پاسخ : سوالات مربوط به LCD های کاراکتری و گرافیکی
سلام ، نحوه اتصال دوربین به میکرو با ال سی دی رنگی
void N11_DrawBitmap(_const unsigned char *bitmap, unsigned char x, unsigned char y, N11_Pmode mode)
unsigned char header, width, height;
unsigned char xx, yy, rr;
unsigned int xy;
unsigned char pd, pc, ps;
unsigned char Cdata;
header = _pgm_read_byte(bitmap[0]); //header size & width & height
width = _pgm_read_byte(bitmap[1]);
height = _pgm_read_byte(bitmap[2]);
ps = _ror(1 << (y%8));
for(xx=0; xx<width; xx++)
pd = ps;
Cdata = _pgm_read_byte(bitmap[xx+header]);
for(yy=0, pc=0; yy<height; yy++,pc++)
if(pc==8)
xy = (unsigned char)(yy/8)*width + xx+header;
Cdata = _pgm_read_byte(bitmap[xy]);
pc = 0;
}//if pc
rr = (unsigned char)((y+yy)/8);
pd = _rol(pd);
//Draw BMP!
if(mode == PIXEL_XOR)
if(bit_is_set(Cdata, pc)) N11_Cache[x+xx][rr] &= ~pd;
else N11_Cache[x+xx][rr] |= pd;
else
if(bit_is_set(Cdata, pc)) N11_Cache[x+xx][rr] |= pd;
else N11_Cache[x+xx][rr] &= ~pd;
}//for yy
}//for xx
N11_Update();
} //*N11_DrawBitmap
//--- Loads a Bitmap to GLCD ---//
void KS108_DrawBitmap(_const unsigned char *bitmap, unsigned char x, unsigned char y, Show_Mode mode)
unsigned char width, height, header;
unsigned char displayData;
unsigned char xx, yy, yyy;
unsigned char hh, ww;
unsigned char endShift;
unsigned int xy;
// Drawing position calculation
ww = width;
hh = height;
if((x+ww) > DISPLAY_WIDTH) ww = DISPLAY_WIDTH -x;
if((y+hh) > DISPLAY_HEIGHT) hh = DISPLAY_HEIGHT -y;
if(hh%8) hh = hh/8+1;
else hh = hh/8;
endShift = 0;
// Draw my BMP!
if(mode != TRANS) KS108_FillRect(x, y, width-1, height-1, WHITE); //no transparent
for(yy=0; yy<hh; yy++)
yyy = y + (yy * 8);
if(yyy > (DISPLAY_HEIGHT-8))
endShift = y % 8;
yyy = DISPLAY_HEIGHT -8;
KS108_GotoXY(x, yyy);
xy = (unsigned int)(yy)*width +header;
for(xx=0; xx<ww; xx++)
displayData = _pgm_read_byte(bitmap[xy++]);
if(endShift) KS108_WriteData((displayData << endShift)|KS108_ReadData());
else KS108_WriteData(displayData);
if(mode == INVERS) KS108_InvertRect(x, y, width-1, height-1); //invers color
} //KS108_DrawBitmap
oo:
