من سورس زیر برای رسم نمودار استفاده کردم و بجای lm 35 از سنسور sht11استعاده کردم و متغیر هام هم از نوع single انتخاب کردم
حالا وقتی گراف رسم میشه از اخرین ستون شروع به رسم میکنه اونم به صورت بر عکس ،هر چی اعداد و دستکاری کردم نشد میشه کسی راهنمای کنه؟
$regfile = "m16def.dat"
$crystal = 8000000
$hwstack = 64
$swstack = 64
$framesize = 64
Config Adc = Single , Prescaler = Auto , Reference = Internal
Enable Adc
Start Adc
Dim W As Word
$lib "glcdKS108.lbx"
Config Graphlcd = 128 * 64sed , Dataport = Portb , Controlport = Portc , Ce = 4 , Ce2 = 3 , Cd = 0 , Rd = 1 , Reset = 5 , Enable = 2
Dim A As Byte , B As Byte
Dim X1 As Byte , X2 As Byte , Y1 As Byte , Y2 As Byte
Dim Arr(26) As Byte , Temp(26) As Byte
Dim S As Byte
Dim Index As Byte
Dim Index2 As Byte
Dim Tmp As Byte
'-------------------- Main Prog Start Here:
Cls
Set Portb.0
Waitms 50
Reset Portb.0
Do
Cls
Showpic 0 , 0 , Pic1
'=================== First Graph =====================
For X1 = 0 To 120 Step 5
Incr Index
Y1 = Arr(index)
Y2 = Arr(index + 1)
X2 = X1 + 5
Line(x1 , Y1) -(x2 , Y2) , 255
Next X1
Index = 0
'================ Update Graph ====================
For Tmp = 1 To 26 'Copy Arr
Temp(tmp) = Arr(tmp)
Next Tmp
Arr(1) = Temp(2) 'Shift Arr
For Tmp = 2 To 25
S = Tmp + 1
Arr(tmp) = Temp(s)
Next Tmp
W = Getadc(0)
W = W / 16 'Max: 1024/16=64
Arr(26) = W
Waitms 500 'Scan Speed
Loop
End
Pic1:
$bgf "Grid.bgf"
$crystal = 8000000
$hwstack = 64
$swstack = 64
$framesize = 64
Enable Adc
Start Adc
Dim W As Word
Dim S As Byte
Dim Index As Byte
Dim Index2 As Byte
Dim Tmp As Byte
Cls
Set Portb.0
Waitms 50
Reset Portb.0
Do
Cls
Incr Index
Y1 = Arr(index)
Y2 = Arr(index + 1)
X2 = X1 + 5
Next X1
Index = 0
Next Tmp
For Tmp = 2 To 25
S = Tmp + 1
Arr(tmp) = Temp(s)
Next Tmp
W = Getadc(0)
Arr(26) = W
Loop
End
Pic1:
$bgf "Grid.bgf"
