سلام می خواستم ببینم چجوری میشه یک موج سینوسی با AVR ساخت؟
تولید موج سینوسی با AVR
پاسخ : تولید موج سینوسی با AVR
کد:[left] /***************************************************** Project : Generating sine waveform Author : Reza Sepas Yar Email : info@avr.ir Chip type : ATmega16 Clock frequency : 4.000000 MHz *****************************************************/ #include <mega16.h> flash char sinewave[]={ 0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x01,0x02,0x03,0x03,0x04,0x05,0x06,0x07,0x08, 0x09,0x0a,0x0c,0x0d,0x0f,0x10,0x12,0x13,0x15,0x17,0x19,0x1b,0x1d,0x1f,0x21,0x23, 0x25,0x27,0x2a,0x2c,0x2e,0x31,0x33,0x36,0x38,0x3b,0x3e,0x40,0x43,0x46,0x49,0x4c, 0x4f,0x51,0x54,0x57,0x5a,0x5d,0x60,0x63,0x67,0x6a,0x6d,0x70,0x73,0x76,0x79,0x7c, 0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae, 0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,0xd8, 0xda,0xdc,0xde,0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,0xf5, 0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,0xfd,0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7, 0xf6,0xf5,0xf3,0xf2,0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,0xe2,0xe0,0xde,0xdc, 0xda,0xd8,0xd5,0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,0xbf,0xbc,0xb9,0xb6,0xb3, 0xb0,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x98,0x95,0x92,0x8f,0x8c,0x89,0x86,0x83, 0x80,0x7c,0x79,0x76,0x73,0x70,0x6d,0x6a,0x67,0x63,0x60,0x5d,0x5a,0x57,0x54,0x51, 0x4f,0x4c,0x49,0x46,0x43,0x40,0x3e,0x3b,0x38,0x36,0x33,0x31,0x2e,0x2c,0x2a,0x27, 0x25,0x23,0x21,0x1f,0x1d,0x1b,0x19,0x17,0x15,0x13,0x12,0x10,0x0f,0x0d,0x0c,0x0a, 0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x03,0x02,0x01,0x01,0x01,0x01,0x01,0x01,0x01 }; char i=0; interrupt [TIM1_COMPA] void timer1_compa_isr(void) { OCR1A=sinewave[i]; i++; // if(i==255) // i=0; } void main(void) { DDRD=0xFF; // Timer/Counter 1 initialization // Clock source: System Clock // Clock value: 8000.000 kHz // Mode: Fast PWM top=00FFh // OC1A output: Non-Inv. // OC1B output: Discon. // Noise Canceler: Off // Input Capture on Falling Edge TCCR1A=0x81; TCCR1B=0x09; TCNT1H=0x00; TCNT1L=0x00; ICR1H=0x00; ICR1L=0x00; OCR1AH=0x00; OCR1AL=0x00; OCR1BH=0x00; OCR1BL=0x00; // Timer(s)/Counter(s) Interrupt(s) initialization TIMSK=0x10; //enable global interrups #asm("sei"); while (1); } [/left]There is nothing so practical as a good theory. — Kurt Lewin, 1951
- تشکرها 1
من داخل کتاب 10 مدار با avr این مدارو +برنامه اش به زبان سی دیدم اگه حاستی بگو برات بزارمانجام پروژه های برنامه نویسی اندروید
برنامه زیر دو موج PWM روی خروجی های OC1A و OC1B در mega8 تولید می کند که با فیلتر کردن آن می توان موج های سینوسی با اختلاف فاز 180 درجه را مشاهده کرد. فرکانس سینوسی در محدوده 488.2-1.9 هرتز تغییر می کند که برای تغییر آن باید یک ولتاژ متغیر در محدوده 0 تا AVcc را به ورودی ADC0 اعمال کرد. این کار می تواند از طریق یک پتاسیومتر انجام شود که دو سر کناری آن به زمین و AVcc و سر وسط آن به ADC0 متصل می شود و با تغییر وضعیت پتانسیومتر، فرکانس خروجی تغییر خواهد کرد. فرکانس کلاک mega8 باید در 8MHz تنظیم شود که این کار از طریق تنظیم مناسب فیوزبیت ها انجام می گیرد.همچنین فرکانس حامل PWM برابر 15.6 کیلوهرتز می باشد.
کد:#include <mega8.h> volatile unsigned char Delay; flash unsigned char sine[256]={ 0x80,0x83,0x86,0x89,0x8c,0x8f,0x92,0x95,0x98,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae, 0xb0,0xb3,0xb6,0xb9,0xbc,0xbf,0xc1,0xc4,0xc7,0xc9,0xcc,0xce,0xd1,0xd3,0xd5,0xd8, 0xda,0xdc,0xde,0xe0,0xe2,0xe4,0xe6,0xe8,0xea,0xec,0xed,0xef,0xf0,0xf2,0xf3,0xf5, 0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfc,0xfd,0xfe,0xfe,0xff,0xff,0xff,0xff,0xff, 0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfe,0xfd,0xfc,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7, 0xf6,0xf5,0xf3,0xf2,0xf0,0xef,0xed,0xec,0xea,0xe8,0xe6,0xe4,0xe2,0xe0,0xde,0xdc, 0xda,0xd8,0xd5,0xd3,0xd1,0xce,0xcc,0xc9,0xc7,0xc4,0xc1,0xbf,0xbc,0xb9,0xb6,0xb3, 0xb0,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x98,0x95,0x92,0x8f,0x8c,0x89,0x86,0x83, 0x80,0x7c,0x79,0x76,0x73,0x70,0x6d,0x6a,0x67,0x63,0x60,0x5d,0x5a,0x57,0x54,0x51, 0x4f,0x4c,0x49,0x46,0x43,0x40,0x3e,0x3b,0x38,0x36,0x33,0x31,0x2e,0x2c,0x2a,0x27, 0x25,0x23,0x21,0x1f,0x1d,0x1b,0x19,0x17,0x15,0x13,0x12,0x10,0x0f,0x0d,0x0c,0x0a, 0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x03,0x02,0x01,0x01,0x00,0x00,0x00,0x00,0x00, 0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x01,0x02,0x03,0x03,0x04,0x05,0x06,0x07,0x08, 0x09,0x0a,0x0c,0x0d,0x0f,0x10,0x12,0x13,0x15,0x17,0x19,0x1b,0x1d,0x1f,0x21,0x23, 0x25,0x27,0x2a,0x2c,0x2e,0x31,0x33,0x36,0x38,0x3b,0x3e,0x40,0x43,0x46,0x49,0x4c, 0x4f,0x51,0x54,0x57,0x5a,0x5d,0x60,0x63,0x67,0x6a,0x6d,0x70,0x73,0x76,0x79,0x7c}; interrupt [TIM2_COMP] void timer2_comp_isr(void) { static unsigned char index=0; if(!--Delay) { Delay=(ADCH?ADCH:1); OCR1A=sine[++index]; OCR1B=sine[index]; } } void main(void) { DDRB=0x06; ADMUX=0x60; ADCSRA=0xE6; while(!ADCSRA.4); Delay=(ADCH?ADCH:1); OCR1A=sine[0]; OCR1B=sine[0]; TCCR1A=0xB1; TCCR1B=0x01; TCCR2=0x09; OCR2=63; TIMSK=0x80; #asm("sei") while (1); }اوژن: به معنای افکننده و شکست دهنده است
- تشکرها 1
تولید سه فاز بصورت ساده مستلزم وجود سه خروجی PWM است که بهترن روش استفاده از شماره هایی مانند mega64 است که تایمرهای 16 بیتی آن دارای 3 واحد compareهستند. هرچند که در mega8 می توان در وضعیت 8 بیتی از OC2 هم استفاده کرد که به دلیل استفاده از دو تایمر مختلف، کار مشکل تری نسبت به mega64 می باشد. از نظر نرم افزاری کافی است که اندیس آرایه را برای 3 فاز به گونه ای انتخاب کنیم تقریبا 120 درجه را محقق کند. از آنجایی که آرایه مورد استفاده دارای 256 عضو است، 120 درجه معادل 256/3 است که بصورت صحیح 85 می شود. برای 240 درجه هم 170 یا 171 را می توان در نظر گرفت. با توجه به اینکه اندیس آرایه از صف شروع می شود، کافی است دو فاز دیگر را با اختلاف اندیس 84 و 170 از جدول بخوانیم تا 3 فاز مورد نظر ایجاد شوند.نوشته اصلی توسط زواربا سلام مهندس میشه درباره این برنامه یه توضیح بدید و بفرمایید برای سه فاز کردنش بایدچه کار کرد؟در اصل اگر بخواهیم این را به یک پل igbt برای ساختن اینورتر سه فاز استفاده کرد باید چه کار کرد؟ممنونم
اما برای کاربردهای کنترل موتور تنها تولید سه فاز به اینصورت جابگو نیست و مواردی مانند منحنی V/f و فرکانس Boost و Acceleration وِ Decelaration و مانند آن باید در نرم افزار پیش بینی شود.
- تشکرها 2
ممنون از پاسختون چند تا سوال دارم 1- سه تا pwm برای اینورتر 3 فاز کم نیست؟آخه پل igbt 6 تا ورودیه گیت داره؟2-در پل igbt دوتا igbt که امیتر یکی به کلکتور دومی وصله پالس گیت اولی با دومی باید نات یکدیگر باشه؟3-برای ساختن یک کنترل دور برای تمام تنظیمات یک مگا 64 جواب میده یا باید از arm استفاده کرد؟4-اگر بخوام این کار را بکنم و این تاپیک را ادامه بدیم برای ساخت یک کنترل دور شما راهنمایی میکنید تا انجام بشه البته میدونم وقتتون کمه اما تجربیات شما در این کار میتونه خیلی مفید باشه و فکر کنم تاپیک خوبی بشه که همه میتونن استفاده کنند من منتظر پاسخ شما هستم ممنونم
- تشکرها 1
1و2- در عمل به 6 موج PWM نیاز است که دو موج بازوی ها بالا و پائین علاوه بر آنکه باید Not یکدیگر باشند، بلکه باید بین آنها یک Dead time هم وجود داشته باشد. به این معنی که بین غیرفعال شدن یک موج و فعال شدن موج دوم یک تاخیر وجود داشته باشد که با استفاده از 3 گیت Not و درایوری مانند IR2130می توان این هدف را محقق کرد. زیرا IR2130 بصورت خودکار Dead time را به موج اضافه می کند. بنابراین همان 3 موج PWM برای این کار کافی هستند. البته در XMEGA بصورت خاص این امکان تولید Dead time پیش بینی شده که مورد بحث این تاپیک نیست.نوشته اصلی توسط زوارممنون از پاسختون چند تا سوال دارم 1- سه تا pwm برای اینورتر 3 فاز کم نیست؟آخه پل igbt 6 تا ورودیه گیت داره؟2-در پل igbt دوتا igbt که امیتر یکی به کلکتور دومی وصله پالس گیت اولی با دومی باید نات یکدیگر باشه؟3-برای ساختن یک کنترل دور برای تمام تنظیمات یک مگا 64 جواب میده یا باید از arm استفاده کرد؟4-اگر بخوام این کار را بکنم و این تاپیک را ادامه بدیم برای ساخت یک کنترل دور شما راهنمایی میکنید تا انجام بشه البته میدونم وقتتون کمه اما تجربیات شما در این کار میتونه خیلی مفید باشه و فکر کنم تاپیک خوبی بشه که همه میتونن استفاده کنند من منتظر پاسخ شما هستم ممنونم.
3- برای روش PWM سینوسی یک mega64 می تواند جوابگو باشد و نیازی به ARM نیست.
4- مگر تاکنون غیر از این بوده و در تاپیک MC3 مگر چندین صفحه به شما و سایر دوستان راهنمایی نشد. البته شرط آن درخواست راهنمایی فقط در حد رفع اشکال است و 99 درصد زحمت کارها را باید خودتان متقبل شوید.اوژن: به معنای افکننده و شکست دهنده است
- تشکرها 1
با سلام خدمت دوستان .ببخشید من یه سئوال داشتم شاید ارتباطی با موضوع اصلی نداشته یاشه ولی میپرسم .
لطفا بفرمائید که من با یک اتمگا 8 و کریستال 8 مگ حداکثر چه فرکانسی میتونم برای موج PWM تولید کنم . من خودم فکرمیکنم حداکثر 15 کیلو هرتز. من 100 کیلونیاز دارم :redface:وقتی همه نیروهای جسمی و ذهنی متمرکز شوند توانایی فرد برای حل مشکلات به طور حیرت انگیزی چند برابر می شود .
نرمن وینسنت پیل
حتما نباید PWM رو از تایمر بگیرید
شمل میتونید یک زمان کوچک رو رو تایمر تنظیم کنید و با متغیر های مختلف PWM بگیریدخدا گفت : به جهنم ببریدش، او برگشت و با تعجب به خدا نگاه کرد. خدا گفت : به بهشت ببریدش. فرشتگان پرسیدند: چرا؟! خدا گفت : او هنوز به من امیدوار است...
ببخشید آقای نجفی .این جواب مربوط به سئوال منه یا آقای زوار؟نوشته اصلی توسط حمید نجفیسلام
اگه جواب منه لطفا کمی بیشتر توضیح بدید که چطوری به فرکانس مورد نظرم برسم؟100کیلووقتی همه نیروهای جسمی و ذهنی متمرکز شوند توانایی فرد برای حل مشکلات به طور حیرت انگیزی چند برابر می شود .
نرمن وینسنت پیل
