من ی برنامه نوشتم با دستور سویچ بریک اما ارو میده
http://uupload.ir/files/829t_untitled.jpg
CodeWizardAVR V2.05.0 Evaluation
Automatic Program Generator
© Copyright 1998-2010 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 08/14/2015
Author : Freeware, for evaluation and non-commercial use only
Company :
Comments:
Chip type : ATmega32
Program type : Application
Memory model : Small
External RAM size : 0
Data Stack size : 512
#include <mega32.h>
#include <delay.h>
#include <stdio.h>
#define ml1 PINC.4
#define ml2 PINC.5
#define mr1 PINC.6
#define mr2 PINC.7
#define sen1 PIND.2
#define sen2 PIND.3
#define sen3 PIND.4
#define sen4 PIND.5
#define sen5 PIND.6
#define sen6 PIND.7
#define sen7 PINC.0
#define sen8 PINC.1
#define sen9 PINC.2
#define sen10 PINC.3
void move (unsigned char dir); {
void main(void)
// Port A initialization
PORTA=0x00;
DDRA=0x00;
// Port B initialization
// State7=T State6=T State5=T State4=P State3=T State2=P State1=T State0=T
PORTB=0x14;
DDRB=0x00;
// Port C initialization
// Func7=Out Func6=Out Func5=Out Func4=Out Func3=In Func2=In Func1=In Func0=In
// State7=1 State6=1 State5=1 State4=1 State3=P State2=P State1=P State0=P
PORTC=0xFF;
DDRC=0xF0;
// Port D initialization
// State7=P State6=P State5=P State4=P State3=P State2=P State1=T State0=T
PORTD=0xFC;
DDRD=0x00;
// Clock source: System Clock
// Mode: Normal top=0xFF
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
TIMSK=0x00;
// USART initialization
// USART disabled
UCSRB=0x00;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC disabled
ADCSRA=0x00;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
move('s');
while (1)
if((sen5==1) || (sen6==1))
move('f');
if((sen1==1) || (sen2==1))
move('c');
if((sen3==1))
move('l');
if((sen6==1))
move('r');
if((sen9==1) || (sen10==1))
move('u');
if(sen1==0 || sen2==0 || sen3==0 || sen4==0 || sen5==0 || sen6==0 || sen7==0 || sen8==0 || sen9==0 || sen10==0)
move('f');
delay_ms(20);
switch (dir)
case 'f':
mr1=0;
mr2=1;
ml1=1;
ml2=0;
break;
case 'u' :
mr1=1;
mr2=0;
ml1=1;
ml2=0;
break;
case 'c' :
mr1=0;
mr2=1;
ml1=0;
ml2=1;
break;
case 's' :
mr1=0;
mr2=0;
ml1=0;
ml2=0;
break;
case 'r' :
mr1=1;
mr2=0;
ml1=0;
ml2=0;
break;
case 'l' :
mr1=0;
mr2=1;
ml1=1;
ml2=0;
break;
eca در
