 0x0106);
    	lcd_writereg (0x0032 , 0x0101);
    	lcd_writereg (0x0035 , 0x0106);
    	lcd_writereg (0x0036 , 0x0203);
    	lcd_writereg (0x0037 , 0x0000);
    	lcd_writereg (0x0038 , 0x0707);
    	lcd_writereg (0x0039 , 0x0204);
    	lcd_writereg (0x003C , 0x0106);
    	lcd_writereg (0x003D , 0x0103);
    	lcd_writereg (0x0050 , 0x0000);
    	lcd_writereg (0x0051 , 0x00EF);
    	lcd_writereg (0x0052 , 0x0000);
    	lcd_writereg (0x0053 , 0x013F);
    	lcd_writereg (0x0060 , 0xA700);
    	lcd_writereg (0x0061 , 0x0001);
    	lcd_writereg (0x0090 , 0x0030);
    	lcd_writereg (0x0007 , 0x0133);
    	write_command(_cmd);
    	write_data(_data);
    	CSH();
    	RDH();
    	WRH();
    	RSH();
    	RSTH();
    	_delay_ms(20);
    	RSTL();
    	_delay_ms(1000);
    	RSTH();
    	_delay_ms(20);
    	RDH();
    	RSL();//COMMAND
    	CSL();
    	write_8bit(HIGH(command));
    	write_8bit(LOW(command));
    	RSH();
    	CSH();
    	RDH();
    	RSH();//DATA
    	CSL();
    	write_8bit(HIGH(data));
    	write_8bit(LOW(data));
    	RSH();
    	CSH();
    	WRL();
    	LCD_DATA_PORT = _value;
    	WRH();
    	int i,j;
    	lcd_writereg(0x0020 , 0x0000);
    	lcd_writereg(0x0021 , 0x0000);
    	write_command(0x0022);
    	for(i=0;i<320;i++)
    	for(j=0;j<240;j++)
    	write_data(color);
    unsigned char HIGH(unsigned int integer)
    	return ( (integer>>8) & 0xff);
    unsigned char LOW(unsigned int integer)
    	return (integer&0xff);
    دلا خو کن به تنهایی که از تنها بلا خیزد
    پاسخ : مشکل عجیب با ATMEL STUDIO (فورییییی)
    دوستان خواهشا کمک کنید
    فوریه
      از چه نسخه ای استفاده می کنید؟
      لطفا خطاهای هنگام کامپایل رو قرار دهید.
        مشکلم حل شد
        کامپایلر خطا نمیده
        مشکلش با دستورات sbi , cbi بود ، از اشاره گر و استراکچر استفاده کردم ، مشکلم حل شد
        ولی نمی دونم چرا با sbi , cbi کار نمیکنه
