دوستان یک دماسنج با DHT22 و AVR درست کردم ،ولی یه اشکال کوچولو داره واونم اینه که وقتی دما زیر 10 درجه بیاد، 99 رو نشون میده وهرچه دما پایینتر بیاد فرضا 7 یا 6 درجه دمای نمایش داده شده نیز کم میشود،درصورتی که برای دماهای بالای صفر دما رو خوب نمایش میده
مشکل چی میتونه باشه؟برنامه به بان بسکام هست
$regfile = "m8adef.dat"
$crystal = 8000000
$hwstack = 40
$swstack = 16
$framesize = 32
Config Spi = Hard , Interrupt = On , Data Order = Lsb , Master = Yes , Polarity = High , Phase = 0 , Clockrate = 4
Enable Interrupts
Enable Spi
On Spi Ers
Config Portb.5 = Output
Config Portb.3 = Output
Config Pinb.2 = Input
Config Pinb.4 = Input
Config Pinb.0 = Input
Config Portc.0 = Output
Config Portc.5 = Output
Portc.0 = 1 'DHT22 Data
Config Timer0 = Timer , Prescale = 8
Spiinit
'Const Min_time = 95
'Const Min_time = 48
Const Min_time = 48
Dim C As Single
Dim B(2) As Byte
Dim Count As Byte
Dim Signaltime(43) As Byte
Dim Humidityw As Word
Dim Temperaturew As Word
Dim Humsens_chksum As Byte
Dim Hum As String * 2
Dim Dataout As String * 4
Dim Temp As String * 2
Dim Humiditys As String * 16
Dim Temperatures As String * 16
Dim Code As Byte
Dim A As Byte
Dim Strstring As String * 14
Dim Ib As Byte
Dim Info As Byte
Dim I As Byte
Declare Sub Read_timings
Declare Sub Humtemp_values
Declare Function Compare_chksum(byval Hsens_humidity As Word , _
Byval Hsens_temperature As Word , Byval Hsens_chksum As Byte) As Byte
For I = 1 To 5
Toggle Portc.5
Waitms 150
Next
Portc.5 = 0
Do
Call Humtemp_values
Humiditys = Str(humidityw)
Temperatures = Str(temperaturew)
Temp = Left(temperatures , 2)
Hum = Left(humiditys , 2)
B(1) = Val(temp)
B(2) = Val(hum)
Info = 113
Portc.0 = 0
Spdr = Info
Waitms 100
Portc.0 = 0
Spdr = B(1)
Waitms 100
Info = 114
Portc.0 = 0
Spdr = Info
Waitms 100
Portc.0 = 0
Spdr = B(2)
Loop
End
Sub Read_timings
Wait 3
Count = 1
Config Pinb.0 = Output : Portb.0 = 0 ' request data
Waitms 20 ' wait 20 ms
Config Pinb.0 = Input ' wait for data, receive data
While Count < 43 'collect 42 timings / signals
Bitwait Pinb.0 , Set 'signal goes high > start timer
Start Timer0
Bitwait Pinb.0 , Reset 'signal goes low > stop timer
Stop Timer0
Signaltime(count) = Tcnt0 'store number of ticks per signal in Signaltime byte
Tcnt0 = 0
Incr Count
Wend
End Sub
'############################################## Humidity and temperature values
Sub Humtemp_values
Local X As Byte
Humidityw = 0
Temperaturew = 0
Humsens_chksum = 0
Call Read_timings
For Count = 3 To 42 ' skip first two
Select Case Count
Case 3 To 18
X = 18 - Count
If Signaltime(count) > Min_time Then Toggle Humidityw.x
Case 19 To 34
X = 34 - Count
If Signaltime(count) > Min_time Then Toggle Temperaturew.x
Case 34 To 42
X = 42 - Count
If Signaltime(count) > Min_time Then Toggle Humsens_chksum.x
End Select
Next
End Sub
'######################### Calculate Checksum and compare with trasnmitted value
Function Compare_chksum(byval Hsens_humidity As Word , Byval Hsens_temperature As Word , Byval Hsens_chksum As Byte) As Byte
Local Chksum As Byte
Chksum = Low(hsens_humidity ) + High(hsens_humidity )
Chksum = Chksum + Low(hsens_temperature)
Chksum = Chksum + High(hsens_temperature)
If Chksum = Hsens_chksum Then
Compare_chksum = 1
Else
Compare_chksum = 0
End If
End Function
Ers:
Portd.0 = 1
Return
oo:
