پاسخ : سوالات مربوط به LCD های کاراکتری و گرافیکی
^ خدایا شکرت. یکی بالاخره میخواد کمک کنه :biggrin:
این شماتیک:
http://www.pic1.iran-forum.ir/images...9676252341.jpg
و این برنامه :
CodeWizardAVR V2.05.0 Advanced
Automatic Program Generator
© Copyright 1998-2010 Pavel Haiduc, HP InfoTech s.r.l.
http://www.hpinfotech.com
Project :
Version :
Date : 3/26/2012
Author : www.Eca.ir *** www.Webkade.ir
Company :
Comments:
Chip type : ATmega64
Program type : Application
AVR Core Clock frequency: 4.000000 MHz
Memory model : Small
External RAM size : 0
Data Stack size : 1024
#include <mega64.h>
#include <delay.h>
// Alphanumeric LCD Module functions
#include <alcd.h>
void main(void)
// Port A initialization
PORTA=0x00;
DDRA=0x00;
// Port B initialization
// Func7=Out Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=0 State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTB=0x00;
DDRB=0x80;
// Port C initialization
PORTC=0x00;
DDRC=0x00;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Port E initialization
PORTE=0x00;
DDRE=0x00;
// Port F initialization
PORTF=0x00;
DDRF=0x00;
// Port G initialization
// Func4=In Func3=In Func2=In Func1=In Func0=In
// State4=T State3=T State2=T State1=T State0=T
PORTG=0x00;
DDRG=0x00;
// Clock source: System Clock
// Mode: Normal top=0xFF
// OC0 output: Disconnected
ASSR=0x00;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// OC1C output: Discon.
// Noise Canceler: Off
// Compare C Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
OCR1CH=0x00;
OCR1CL=0x00;
// OC2 output: Disconnected
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// Timer/Counter 3 initialization
// Clock value: Timer3 Stopped
// OC3A output: Discon.
// OC3B output: Discon.
// OC3C output: Discon.
// Timer3 Overflow Interrupt: Off
TCCR3A=0x00;
TCCR3B=0x00;
TCNT3H=0x00;
TCNT3L=0x00;
ICR3H=0x00;
ICR3L=0x00;
OCR3AH=0x00;
OCR3AL=0x00;
OCR3BH=0x00;
OCR3BL=0x00;
OCR3CH=0x00;
OCR3CL=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
// INT3: Off
// INT4: Off
// INT5: Off
// INT6: Off
// INT7: Off
EICRA=0x00;
EICRB=0x00;
EIMSK=0x00;
TIMSK=0x00;
ETIMSK=0x00;
// USART0 initialization
// USART0 disabled
UCSR0B=0x00;
// USART1 initialization
// USART1 disabled
UCSR1B=0x00;
// Analog Comparator: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC disabled
ADCSRA=0x00;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
// Alphanumeric LCD initialization
// Connections specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTC Bit 1
// RD - PORTC Bit 7
// EN - PORTC Bit 2
// D4 - PORTC Bit 3
// D5 - PORTC Bit 4
// D6 - PORTC Bit 6
// D7 - PORTC Bit 5
// Characters/line: 16
lcd_init(16);
while (1)
// Place your code here
PORTB.7=1;
lcd_clear();
lcd_gotoxy(0,0);
lcd_putsf("salam"
delay_ms(500);یلی
PORTB.7=0;
delay_ms(500);
این led که گذاشتم شروع می کنه چشمک زدن. یعنی برنامه درست ریخته شده و میکرو داره کار می کنه. ولی lcd انگار نه انگار که خبری شده. خیلی خیلی خیلی ممنون که یه جوابی به این سوالم دادید :applause: اگه بتونید مشکل من رو حل کنید که دیگه نور علی نور :icon_razz: خیلی ممنون
^ خدایا شکرت. یکی بالاخره میخواد کمک کنه :biggrin:این شماتیک:
و این برنامه :
Project :
Version :
Date : 3/26/2012
Company :
Comments:
#include <mega64.h>
#include <delay.h>
#include <alcd.h>
void main(void)
PORTA=0x00;
DDRA=0x00;
PORTB=0x00;
DDRB=0x80;
PORTC=0x00;
DDRC=0x00;
PORTD=0x00;
DDRD=0x00;
PORTE=0x00;
DDRE=0x00;
PORTF=0x00;
DDRF=0x00;
PORTG=0x00;
DDRG=0x00;
ASSR=0x00;
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
OCR1CH=0x00;
OCR1CL=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
TCCR3A=0x00;
TCCR3B=0x00;
TCNT3H=0x00;
TCNT3L=0x00;
ICR3H=0x00;
ICR3L=0x00;
OCR3AH=0x00;
OCR3AL=0x00;
OCR3BH=0x00;
OCR3BL=0x00;
OCR3CH=0x00;
OCR3CL=0x00;
// INT0: Off
// INT1: Off
// INT2: Off
// INT3: Off
// INT4: Off
// INT5: Off
// INT6: Off
// INT7: Off
EICRA=0x00;
EICRB=0x00;
EIMSK=0x00;
TIMSK=0x00;
ETIMSK=0x00;
// USART0 disabled
UCSR0B=0x00;
// USART1 disabled
UCSR1B=0x00;
ACSR=0x80;
SFIOR=0x00;
// ADC disabled
ADCSRA=0x00;
// SPI disabled
SPCR=0x00;
// TWI disabled
TWCR=0x00;
// RS - PORTC Bit 1
// RD - PORTC Bit 7
// EN - PORTC Bit 2
// D4 - PORTC Bit 3
// D5 - PORTC Bit 4
// D6 - PORTC Bit 6
// D7 - PORTC Bit 5
lcd_init(16);
while (1)
PORTB.7=1;
lcd_clear();
lcd_gotoxy(0,0);
lcd_putsf("salam"
;delay_ms(500);یلی
PORTB.7=0;
delay_ms(500);
oo:
