یه مشکلی برام پیش اومده که انشاالله با کمک شما دوستان و اساتید رفع بشه.من یه قفل رمز دارم که وقتی یکی دوبار پسورد را اشتباه بزنم یا اینکه یه مدت دستگاه بدون استفاده باشه پسورد درست رو هم میگه اشتباهه :eek:!!!لطفا راه نمایی کنین مشکل از کجاست[code=vb]$regfile = "m8def.dat"
$crystal = 8000000 'Internal RC
$hwstack = 64
$swstack = 64
$framesize = 64
'LCD
Config Lcdpin = Pin , Db4 = Pinc.3 , Db5 = Pinc.2 , Db6 = Pinc.1 , Db7 = _
Pinc.0 , E = Pinc.4 , Rs = Pinc.5
Config Lcd = 16 * 2
Cls : Home : Cursor Off
'Back Space Symbol
Deflcdchar 0 , 32 , 4 , 12 , 31 , 12 , 4 , 32 , 32
'Keypad
Config Kbd = Portb
[I/O
Config Pind.0 = Output 'Active
Config Pind.1 = Output 'Relay
Config Pind.2 = Input 'Default
Config Pind.3 = Output 'Speake[/img]r
'Set Pullup Resistor For Default Key
Set Portd.2 'Active Pullup Res
'Aliases
Active Alias Portd.0
Relay Alias Portd.1
Default Alias Pind.2
Speaker Alias Pind.3
'Var
Dim Digits As Byte , Key As Byte , Result As Byte , Num As String * 4
Dim Pass(8) As String * 1 , Pass1(8) As String * 1 , Pass2(8) As String * 1
Dim Pass_eeprom(8) As Eram String * 1 , Rcv(8) As String * 1
Dim Temp As Byte , Sel As Byte
'Subroutines
Declare Sub Main
Declare Sub Default_pass
Declare Sub Load2ram
Declare Sub Getpass
Declare Sub Check
Declare Sub Change
Declare Sub Menu
Declare Sub Change_pass
Declare Sub Confirm
Declare Sub Check1
'Declare Sub Cleardisp(byval Sel As Byte)
'Function
Declare Function Is_num(byval Num As String) As Byte
'Main Prog Start Here:
Call Main
End
'____________________________________________ ___________________________________
'Main Sub, Check Default Key Status & Call Other Sub's
Sub Main
Sound Speaker , 120 , 20 'Startup Sound
Active = 1 'Red LED=1
If Default = 0 Then Call Default_pass
Call Load2ram
Call Getpass
End Sub
'Set Default Password (11111111)
Sub Default_pass
Sound Speaker , 120 , 30
'Clear Pass
For Temp = 1 To 8
Pass_eeprom(temp) = "1"
Waitms 20
Next Temp
Cursor Off
Cls : Home : Lcd "Memoey Erased!"
Lowerline : Lcd "Pass=11111111"
Sound Speaker , 120 , 60
Waitms 1500
End Sub
'Load Pass to SRAM
Sub Load2ram
For Temp = 1 To 8
Pass(temp) = Pass_eeprom(temp)
Waitms 20
Next Temp
End Sub
'Get Password
Sub Getpass
Cls : Home : Lcd "Password? Cls=" ; Chr(0)
Home L : Cursor Blink
Digits = 0
Waitms 500
Key = Getkbd()
Num = Lookupstr(key , Decode)
If Num = "Cls" Then Call Getpass
If Is_num(num) = 1 Then
Sound Speaker , 120 , 50
Sound Speaker , 120 , 40
Incr Digits
Locate 2 , Digits : Lcd "*"
Rcv(digits) = Num
If Digits = 8 Then 'Pass Entered
Call Check
If Result <> 8 Then
'Error Pass
Sound Speaker , 120 , 80
Cls : Home : Lcd "Error!"
