سلام خدمت اساتید عزیز....
من میخوام ATMEGA16A رو با یه ماژول آماده FTDI وصل کنم به پورت سریال ، این تصویر مدارم هستش:
http://s6.picofile.com/file/8198579426/madar.jpg
این هم کد پروژم:
اینم کتاب خانه ای که ساختم برای UART:
این هم کد پروژم:
#define F_CPU 8000000
#include <avr/io.h>
#include <util/delay.h>
#include <Angel/UARTMethods.h>
#include <avr/interrupt.h>
int main(void)
InitializeUART(9600, 0, 8, NONE, 1, TRUE);
while(1)
_delay_ms(100);
TransmitUART('a');
#ifndef UARTInit
#define UARTInit
#define EVEN 0
#define ODD 1
#define NONE 2
#define FALSE 0
#define TRUE 1
#include <math.h>
#include <avr/io.h>
unsigned char ReceiveUART(void)
while (! (UCSRA & (1 << RXC)) );
return UDR;
void TransmitUART(unsigned char data)
//Wait until the Transmitter is ready
while (! (UCSRA & (1 << UDRE)) );
//Get that data outa here!
UDR = data;
void InitializeUART(int baud, char AsyncDoubleSpeed, char DataSizeInBits, char ParityEVENorODD, char StopBits, char USARTInterruptEnable)
uint16_t UBBRValue = lrint(( F_CPU / (16L * baud) ) - 1);
if (AsyncDoubleSpeed == 1) UCSRA = (1 << U2X); //setting the U2X bit to 1 for double speed asynchronous
//Put the upper part of the baud number here (bits 8 to 11)
UBRRH = (unsigned char) (UBBRValue >> 8);
//Put the remaining part of the baud number here
UBRRL = (unsigned char) UBBRValue;
//Enable the receiver and transmitter
UCSRB = (1 << RXEN) | (1 << TXEN);
if (USARTInterruptEnable) UCSRB |= (1 << RXCIE);
//Set 2 stop bits
if (StopBits == 2) UCSRC = (1 << USBS);
if (ParityEVENorODD == EVEN) UCSRC |= (1 << UPM1); //Sets parity to EVEN
if (ParityEVENorODD == ODD) UCSRC |= (3 << UPM0); //Alternative way to set parity to ODD
if (DataSizeInBits == 6) UCSRC |= (1 << UCSZ0); //6-bit data length
if (DataSizeInBits == 7) UCSRC |= (2 << UCSZ0); //7-bit data length
if (DataSizeInBits == 8) UCSRC |= (3 << UCSZ0); //8-bit data length
if (DataSizeInBits == 9) UCSRC |= (7 << UCSZ0); //9-bit data length
#endif
