سلام تو تبدیل دما از fioat مشکل دارم کدویژن هی گیر می ده دستورش چیه و به چی تبدیلش کنم
نمایش دما برروی 7seg در کدویژن
پاسخ : نمایش دما برروی 7seg در کدویژن
#include <mega16.h>
#include <delay.h>
#include <stdlib.h>
unsigned char sec , min , hour;
int count=0;
bit change=0;
interrupt [TIM0_OVF] void timer0_ovf_isr(void)
count ++;
if (count>=0)
sec ++ ;
if(sec==60)
min ++;
sec=0;
if(min==60)
hour ++;
min=0;
if(hour==24)
hour=0;
#define ADC_VREF_TYPE 0x00
// Read the AD conversion result
unsigned int read_adc(unsigned char adc_input)
ADMUX=adc_input | (ADC_VREF_TYPE & 0xff);
// Delay needed for the stabilization of the ADC input voltage
delay_us(10);
// Start the AD conversion
ADCSRA|=0x40;
// Wait for the AD conversion to complete
while ((ADCSRA & 0x10)==0);
ADCSRA|=0x10;
return ADCW;
char hojjat[4];
char i=1;
char temp1[];
float temp ;
void main(void)
// Port A initialization
PORTA=0x00;
DDRA=0x00;
// Port B initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=Out Func2=Out Func1=Out Func0=Out
// State7=0 State6=0 State5=0 State4=0 State3=0 State2=0 State1=0 State0=0
PORTB=0x00;
DDRB=0xFF;
// Port C initialization
PORTC=0x00;
DDRC=0x01;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Clock source: System Clock
// Clock value: 172.800 kHz
// Mode: Normal top=FFh
// OC0 output: Disconnected
TCCR0=0x03;
TCNT0=0x00;
OCR0=0x00;
// Mode: Normal top=FFFFh
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
TIMSK=0x01;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC Clock frequency: 172.800 kHz
// ADC Voltage Reference: AREF pin
// ADC Auto Trigger Source: None
ADMUX=ADC_VREF_TYPE & 0xff;
ADCSRA=0x86;
// Global enable interrupts
#asm("sei"
while (1)
temp= read_adc(0);
temp=(temp*100/1024);
switch (i) {
case 1:
hojjat[i]=min%10 ;
PORTD=hojjat[i]|128 ;
i++;
break;
case 2:
hojjat[i]=min/10 ;
PORTD=hojjat[i]|64 ;
i++;
break;
case 3:
hojjat[i]=hour%10 ;
PORTD=hojjat[i]|32 ;
i++;
break;
case 4:
hojjat[i]=hour/10 ;
PORTD=hojjat[i]|16 ;
i=1;
break;
if (PINC.6==0)
min++;
delay_ms(250);
if (min==60)
min=0;
if (PINC.5==0)
hour++;
delay_ms(250);
if (hour==24)
hour=0;
if (PINC.4==0)
switch (i) {
ftoa (temp,0,temp1); //<<--------injass moshkel fec konam eshteb neveshtam
case 1:
hojjat[i]=temp1%10 ;
i++;
break;
case 2:
hojjat[i]=temp1/10 ;
i=1;
break;
[/left][/left][/right]