Cursor Noblink
Waitms 500
Call Getpass
Else
'Successful Pass
Call Menu
End If
End If
Waitms 300
End If
End Sub
'Check Pressed Key Is A Number(0-9)? If Yes Is-num = 1 In No Is_num=0
If Num = "0" Or Num = "1" Or Num = "2" Or Num = "3" Or Num = "4" _
Or Num = "5" Or Num = "6" Or Num = "7" Or Num = "8" Or Num = "9" then
Is_num = 1
Else
Is_num = 0
End If
End Function
'Password Checker
Sub Check
Result = 0
For Temp = 1 To 8
If Rcv(temp) = Pass(temp) Then Incr Result
Next Temp
End Sub
'Sub Menu (Open Door Or Cahnge pass)
Sub Menu
Cls : Home : Cursor Noblink : Lcd "1=Relay Exit"
Lowerline : Lcd "2=Change"
Sound Speaker , 120 , 100
Waitms 500
Key = Getkbd()
If Num = "1" Then
Toggle Relay
If Relay = 0 Then
Else
End If
Waitms 500
End If
If Num = "Exit" Then Call Getpass
If Num = "2" Then Call Change_pass
End Sub
'Change Password
Sub Change_pass
Cls : Home : Lcd "New Pass? Cls=" ; Chr(0)
Lowerline : Lcd " Exit"
Digits = 0
Waitms 500
Key = Getkbd()
If Num = "Cls" Then Call Change_pass
Incr Digits
Pass1(digits) = Num
Waitms 300
If Digits = 8 Then Call Confirm
End If
End Sub
'Confirm Password
Sub Confirm
Digits = 0
Cls : Home : Lcd "Confirm: Cls=" ; Chr(0)
Home L
Waitms 500
Key = Getkbd()
If Num = "Cls" Then Call Confirm
Incr Digits
Pass2(digits) = Num
Waitms 300
If Digits = 8 Then
Call Check1
Cursor Noblink
If Result = 8 Then
Cls : Home : Lcd "Pass Changed!"
For Temp = 1 To 8
Pass_eeprom(temp) = Pass1(temp)
Waitms 20
Next Temp
Call Load2ram
Call Getpass
Else
Waitms 500
Call Change_pass
End If
End If
End If
End Sub
'Confirm Pass Checker
Sub Check1
Result = 0
For Temp = 1 To 8
If Pass1(temp) = Pass2(temp) Then Incr Result
Next Temp
End Sub
'Keypad Decode Data Table
Decode:
Data "1" , "2" , "3" , ""
Data "4" , "5" , "6" , ""
Data "7" , "8" , "9" , ""
Data "Exit" , "0" , "Cls" , "" , ""
[/code]
[img][/img]
$hwstack = 64
$swstack = 64
$framesize = 64
'LCD
Config Lcd = 16 * 2
'Back Space Symbol
'Keypad
Config Kbd = Portb
[I/O
'Aliases
Relay Alias Portd.1
'Var
'Subroutines
Declare Sub Main
Declare Sub Getpass
Declare Sub Check
Declare Sub Change
Declare Sub Menu
Declare Sub Confirm
Declare Sub Check1
'Function
Call Main
End
Sub Main
Call Load2ram
Call Getpass
End Sub
Sub Default_pass
'Clear Pass
For Temp = 1 To 8
Waitms 20
Next Temp
Cursor Off
Waitms 1500
End Sub
'Load Pass to SRAM
Sub Load2ram
For Temp = 1 To 8
Waitms 20
Next Temp
End Sub
'Get Password
Sub Getpass
Digits = 0
Waitms 500
Key = Getkbd()
Incr Digits
Rcv(digits) = Num
Call Check
If Result <> 8 Then
'Error Pass
Cursor Noblink
Waitms 500
Call Getpass
Else
'Successful Pass
Call Menu
End If
End If
Waitms 300
End If
End Sub
Is_num = 1
Else
Is_num = 0
End If
End Function
'Password Checker
Sub Check
Result = 0
For Temp = 1 To 8
Next Temp
End Sub
Sub Menu
Waitms 500
Key = Getkbd()
If Num = "1" Then
Toggle Relay
If Relay = 0 Then
Else
End If
Waitms 500
End If
End Sub
'Change Password
Sub Change_pass
Digits = 0
Waitms 500
Key = Getkbd()
Incr Digits
Pass1(digits) = Num
Waitms 300
End If
End Sub
'Confirm Password
Sub Confirm
Digits = 0
Home L
Waitms 500
Key = Getkbd()
Incr Digits
Pass2(digits) = Num
Waitms 300
If Digits = 8 Then
Call Check1
Cursor Noblink
If Result = 8 Then
For Temp = 1 To 8
Waitms 20
Next Temp
Call Load2ram
Call Getpass
Else
Waitms 500
Call Change_pass
End If
End If
End If
End Sub
Sub Check1
Result = 0
For Temp = 1 To 8
Next Temp
End Sub
Decode:
[/code]
[img][/img]
